Maintenance Required Light won't reset
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueRidgeDog, Dec 20, 2021.
  1. Dec 20, 2021 at 9:32 AM
    BlueRidgeDog
    BlueRidgeDog [OP] Active Member
    James
    2013 Tacoma
    Just fishing in case there is any knowledge on this before I go to a dealer. My 2013 has the service light on that is just a dummy 5,000 mile (or 3,000) mile light. I "know" how to reset it (hold ODO or trip A while turning key from lock to on etc). My problem is it will not reset.
    My googling is stopped because there are thousands of results related to how to reset it, not what might cause it not to reset!
    Anyway, I am stumped. I am also OCD and like all my dash lights to be out!
  2. Dec 20, 2021 at 9:44 AM
    Longtech
    Longtech Well-Known Member
    Long
    SoCal
    15' OR converted 4WD
    Try to disconnect neg battery terminall. Reconnect and see if it will reset
  3. Dec 20, 2021 at 9:46 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Is it doing the ------ countdown?
    Dm93 and wi_taco like this.
  4. Dec 20, 2021 at 10:17 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You have to hold it until it stops blinking and the odometer reads all 0s.
    TRDSport10 likes this.
  5. Dec 20, 2021 at 10:18 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Owners manual, I forget what page
    Set trip a, then turn off, hold while turning on?
    fatfurious2 likes this.
  6. Dec 20, 2021 at 11:26 AM
    BlueRidgeDog
    James
    2013 Tacoma
    I have tried the normal thing. I don't get a countdown. Nothing happens.
  7. Dec 20, 2021 at 11:27 AM
    BlueRidgeDog
    James
    2013 Tacoma
    I will give it a try. That is logical and worked on a similar issue a long time ago on another car.
  8. Dec 20, 2021 at 11:34 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Turn ign on and set odometer to TRIP A.
    Press and hold reset button.
    While holding reset, turn ign off then back on.
    Continue to hold reset while odo does - - - - - countdown.
    Once countdown is complete, it will go to 000000 then to total mileage. You can release the reset at that point.
    Edit: trip A not total, my Googlefu failed me today.
    super_white, Knute and Dm93 like this.
  9. Dec 20, 2021 at 11:43 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think it's trip A on mine, it seems like it changed at some point but idk what the year break is.
  10. Dec 20, 2021 at 12:07 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP.....open the Owner's Manual for your truck. Verify you are executing the reset procedure correctly.
    I suspect you have something in the procedure not quite right.
  11. Dec 20, 2021 at 2:27 PM
    BlueRidgeDog
    James
    2013 Tacoma
    I was hopeful, but alas no go.
    For those suggesting trip etc...I "know" how to do it...the point is that it is not working. It never resets, never gives the countdown etc...just nothing.
  12. Dec 20, 2021 at 4:01 PM
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    Mine had to be on trip b
    nightcrawler likes this.
  13. Dec 20, 2021 at 4:40 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Just did mine a few minutes ago after another 5K oil change. I forgot the exact procedure and didn't bother to look it up. With the ignition key off, I pressed the odometer button, then turned the key on while holding the button down. It lit up and did the - - - - - countdown, then flashed to all zeros. I never selected trip A or trip B.
    OP, sorry you're having trouble with it and I hope you can get something to work. Black tape over the offending maintenance reminder is so tacky. Let us know if you get it fixed.
    cmoore likes this.
  14. Dec 20, 2021 at 5:18 PM
    BlueRidgeDog
    James
    2013 Tacoma
    Well, I have done the procedure on ODO/A/B and it remains, never the --------, never the zeros. I do have to take the dash out when it warms up to address a few other issues, and will remove the bulb at that point! I do want to get it working normally though as I am OCD about stuff like that.
  15. Dec 20, 2021 at 8:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Late 2011 when they changed from the Red Face Cluster to the White Faced Cluster.
  16. Dec 20, 2021 at 8:41 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    What is the exact procedure per your owners manual?
  17. Dec 21, 2021 at 3:12 AM
    BlueRidgeDog
    James
    2013 Tacoma
    I don't have the manual for the truck, so I have had to use the common procedure of pressing and holding the ODO button while putting the key from off/lock to on.
  18. Dec 21, 2021 at 4:11 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  19. Dec 21, 2021 at 4:57 AM
    BlueRidgeDog
    James
    2013 Tacoma
    Thanks for the copy from the manual. That is what I am doing...and the point of the post. It will not reset.
  20. Dec 21, 2021 at 5:18 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Just trying to help... Is the engine RUNNING when you switch to A? When I reset mine I don't think it is but that's what is listed above. Good luck.
