Maintenance Service on 2021 Tacoma...this is what I was told today.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scsiguru, Jun 26, 2024.
  1. Jun 26, 2024 at 10:40 AM
    scsiguru
    scsiguru [OP] Well-Known Member
    I'm new to the area and found a shop to do some work on my truck. They get good reviews and look like a decent shop. I was just in for a special they were running: Full synthetic oil change, tire rotation/balance all for $80. Brought my truck in for this and then the service guy came out with a whole list of items for me to have done on my truck (see attached photo). I declined all of them until I had the time to research and look at the fluids/items myself. My truck has 48,000 miles on it and is not driven under off road or used for towing.
    I found this thread herehttps://www.tacomaworld.com/threads/3rd-gen-maintenance-intervals-simplified.766505/ which give a great summary of what is needed to be done and when. I can see possibly the power steering/brake fluid but even those look good.
    So I thought this guy was trying to upsell me for some pricey service. Even if I decided to do some of these things I'd shop around for another shop to do it. Some of the reviews of this place mention their service prices are on par with a dealership.
    I know a little about vehicle maintenance but wanted to get thoughts here if I'm looking at this correctly AND if those prices are high. Thanks!
  2. Jun 26, 2024 at 10:46 AM
    Old Man Tan 4x4
    Old Man Tan 4x4 Well-Known Member
    North East
    2017 TRDOR DCSB 4x4
    The only things I would consider on that list at your mileage are the diffs and transfer case fluid swap, but even those aren't really necessary at your mileage if you aren't hard on the truck. I have 106k on mine and have yet to do a brake or power steering fluid swap. Toyota recommends coolant at 100k which I did at 85k. Same with tranny fluid, did mine at 100k.
  3. Jun 26, 2024 at 10:56 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    You can do the diffs and transfer case yourself if you’re mechanical inclined. There are many tutorials online to guide you. I would use Redline LF in the transfer case.
  4. Jun 26, 2024 at 11:05 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    $1,200 damn
  5. Jun 26, 2024 at 11:10 AM
    mryan_884
    mryan_884 Well-Known Member
    Michael
    Camano Island, WA
    2017 Tacoma TRD OR
    The diffs/t case are super easy to do
    gsubioguy likes this.
  6. Jun 26, 2024 at 11:16 AM
    Big Cole
    Big Cole Well-Known Member
    Agree that only the front/rear differentials and transfer case may need service. Cost is under $200 plus a couple hours of your time. You don't have to be mechanically inclined just able to follow and execute basic procedures.
  7. Jun 26, 2024 at 12:17 PM
    scsiguru
    That's what I was thinking as well. I used to have a T100 and never recall doing this much maintenance at so few miles. Like I mentioned I'm not at all hard on this truck.
  8. Jun 26, 2024 at 12:19 PM
    scsiguru
    I use to do some mechanical things but getting too old for those now...plus I don't have the space to even work on this. I'm not going to do this now, but there are other shops in my local area and I can get pricing from them.
  9. Jun 26, 2024 at 12:19 PM
    scsiguru
    Yep...said the same thing but not in that word...LOL!!!
  10. Jun 26, 2024 at 12:22 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Understand that the point of an $80 service like you received is to find other things that may need servicing.
    They lost money on the initial work.
    gsubioguy, soundman98 and Chew like this.
  11. Jun 26, 2024 at 12:26 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    If you do any fluid drains FIRST be sure the fill plug is open.
    t0p_d0g and po35042 like this.
  12. Jun 26, 2024 at 12:27 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    The prices are reasonable. Check your manual to see what is recommended.
    soundman98 and RIX TUX like this.
  13. Jun 26, 2024 at 12:40 PM
    scsiguru
    Yes...I agree. I know a "bit" about maintenance on vehicles but feel bad for those that have all this done at the same time.
  14. Jun 26, 2024 at 1:01 PM
    IPNPULZ
    going to be fun!
    This past weekend I had the 4 Runner in for its Toyota care oil change and while waiting by the service desk. The service writer soaked this older lady driving a new Camry with less than 12K for $800 bucks AC deodorizer/brake fluid flush/intake cleaner/rotate balance/air and cabin filters/wiper blades/front end alignment and power steering fluid change. I told the lady when she goes to pay tell the service writer the front end alignment is under warranty.
  15. Jun 26, 2024 at 1:02 PM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    We Americans treat brake fluid as the OG "lifetime fluid", but in reality it should be changed every 2 years.
    Given your mileage, I would do the driveline fluids (Diffs, Transmission and Transfer) and power steering if you intend to keep the truck long-term.
    All of those should just be drain and fill. You can use a suction pump (think big syringe with a hose) and suck out most of the PS fluid from the reservoir and refill. No "flush" or "BG Service" needed.
    You have another 50k miles before I'd give the coolant any thought. Every 100k is fine with factory antifreeze.
    Yes, those prices are expensive. It's a dealership, and they're quoting you book for every job. Even though the truck will go on the lift once, that subtask is added to each task, for example.
    Bear in mind that I'm a maintenance nazi that re-torques lugnuts in the parking lot after the dealer rotates tires...
  16. Jun 26, 2024 at 1:04 PM
    scsiguru
    Thanks for this helpful information. This was not a dealership but a locally owned shop that also specialized in foreign vehicles like Toyota's.
  17. Jun 26, 2024 at 1:14 PM
    dneal
    MidMO
    24 TRD OR 6M
    Seems awfully pricey for an independent shop. I'd find a different one unless they have a reputation of being really good.
    Shops that specialize in "imports" are fine for the German stuff, because the engineers don't take mechanics into account and usually need lots of special tools. Toyotas are ubiquitous and simple to work on.
    Only caveats I would add is that there is a specific procedure for getting the right transmission level (for automatics), and I would only use the OEM fluid. Same goes for antifreeze. Otherwise, gear oil is gear oil and brake fluid is brake fluid (given that it's the correct weight/spec).
  18. Jun 26, 2024 at 3:48 PM
    scsiguru
    I agree...seems a bit steep. For those prices I'd rather go to the dealership. I did find a local FB group for my area and there are some recommendations for shops closer to me that seem reputable. When the time comes I'll approach one of them about changing the gear oil and brake fluid. As for the transmission fluid and antifreeze I think I'd rather have the dealership do those since they would use the correct procedure and fluids. With these sealed transmission cases I don't think I'd trust any mechanic.
  19. Jun 26, 2024 at 4:12 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Time and physical abilities are real reasons to pay someone to do something. However, it doesn't take space or mechanical abilities to do the diffs or transfer case. You just roll under the truck, drain, and fill. It just takes a socket set, a cheap transfer pump, and between 2 and 6 beers depending on who's doing it. It can be done in the garage or even a parking lot without moving the truck.
    My only advice is to wait for comfortable weather. You have plenty of time. Wait till fall, watch a few YouTube videos and you'll be fine.
    ndoldman59 likes this.
  20. Jun 26, 2024 at 4:22 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    i understand the shops pov.....some drivers like to have all this done.....
    but me: i only worry about stuff when it breaks
    scsiguru[OP] likes this.
