Maintenance Required Light staying on after oil change is done
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tony456, Apr 1, 2019.
  1. Apr 1, 2019 at 7:59 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    2007 black Tacoma Regular Cab
    Aside from needing to get an oil change, is there any other reason why this Maint Req'd light would go on?
    It dutifully started flashing after my truck went 4500 miles past its last oil change. However, after I got the oil change done and reset my mileage counter like how I always do, it still continued to flash (and now it's always on) during start-up. Is this just a faulty sensor or is this some other vehicular problem/maintenance need I'm just not aware of?
  2. Apr 1, 2019 at 8:01 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  3. Apr 1, 2019 at 8:04 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    Thank you. I'm gonna try it right now.
  4. Apr 1, 2019 at 9:24 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    Unfortunately, it didn't work. According to the instructions on the linked page, while depressing the reset button, the "odometer display should come up with a series of dashes that disappear one by one. When they've all disappeared, a series of zeros will display." I didn't see anything like that. The odometer reading on either Trip A or Trip B just continued to statically display the same number no matter how long I have the button depressed. Of course, I can hit the reset button again and that would make either Trip A or Trip B go to zero, but, as I mentioned in my post, that action isn't causing the Maint Reqd light to turn off like it should.
  5. Apr 1, 2019 at 9:31 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Norton, Steves104x4 and JerzRob like this.
  6. Apr 1, 2019 at 9:32 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    1. Place key to the ACC position.
    2. Set Trip Odo to A
    3. Place key to OFF position.
    4. Press and hold the Trip Odo button.
    5. While holding Trip Odo button, place key to ACC position.
    6. Continue holding the button until the zeros reset. Mainly light is now reset.
    Jojee117 likes this.
  7. Apr 1, 2019 at 9:45 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    You obviously didnt reset it.
    themanbearpig012 and Norton like this.
  8. Apr 1, 2019 at 10:05 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    Well, I hit the reset button in Trip A, and it went to 0.0. Is that not resetting the mileage counter?
  9. Apr 1, 2019 at 10:07 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Is this a troll? The answer is no, resetting the trip counter does not reset your light.
    Accipiter13, Norton and BillsSR5 like this.
  10. Apr 1, 2019 at 10:09 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Push until odo not trip A or B
    tony456[OP] likes this.
  11. Apr 1, 2019 at 10:11 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    What are you talking about? I never said that. I reset my trip counter to zero is what I said.
  12. Apr 1, 2019 at 10:22 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  13. Apr 1, 2019 at 10:25 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Gotta be on ODO, not trip.
  14. Apr 1, 2019 at 10:30 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Have to make sure your holding down the trip button BEFORE you turn on the ignition.
  15. Apr 1, 2019 at 10:31 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    Gunshot-6A and Steves104x4 like this.
  16. Apr 1, 2019 at 10:31 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Sweet
  17. Apr 1, 2019 at 10:31 AM
    tony456
    tony456 [OP] Member
    Tony
    Wichita Falls
    Yup! That's what it was.
  18. Apr 1, 2019 at 11:17 AM
    That one old guy
    Chuck
    Stockish
  19. Apr 1, 2019 at 12:54 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    You have no idea how many times I did it on ODO on my '11, and how pissed I was that it kept not working. Every Toyota I worked on was like that, and everything I was seeing said to do it that way.
    Then I finally stumbled on one freaking thread that mentioned they changed it for '11 to use Trip A instead. :homer: I love me some Toyota, but WTF.
  20. Apr 1, 2019 at 1:35 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    April fools!!
