Manual Hub Wheel bearing replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Apr 17, 2017.
  1. Apr 17, 2017 at 1:46 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So I am in the process of changing out my wheel bearing and I am not sure what to do next. I got the socket to get the nut off but decided to stop and get some opinions before I start ripping this thing apart. I feel like these bronze nuts need to be removed somehow? obviously the seal needs to come out...just looking for some opinions from someone who has done this before.
  2. Apr 17, 2017 at 2:00 PM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    Those are brass bushings and they don't need to come out. And actually be super careful with them cause if you damage one of the inner ones, right now, the only option to replace is buying a complete new hub that seems to only be available from Toyota and they're $150+ each. ORS normally has the brass bushings, but they only have outers right now and the inners have been back order for a good long while now....
  3. Apr 17, 2017 at 2:04 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    subbed for progress :spy:
  4. Apr 17, 2017 at 2:19 PM
    harper7
    harper7 Well-Known Member
    Gary
    Tulsa/Claremore OK
    00 Imperial Jade 4x4 TRD,01 TRD 5sp
    ^^^ What he said.......aaaalways watchin:spy:
    I have a junkyard set that I'm eventually going to install
  5. Apr 18, 2017 at 1:45 PM
    cooper4x4
    cooper4x4 Well-Known Member
    Dallas
    02 Tacoma SAS
    See attached FSM pages. You'll need a very big press to get the bearings out.
  6. Apr 18, 2017 at 2:17 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    That is very helpful sir thank you! I have a 20 ton press. I am now wondering how anyone accomplishes this without those special tools.
  7. Apr 18, 2017 at 2:18 PM
    cooper4x4
    Dallas
    02 Tacoma SAS
    I think mine took 21-22 tons on a 40 ton press. Maybe you'll get lucky with the 20 ton.
  8. Apr 18, 2017 at 2:27 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    The more I look at it, really doesn't seem to bad. So if this metal flange is part of the outer seal (I assume it is) then I can just rip it out.
    Then pull the snap ring out and press everything out if i am reading all of this correctly
  9. Apr 18, 2017 at 2:28 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    @cooper4x4 could you elaborate some on this step for me?
  10. Apr 18, 2017 at 2:31 PM
    cooper4x4
    Dallas
    02 Tacoma SAS
    That is where you press out the hub. You don't need the SST if you have proper press tools. Be careful as the bearing exploded while pressing out the hub (hub was seized to the inner race). Make sure your feet are clear.
  11. Apr 18, 2017 at 2:37 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So I don't need to remove the hub from the spindle before I press out the bearing? Also am i correct in assuming that metal flange is part of the outer bushing in my previous post?
    Also what kind of special press tools did you use?
  12. Apr 18, 2017 at 2:40 PM
    cooper4x4
    Dallas
    02 Tacoma SAS
    You'll press the hub out first. Then, if I remember correctly, there is another snap ring that you'll remove and then press out the bearing. I don't remember what tools we used for the press (7-8 years ago is the last time I did this). You'll need something to support the knuckle as you press out the hub.
  13. Apr 19, 2017 at 12:15 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I just helped a friend put Tacoma knuckles with manual hubs on this 3rd Gen 4runner. We replaced the bearings and seals on the knuckles and then installed them on this rig. We videoed the job and I'll be posting it soon.
  14. Apr 19, 2017 at 6:35 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    That would be perfect! Any idea when that might be done? my taco is kind of siting on jack stands till i can figure this out.. lol
  15. Apr 19, 2017 at 6:45 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Honestly I'd just swing by a machine so and have them press it in for you.
  16. Apr 19, 2017 at 8:04 AM
    digitalferg
    Southern Utah
    Since I didn't have a press nor could I find anybody local willing to help me out or let me use their press, this is pretty much what I did when I went manual hubs on my old Tacoma...but I actually went to a local Toyota dealer. I took in my original spindles and the manual hub spindles and had them swap the manual hubs into my original spindles with new bearings and seals etc. They had no problem doing it for me even with me supplying the bearings and seals that I had bought online (OEM Toyota parts though of course). That was back in 2013. I think they charged me like $150. I've since found a good small auto shop that I've gone to a bunch for other stuff that would prob do this job for $50 or so.
  17. Apr 19, 2017 at 8:36 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I did my 95' w/ manual hubs with my 20 ton china freight press,, i remember, (kinda), that the one of the hardest things was removing the snap rings without the proper snap ring tool, i had a complete set, so I thought, but these Japs require the cup kind for lack of better description. You can do it with a screwdriver, but those pliers made it alot easier. I got mine at the NAPA store for about $20.
    The bearing was super tight, but I got it,, sounded like a rifle when it finally broke lose.
  18. Apr 19, 2017 at 8:44 AM
    Timmah!
    TIM
    In 2013, I'm guessing their shop labor rates were around $100/hr and they charged you 1.5 hours. My local dealership in the People's Republic of Northern California charges $150/hr and I bet they would quote me 2 hours for this job. I've also checked with a local machine shop out of curiosity to see what they would charge to do press work for rear axle seal bearings and they said around $200 for the set.
    So, I reckon where you live makes a pretty big difference. Since I prefer doing my own work anyway, it was a no brainer to buy a Harbor Freight press since it's paid for itself after one job. The Harbor Freight 20 Press is currently selling for $175. I've also got more money into a press sleeve kit and extra press plates but now that I've helped two people with their rear axle seal bearing jobs and the recent manual hub conversion, it's been a worthwhile investment to document the jobs so I can share them on YouTube. The two rear axle seal videos (ABS and Non-ABS) will most likely be uploaded sometime today. The manual hub conversion will be within the next week hopefully.
  19. Apr 19, 2017 at 8:46 AM
    Timmah!
    TIM
    I did all the rough editing and my buddy Sean just needs to finalize it and make it look and sound better. I'm guessing he'll have it done sometime this week.
    Dalandser likes this.
  20. Apr 19, 2017 at 12:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Keep it coming - once I have enough money, space, and time to get all my own tools I'll never need to go to a mechanic again with your diy's. I'm glad to have such a good resource!
