Making 6in Procomp Lift Better
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kinjo, Mar 3, 2017.
  1. Mar 3, 2017 at 8:03 AM
    Kinjo
    Kinjo [OP] Where America's Day Begins
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    6in ProComp,TC UCA, ARB Lockers 456 gears, TRD CAI/Catback, ARB Dual Compressor, HID HL & Fog lamps, 6in Alcan rear leafs w/500# load, king CO w/ res
    i have a 08 Tacoma DC 4x4 with 6in procomp lift, 35in wheels and it rides like s***. I have been doing a lot of reading on what other mates have posted but none are current with todays newer designed options such as heim uca's.
    I would love to have a better performing truck with what i have now and want to make my ride more offroad capable....leaning more to a fuctional mid travel rig. Ie...uca, coil over w/ remote res, extended/non travel.....
    I would love the hear from anyone who has made improvements to the same setup that i currently have would be greatly appreciated. Please specific on what you did.
  2. Mar 3, 2017 at 9:38 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    No experience with using or removing DBs, but you have laid the frame work above: remove it and install a proper MT setup.
  3. Mar 3, 2017 at 12:55 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    I have a 6'' procomp on my truck as well. It actually rides great compared to anything else I have ever driven that was lifted 6'', no complaints at all. I did not install this kit and would have opted for a mid or long travel setup instead if it was my choice. The truck came with it installed.
    There has been some people who have removed them with good results. Going to take a competent fabricator / welder to do so, and probably at least 6 hours of labor just to do the removal and install of drop bracket / crossmember if your paying them.
    I have upgraded my pro-comp with Icon coil overs in the front and fox shocks in the rear (neither have remote res), which greatly enhanced the ride, but the biggest for me was the upgrade to Light Racing upper control arms.... Huge difference in the way it handled (especially at highway speeds) imo.
  4. Mar 3, 2017 at 6:04 PM
    Kinjo
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    Im looking at TC heim uca to start, while repairing swaybar link threads on the control arm; i noticed that my upper ball joint was broke during re assembly. Im wondering if thats the loud pop sound i hear when leave my driveway.
  5. May 13, 2017 at 12:24 AM
    Kinjo
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    Installed Alcan 6in leafs with 500lb load, timbren shackle flip with bump stops and king shocks with remote res today.
    5678ta and excorcist like this.
  6. May 13, 2017 at 9:37 AM
    excorcist
    Reno, NV
    Thats legit
  7. May 13, 2017 at 9:43 AM
    Manwithoutaplan
    ID
    what are the length of your shocks?
  8. May 13, 2017 at 2:08 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    Those shocks look like they have become the bump stops...Or is it just me?
  9. May 13, 2017 at 2:19 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Looks like it would be close
  10. May 13, 2017 at 2:27 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Was thinking the same thing. Need to cycle that leaf pack and possibly space that timbren.
    kh7nm likes this.
  11. May 13, 2017 at 2:38 PM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Yet another "happy" DB story.
    But god forbid anybody says anything negative BD lifts on this forum:rolleyes:
    Anyway, get good quality coilovers for the front, new leaf packs with good quality shocks for the rear. basically, redo most of the lift $$$$$$.
    The only other option is to remove the DB and bring the truck back to factory specs... - which is neither cheap or easy.
    agunday21 likes this.
  12. May 14, 2017 at 9:14 AM
    Kinjo
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    Not sure on lengeth but according to king, these were built for the 6in pro comp lift.
  13. May 14, 2017 at 9:16 AM
    Kinjo
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    After i get the front suspension set, ill flex then adj bumpstops as needed.
  14. May 16, 2017 at 8:26 PM
    Homemade Taco
    Homemade Taco New Member
    Hey Kinjo, I'm new to this place. Found a lot of good info here and decided to join. I have a very similar build to yours. How do you like those shocks so far? And what did you run before? And how do they feel in comparison? Thanks!
  15. May 19, 2017 at 1:37 PM
    Kinjo
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    I use to run blocks with add a leaf from procomp. Now with 6in alcan leaf and king shock at the rear, my truck rides better. Cost was $1800 including timbren shackle flip. IMG_0387.jpg
    I'm not happy with the front as its still a work in progress with king shocks. Installed king 25001-619 with remote res and additional 5 turn of preload that rasied ride height 1in from factoy setting, but rides rough.
  16. May 19, 2017 at 9:42 PM
    bullaculla
    Da big big island!
    You really don't need 700# springs. Unless you are planing on a plate bumper, winch and armor. I was running 700s with steel bumper, full steel skids, winch, and sliders, and it rode fine. Without that weight, it's gonna be really rough hitting those speed bumps at the mall...
    From the King GB thread...
    And if you were rubbing on the body mount at ride height, then cranked the coilovers 3" higher, you will still rub when you are turning and the suspension cycles. Like turning into a steep driveway. You should also check to see how much down travel you have. If your coilovers are fully extended at ride height from you adding 3 more inches of lift, it will ride terrible.
    Measure center of the hub to the fender at ride height, jack up the truck enough to get the tires off the ground, then measure again.
    kh7nm likes this.
  17. May 19, 2017 at 10:11 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    If you rubbing on your cab mount, maybe you should do the cab mount chop and start pounding on your fender walls
    Manwithoutaplan likes this.
  18. May 19, 2017 at 10:30 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Define "rides like shit" is it too bumpy or lumpy? Does it feel flighty on the road?
  19. May 21, 2017 at 12:08 PM
    Kinjo
    Kinjo
    SATX
    08 Tacoma DCSB 4x4
    bumpy ride as a result of gaining additional ride height from one inch of extra preload on 700lb springs.
    After contacting king, the springs i ordered normally have 18" springs installed for my application. Why 14" springs were mounted on the ones i ordered is an issue Im waiting for reply from king.
    As for the rubbing issue at cab mount while making turns, it was advised from total chaos to perform trimming when i installed heim uca. To be performed at a later date to correct the problem if it still exisits after the shock correction.
