Machining flywheel without replacing clutch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMitch93, Nov 23, 2015.
  1. Nov 23, 2015 at 4:10 PM
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    My 09 2.7 AC Tacoma has hotspots in the flywheel. Take offs in low shake the shit out of the truck.
    The truck has a LCE clutch in it.
    I have to replace the throw bearing in the near future, but I don't have the cash for a whole new clutch kit (I really like the LCE clutch and by the time they get to Canada they cost retarded amounts of money). Since I'm going to have the transmission out anyway, would machining my flywheel provide any sort of benefit?
    I honestly can't see how it would hurt anything, but I'm wondering if it would be worth it or help with the problem at all.
    And before anyone starts hating on my ability to drive standard, crawling is hard in a standard and requires lots of clutch. Automatic is the easy way out and I'm not about that life.
  2. Nov 23, 2015 at 4:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Personally I wouldn't pull it out without replacing the whole clutch pressure plate and throw out bearing. When you get the flywheel turned due to hot spots you may find out you need a new flywheel.
    Not trying to piss on your parade, but you need to be prepared for the worst...
    DoorDing and BUZZCUT like this.
  3. Nov 23, 2015 at 5:06 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    No parade here. I asked for thoughts and opinions from people who may have more experience than me and that's exactly what you gave me!
    However, I really only notice the hot spots in low, it gets shaky on some hills and such but its far more manageable in 2wd.
    I have a throw bearing and I figured I would toss it in before it explodes and do the whole clutch in the new year. An R&R on the tranny would only take 5 or 6 hours and that's far better than having the throw bearing grenade and ruin more than just the clutch, plus then the truck is down for more than 5 or 6 hours while I'm sourcing parts.
    I was wondering whether it would be worth it or not to machine the flywheel while its apart.
  4. Nov 23, 2015 at 5:09 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If the flywheel has hot spots, yes it would be worth the effort. If you are doing the work and don't mind the labor and time sure go for it.
    TacoMitch93[OP] likes this.
  5. Nov 23, 2015 at 6:09 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Thanks for the input! Probably won't hurt to at least peak at the flywheel.
  6. Nov 23, 2015 at 7:33 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If the pressure plate also has hot spots, then you're not going to gain much, if anything. On the other hand, if that clutch was installed without resufacing the flywheel, resurfacing the flywheel now might just fix you right up. I've resurfaced a flywheel and reinstalled a used clutch in the past with no ill effects, not ideal, but it can work.
  7. Nov 23, 2015 at 7:36 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I didn't machine the flywheel when I put that clutch in because it didn't slip a whole bunch and it was the pressure plate that fucked up on me.
    I imagine everything in there has over heated. It's only recently gotten bad. I've got somewhere close to 40km on it now.
  8. Dec 10, 2015 at 4:31 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Replace all they all work like a smooth Japanese watch.swiss watch witch ever.all work like your engine rebuild it but reuse the bearings.Yes it is expensive but once and done. Sorry my 2 cents.
  9. Dec 10, 2015 at 7:04 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I didn't machine anything. Just replaced the TOB. The flywheel only had a few hot spots. Scuffed and cleaned the pressure plate and the flywheel and bam back together and working fine.
    I think my clutch gets jumpy because it gets wet. I'm missing the inspection plate.
