Magnaflow 18" or 14"
Discussion in '1st Gen. Tacomas (1995-2004)' started by HSmith_11, Aug 28, 2017.
  1. Aug 28, 2017 at 3:03 PM
    HSmith_11
    HSmith_11 [OP] Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I'm looking to get a nice sounding exhaust for my 2001 4 cylinder. I've heard good things about the magnaflows but I've seen both the 11225 (14") and 11255 (18"). Whats the difference? I want it to be quite loud outside the truck but not too much drone when going ~60mph.
  2. Aug 28, 2017 at 3:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The main difference will be how loud it is.
    I run the 18" and like it a lot. No drone, not too loud but can definitely hear it when I get on it.
    In general, 24" if you want quite, like stock. 18" I you want to hear it. And 14" if you want the whole neighborhood to know you are back.
  3. Aug 28, 2017 at 3:25 PM
    HSmith_11
    Hunter
    Madison, Va
    Do you have any sound clips of your 18"?
  4. Aug 28, 2017 at 3:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
  5. Aug 28, 2017 at 4:07 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Are you looking at chambered (traditional style) or the straight through design (more like a glasspack)?
    I've been thinking about going with a straight through style one since my truck is no longer my DD but it will be LOUD
  6. Aug 28, 2017 at 4:09 PM
    Wulf
    rock raisin
    Here is a clip of the 18" straight through Magnaflow (start up, revs, driving from outside the truck) starting at 5:48
    Kittenmittens4U likes this.
  7. Aug 28, 2017 at 4:14 PM
    Wulf
    rock raisin
    and here's a clip of the 14" (I think) it is louder and not as deep
  8. Aug 28, 2017 at 4:36 PM
    HSmith_11
    Hunter
    Madison, Va
    Whats the difference between the chambered bad straight through designs?
  9. Aug 29, 2017 at 10:02 AM
    Wulf
    rock raisin
    Straight through is a single perforated tube that goes straight through the center of the muffler. It has a larger case and the combination of the case chamber, perforations, and fiberglass packing provide noise reduction without altering the engine's sound too much. It won't be nearly as loud as a straight pip but will probably have some of the characteristics.
    The chambered muffler uses a bunch of baffles inside the muffler case that deflect sound waves into each other and provide a greater noise reduction and deeper sound.
  10. Aug 29, 2017 at 10:11 AM
    HSmith_11
    Hunter
    Madison, Va
    You explained it really well. I guess I'm going with a chambered cause that's what the 11255 model is right? With the offset in and out.
  11. Aug 29, 2017 at 11:39 AM
    Wulf
    rock raisin
    it looks like the 11255 is actually a straight through style as well. It probably has an s-shaped pipe going through the center. I'm sure that it will sound great, though!
    https://www.magnaflow.com/products?partNumber=11255
  12. Aug 29, 2017 at 2:16 PM
    HSmith_11
    Hunter
    Madison, Va
    Ah I noticed that a hour or so ago while I was on their website. I'll still probably go with that one mainly because of the great reviews
  13. Aug 29, 2017 at 4:18 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    not a chambered muffler in vid.
  14. Aug 29, 2017 at 4:36 PM
    Wulf
    rock raisin
    yeah should have edited my post, it's actually straight through
  15. Aug 29, 2017 at 5:52 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Magnaflows are straight through over priced glasspacks, basically no difference from a cherry bomb other than size and looks. Longer equals quieter. Chambered refers to the flowmaster style of mufflers, where they have no packing, just different chambers and baffles to cancel out the sound. Personally I prefer the flowmaster style because they actually change the exhaust tone. I have an imco(basically a 40 series flowmaster) on my 97 2.7 and it sounds about as good as a 4 banger can. I've never been a fan of the glass pack sound.
  16. Aug 29, 2017 at 9:50 PM
    Wulf
    rock raisin
    Eh, I wouldn't say that's entirely true since they use the case size and steel packing as well to change the sound. I've had a traditional style glasspack on a previous Toyota truck and it didn't sound anything like the Magnaflows in this thread.
  17. Aug 30, 2017 at 6:09 AM
    devinzz1
    devin
    2023 aclb trd or mt
    s
    same principle but theres so little packing and its so loose its alot less effective. they usually just ise fiberglass strands that start burning out like immediately. others like borla and magnaflow use stainless steel and ceramic packing. the extra cost comes comes with longevity.
    my favourite muffler for these trucks is the fm44. sound is personal preference tho so idk why ppl ask others what they want.
  18. Aug 30, 2017 at 9:44 AM
    Wulf
    rock raisin
    Validation :D :crapstorm:
    In this case it seems like it's a question of getting the right volume, OP already wants the Magnaflow sound.
  19. Aug 30, 2017 at 10:14 AM
    HSmith_11
    Hunter
    Madison, Va
    I basically don't want an exhaust that isn't constantly loud enough to be annoying I can make it annoyingly loud of I want to by giving it some extra gas. :D
  20. Aug 30, 2017 at 10:36 AM
    Wulf
    rock raisin
    totally valid :D
    I bet you'll be very content with one of the longer Magnaflows
