Magnetic Drain Plugs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Feb 5, 2022.
  1. Feb 5, 2022 at 5:44 AM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I was thinking, why could I not simply take an appropriate size Neodymium magnet and place it directly on the plugs internal end? The magnetic force should hold it there solidly. I ask because I’m puzzled why we would need to purchase one that already has a magnet installed.
    The Neodymium magnets are stronger and I was thinking I could maximize the size I could locate on the end of the plug to provide the largest surface area and pulling force. I don’t think we would need to bond the magnet to the plug or recess install it either. Am I missing something?
    I suspect the size that would fit would provide approximately 10-15 lbs of pulling force ensuring anything in the differentials would wind up on the magnet.
    https://www.kjmagnetics.com/products.asp?cat=1
  2. Feb 5, 2022 at 7:10 AM
    Bronxguy
    Bronxguy Well-Known Member
    Frank
    New York
    2021 Off Road
    I'd would be a little nervous about not having the magnet bonded to the bolt due to on/off road vibrations over the course of time between fluid changes, that's just me.
    Key-Rei likes this.
  3. Feb 5, 2022 at 7:29 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Wouldn't bother me any.
    I'd imagine if you hit something so hard as to jar the magnet loose, you'd be looking for a new truck and not the magnet.
  4. Feb 5, 2022 at 7:31 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just stick it to the bottom of the pan.
  5. Feb 5, 2022 at 7:35 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Yep, I would guess it to be virtually impossible to get a 10+ LB pull strength Neodymium magnet to move from the end of that drain plug. I’ll do this and report back. I’m going to go to Toyota today to purchase two new front and rear differential drain plugs. I’ll then measure the diameter at the end of each plug so I can order the magnets.
    JJ Diablo likes this.
  6. Feb 5, 2022 at 7:42 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  7. Feb 5, 2022 at 8:09 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    I’m doing this for the differentials. I use a Fumoto for the oil.
  8. Feb 5, 2022 at 8:42 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  9. Feb 5, 2022 at 8:45 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    aren't those drain plugs for diffs already magnetized from factory?
  10. Feb 5, 2022 at 9:30 AM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Would the magnet want to stick to the pan as you are installing it ? Then upon removal it could grab the pan and come away from the plug. How would you remove it at that point. Maybe add some oil resistant epoxy if there is such a material.
    GreenTaco22 likes this.
  11. Feb 5, 2022 at 10:08 AM
    indoomitable
    indoomitable Baby-steppin' down the stairs
    Texas
    2018 OR 4x4 DCSB
    Thats what I thought too. Im changing front and rear diff fluid soon and got these just so I could change out the socket head bolts on the front diff. I read somewhere online that these will fit but dont have first hand knowledge yet.
    Fill - Toyota part# 9034118060
    Drain - Lexus part# 90341-24016
  12. Feb 5, 2022 at 10:44 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Good point
  13. Feb 5, 2022 at 10:45 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Yes. I was thinking of supercharging them with Neodymium’s.
  14. Feb 5, 2022 at 2:48 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    7DBA07A7-B975-43E8-9607-B31947F5FB6E.jpg After perusing this site for information I’m going to swap out the standard plugs with the Toyota derivative with a larger magnet.
    stock
    90431-18021 front differential drain plug with small magnet/10mm hex
    90431-18057 rear differential drain plug with small magnet/24mm socket
    alternative
    90431-18035 front differential drain plug with large magnet/10mm hex
    90431-18044 rear differential drain plug with large magnet/24mm socket
  15. Feb 5, 2022 at 2:51 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    If it ain’t broke don’t fix it.
    Dbarffish likes this.
  16. Feb 5, 2022 at 2:52 PM
    malatx
    this looks pretty long, you sure it won't protrude inside too much and collide with gears and other moving parts?
  17. Feb 5, 2022 at 2:53 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    I will be able to tell when I install. Between the plug itself and a gauge I’m confident in being able to determine acceptability.
  18. Feb 5, 2022 at 2:59 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It's got a bonded magnet and it's low profile.
  19. Feb 5, 2022 at 3:01 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    This is just one of many reasons why a Land Cruiser costs what it does. I hear you and I hear many others who ask why do I think I’m smarter than a Toyota engineer. I’m not, just take a look at what components are installed on the Land Cruiser by Toyota engineers and you will find higher quality components. It’s FREE to look and inquire.
    Key-Rei likes this.
  20. Feb 5, 2022 at 3:02 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Yep, just as indicated in post #14. Thanks!
    Key-Rei[QUOTED] likes this.
