Maintenance required light hasn't came on in over 6 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05TacomaGirl, Dec 3, 2021.
  1. Dec 3, 2021 at 3:42 PM
    05TacomaGirl
    05TacomaGirl [OP] Well-Known Member
    Tampa, FL
    2005 Toyota Tacoma prerunner V6 SR5
    Is there a fuse for the check engine/ maintenance required light it comes up on the dash? My maintenance required light hasn't came on in over 6 months. I have to keep up with my oil change with my trip A meter. If there is a fuse can somebody please tell me where it's at so I can check them.
  2. Dec 3, 2021 at 3:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You’re driving 5k in 6 months?
    Tacoma Mike likes this.
  3. Dec 3, 2021 at 3:54 PM
    05TacomaGirl
    Tampa, FL
    No what I'm saying is that the light hasn't came on in over 6 months.
  4. Dec 3, 2021 at 3:56 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I think it comes on every 5k miles
  5. Dec 3, 2021 at 4:02 PM
    05TacomaGirl
    Tampa, FL
    I know this but when I'm trying to tell you is it has not came on in 6 months. That's why I'm trying to find out if there is a fuse that may be blown out as to the reason why it has not come on in 6 months.
    604 likes this.
  6. Dec 3, 2021 at 4:04 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Maintenance required will blink at startup 4500 miles after it was last reset and be on solid 5000 miles after it was last reset, there is no dedicated fuse it goes by accumulated miles since it was reset.
    The check engine light will only come on with the engine off or while running when a problem is detected.
    Tacospike and TnShooter like this.
  7. Dec 3, 2021 at 4:09 PM
    Tacoma Mike
    Southern Maine
    It’s mileage based only.
    Not time.
    Change it every 6 months and forget the maint lamp. Just reset it when you do your oil change
    eherlihy, Tacospike and Steves104x4 like this.
  8. Dec 3, 2021 at 4:15 PM
    05TacomaGirl
    Tampa, FL
    I know all of this I was just asking was there a fuse for it. I know about the blinking I know about all of that. But it did not blink or do anything the last time I got the oil changed it did not come on at all but my trip A meter showed 5000 miles.
  9. Dec 3, 2021 at 4:20 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    No damn idea. Sorry
    Tacospike likes this.
  10. Dec 3, 2021 at 4:22 PM
    05TacomaGirl
    Tampa, FL
    I don't know eth
    Steves104x4 likes this.
  11. Dec 3, 2021 at 4:24 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    The led could be burnt out. There is not a fuse for that specific light. If the fuse was out the entire cluster would be too.
    Instead of using the trip computer just change it at 5k mile intervals based on the odometer (95,000 - 100,000 - 105,000 - 110,000 etc.)
  12. Dec 3, 2021 at 4:26 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    The maintenance required light also resets anytime you disconnect the battery so if you’ve unhooked it for any reason that effectively reset it back to zero miles.
    Tacospike and wilcam47 like this.
  13. Dec 3, 2021 at 4:26 PM
    Tacoma Mike
    Southern Maine
    If somebody reset it off time it would not come on. It has it’s own mileage counter. Nothing you can read or get to. Your trip meter has nothing to do with this.
    Does this help ?
  14. Dec 3, 2021 at 4:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Does it light up for a second when you first turn the key on? If it doesn't then the light bulb is not working, if it does then idk what's going on.
    TACO TX and tcjacado like this.
  15. Dec 3, 2021 at 4:29 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Don't think that's the case (at least not with my 2012). Last service I disconnected the batter to clean terminals and it was disconnected for a couple hours while I did other stuff. Still had to reset the service light when I hooked it back up.
  16. Dec 3, 2021 at 4:33 PM
    05TacomaGirl
    Tampa, FL
    Yes the light comes on when I put the key in the ignition but it just doesn't come on when it's time to get the oil changed. That's why when I reset it after I get the oil change I use the trip A meter to keep up with the miles that I drive in between oil changes
  17. Dec 3, 2021 at 4:36 PM
    plurpimpin
    PDX
    Weird. It I’m pretty sure it resets it on my 2010. I’ve been doing abunch of welding lately so disconnecting and reconnecting the battery. One time was right before a service based on my odometer and then I went another thousand miles without the light coming on when it should have.
    I’ve never done it with the light actually on. maybe once the light is on it stays on?
  18. Dec 3, 2021 at 4:37 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not sure then if your mileage is accurate there must be something wrong with the logic in the cluster.
  19. Dec 3, 2021 at 4:41 PM
    05TacomaGirl
    Tampa, FL
    As far as I know my battery hasn't been disconnected. Unless the Toyota dealership did it when they did my routine maintenance that's the only thing I can think of.
  20. Dec 3, 2021 at 4:44 PM
    Tacoma Mike
    Southern Maine
    OK.
    Then, I will make this suggestion.
    Get note book and at your next oil change write down the mileage and date and reset the lamp.
    Run it for 5000 and use the book as a reference.
    This will eliminate indicated trip mileage etc.
    Take everything out of the equation..
    Myself personally, I have not seen what your describing. I’ve had plenty say it didn’t come on.
    but, it did…..
    I have seen speedo issues cause inaccurate trip reading which would could interfere with maint lamp.
    You could in fact have and issue. Will need some detective work to eliminate things.
    Make sure your trip counts down the reset lines when you do the procedure.
    Let us know in 5000 miles..
    :thumbsup:
