Maintenance Before Cross Country Road Trip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kremtok, Jun 14, 2021.
  1. Jun 14, 2021 at 5:13 PM
    Kremtok
    Kremtok [OP] Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Good day folks,
    Next month we are moving from Alaska to Texas and the wife and I will be driving the Tacoma about 4700 miles to get where we are going. Movers are handling our stuff so we won't have a trailer or be overloaded for the trip.
    Right now the truck is at about 32k miles but it's spent most of the last year sitting in a heated garage on a battery tender. I did a fresh oil change right before parking it and other than seasonal tire change overs and putting a new battery in it a little over a year ago, we haven't had to do much to maintain it. Oh, except for the transmission; that was drained and refilled when it was about year old due to a timing cover leak.
    I'm half tempted to drain and refill every fluid in the truck and replace all of the filters I can think of before starting the drive, but I figured that might be overkill.
    What maintenance tasks would you all recommend before we start our road trip?
    Thanks for your time, folks.
    tacotoe likes this.
  2. Jun 14, 2021 at 5:17 PM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    How old is the battery? If less than 3 years, I'd gas and go.
    Do the maintenance after the trip - sounds like you've taken good care of the truck, so no worries.
  3. Jun 14, 2021 at 5:30 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Check fluids and tire pressure. Maybe check lug nut torque. Then send it.
    Chew, Mojlnir, hiPSI and 1 other person like this.
  4. Jun 14, 2021 at 5:30 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    I know you said that you did an oil change before storage. Most people recommend another change after a year of sitting idle. I would crank it up and run it a day or two. Then change it before and after the trip. Just my $0.02
  5. Jun 14, 2021 at 5:32 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Is it included in the fuel pump recall ?
    Kremtok[OP] likes this.
  6. Jun 14, 2021 at 5:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    Check the spare tire pressure and washer fluid level, verify all lights are working and enjoy your trip.
  7. Jun 14, 2021 at 5:36 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I've never heard that before. Usually change before storage and drive it or leave the oil and change it before you start to drive again. But certainly wouldn't hurt to change it.
    OP I'd make sure fluids are topped off and tires are good and start driving.
  8. Jun 14, 2021 at 5:38 PM
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    I wouldn't drain all the fluids, but I would change the air filter, cabin air filter, do another oil change and rotate the tires.
  9. Jun 14, 2021 at 5:57 PM
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    Is it going back into storage once you get to Texas?
    If the oil is a year old and you're looking to do half a change interval worth of driving, I'd get the oil changed before you go.
    If it's going to be used for more than the move, see what was done and what wasn't for the 30k service.
  10. Jun 14, 2021 at 5:59 PM
    Shellshock
    Iowa
    Put gas in it and go. You’ll be totally fine. I’ve dont many trips of that distance or longer with no prep. I was doing 1000+ miles weekly for a long time for work.
  11. Jun 14, 2021 at 6:01 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Oil change is never a bad idea, and tire pressures. But I'd just drive it otherwise, certainly not doing a whole host of things. I would ultimately look in the manual and see what the 30K service says and make sure I was up to date on it.
    Kremtok[OP] and Mojlnir like this.
  12. Jun 14, 2021 at 6:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I drove from South Carolina to Las Vegas and back. Around 5K miles. I checked air pressure in tires and filled up the washer fluid. I glanced at radiator reservoir and brake reservoir and filled her with gas. 40K miles. Didn't even check oil as it does not use any.
    Edit: most say send it as it's no big deal. I agree.
  13. Jun 14, 2021 at 6:12 PM
    Justin3196
    Justin3196 Member
    2004 SR5 Tacoma
    Stock
    I wouldn’t change the oil before the trip , if you changed it before you parked it it’s fine. Check all the fluids , tire pressure , top off what’s low and go. Change it when you get there.
    shotgunbilly420 and Kremtok[OP] like this.
  14. Jun 14, 2021 at 6:14 PM
    PhenixFord
    Randy
    Arkansas
    Read enough and you will see anything. Then you have to figure out what you believe.
    Theory is that the oil is still leaching chemicals from the metals. Kinda makes sense to me. :notsure:
  15. Jun 14, 2021 at 6:16 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Do not do any large service before you road trip. Something will go wrong, a part will be back ordered, or something will break during or right after the service.
    I worked in a dealership for 6 years, so many people come in the day before their big trip to get something big done only to have to cancel their trip due to a part needing to be ordered, or a tech screwing something up. So many people show up for a service they needed to have done 3 months ago only to not be able to get the service due to lack of time.
    It sounds like your truck is in good shape, and you should be fine just filling it up and driving. Just make sure your spare tire is good, and you'll be fine.
  16. Jun 14, 2021 at 7:00 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I like what he said. I always do big services in advanced that way everything is settled. I dd my truck so anytime I do a big trip make sure the engine q oil is fresh. Cheap insurance. If battery has been on tender it should be fine. Air pressure in tires make sure are proper.
    5nahalf[QUOTED] and Kremtok[OP] like this.
  17. Jun 14, 2021 at 7:58 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Grab nice new small battery jump pack(MUST have for me anyways) and head South! You're over thinking this.
    Kremtok[OP] and Kev250R like this.
  18. Jun 14, 2021 at 8:04 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I’ve done 9 cross country trips and one trip from Alaska to CA. Don’t over think it. Oil change, diff and transfer case oils since you’re at 30k and call it good.
    The trip fro Alaska to CA and from CA to VA as my first cross country trip was in a 93 4Runner with known head gasket issues and the 3.0slow motor and had no issues.
    Chew, Kremtok[OP], Kev250R and 2 others like this.
  19. Jun 14, 2021 at 8:16 PM
    5nahalf
    Erik
    Minnesota
    Pretty brave to take 3vze more than a few blocks from home.
  20. Jun 14, 2021 at 8:29 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    And I did 6800 miles with it across the ALCAN and highway 50 across Nevada.
