Maintenance and longevity on this lift kit.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amanhowzit taco, Sep 8, 2020.
  1. Sep 8, 2020 at 1:22 PM
    Amanhowzit taco
    Amanhowzit taco [OP] Well-Known Member
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    265/75/16 tires only everything else stock.
    https://accutuneoffroad.com/product/05-tacoma-mid-travel-suspension-kit-stage-4a-king/
    Will this 6-7 thousand dollar set up stand the test of time?
    (this price is with shipping cost estimate)
    If I'm going to drop this amount of money on improving my truck for future adventures and hauling I want to make sure I'm getting my money worth.
    What is the maintenance required for a setup like this?
    I use my suspension like its supposed to be used.
    I am already bottoming out on my stock suspension with no load in the back on bumps. With only skids and sliders installed. Truck almost has 45,000 miles.
    ALOHA!
  2. Sep 8, 2020 at 1:34 PM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    Everything breaks down in time and requires maintenance. A Ferrari requires more maintenance than a civic. Just because it’s 7k doesn’t mean it’s going to last longer than 600 bilstein.
  3. Sep 8, 2020 at 1:42 PM
    beriman10
    beriman10 Well-Known Member
    Omar
    Orange County
    2019 Jeep Wrangler Unlimited Rubicon
    Fox 2.5 Suspension 2 in Lift
    Yes, shocks will need to be serviced every 15k give or take depending on how hard you offroad. (changing seals, fluid, and nitrogen).
    Upper control arms will the uniballs replaced every 30k normally but depends on off road use as well.
    The benefit to those kits is that as long as you maintain them, you will never have to replace the shocks as they tend to last quite some time.
    If your looking for low maintenance, Bilstein and old man emu sell sealed units that do no require servicing but will eventually need replacing at a certain point
    Amanhowzit taco[OP] and su.b.rat like this.
  4. Sep 8, 2020 at 1:44 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I’ll just replace my Bilsteins every few Years for that price IMO. GOOD luck OP
  5. Sep 8, 2020 at 1:55 PM
    eurowner
    eurowner Duke Sky
    Scoty
  6. Sep 8, 2020 at 2:18 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    OP maintenance is what it comes down to
    Are you needing the kit or wanting the kit ? 30k a year HWY probably don't need the kit
    Crushing offroad trails multiple times a month, or more?
    Edit: that being said it is a complete kit and wouldn't hesitate to get them from accutune or down south motorsports
  7. Sep 8, 2020 at 6:20 PM
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    A little bit of both. I can keep pushing my
    Stock suspension to the end. While at the same time I will definitely use a kit like this. I am loaded full a lot with supplies for work and adventure. Weight handling is my biggest issue. Mahalo for the reply
    Dirk Diggler[QUOTED] likes this.
  8. Sep 8, 2020 at 6:22 PM
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    I didn’t realize maintenance is this often. I put 15 k a year on the truck give or take. That will be changing with more adventures. Thanks for the info.
  9. Sep 8, 2020 at 6:26 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I hear ya ive been putting off an upgrade for suspension for too long. Also it completely depends on what you're doing for rebuilds. Ive heard very commonly 30k is good unless it is a dedicated trail rig.
    I'd reach out to those 3 companies mentioned and talk to them about what you do. They can valve it for your custom setup ect and can help find a local (if you can't find yourself or ship to them) the shocks at X interval and see what they look like for a rebuild and help you decide on intervals
  10. Sep 8, 2020 at 6:27 PM
    FirsTaco
    FirsTaco Well-Known Member
    Jeff
    Reading, MA
    '22 Ford Bronco Badlands
    From what you say you might want to look at airbags instead of 8k suspension. If it is only weight that is the biggest concern.
