Luk oem flywheel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TULLAJ79, Apr 9, 2021.
  1. Apr 9, 2021 at 9:27 AM
    TULLAJ79
    TULLAJ79 [OP] Member
    Ashton
    2005 Black Tacoma 4.0 6-speed manual 4x4 base
    I’m replacing my clutch debating on going with a new flywheel too
  2. Apr 9, 2021 at 9:38 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Unless it has broken teeth, you might just get it resurfaced at a machine shop. It's been a long time, but have paid $30 for a resurface in the past. Always a good thing to do when replacing a clutch, but not always necessary if the mating surface isn't glazed or gouged. With cheap parts available, seems I've had more trouble finding machine shops that will do resurfaces and end up just replacing. I just looked up that Luk at RockAuto, it is pretty cheap!
    Not sure if they still do, but they used to use red Loctite on the bolts, so they can be a pain to bust loose (and you need some to put it back on). Also, while you are in there, do your rear main crankshaft seal.
    Key-Rei and whatstcp like this.
  3. Apr 9, 2021 at 12:41 PM
    TULLAJ79
    Ashton
    Planning on going with this
    Superdave1.0 likes this.
  4. Apr 9, 2021 at 12:47 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Hate to say it that’s scary, $330 for the flywheel, clutch plate, pressure plate, throw bearing. If it’s the original clutch parts your replacing, I’m betting these don’t last 15 years.
    Key-Rei and Too Stroked like this.
  5. Apr 9, 2021 at 12:48 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Looks like a good kit, just add a rear main seal!
  6. Apr 9, 2021 at 12:52 PM
    gotoman1969
    Yes don’t forget this.
  7. Apr 9, 2021 at 12:52 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've had good luck (no pun intended) with LUK clutch parts. Honda cars specifically. Oem style, lasted forever.
    Jeffch likes this.
  8. Apr 9, 2021 at 12:59 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Checked the RockAuto prices for the same parts, they are about the same -- that is likely the best clutch kit they sell. I'd go Aisin myself if I was doing a clutch.
    Jeffch likes this.
  9. Apr 9, 2021 at 1:31 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Used Asian parts on my 08 had 170k on the original Asian so why not it still had plenty of life left!
    Did clutch while doing rear main.
    Did fork bearing plates and rear main!
    Had 196k and was totaled but the clutch was good!
    Flywheel was resurfaced!!
  10. Apr 9, 2021 at 10:05 PM
    TacoTuesday1
    FL
    well
    upon removal mine looked new
    so I scuffed it up and re-used it.
    but according to this guy, what you need to do is:
    take your flywheel to a machine shop during weekday working hours
    somehow leave your vehicle torn apart during that time while waiting for them to cut and grind metal off of the flywheel
    and then slap that flywheel back in, probably causing problems, because nobody mentioned at all the existence of "shims" to be used to compensate for material removed thickness
    let alone what shims, where to get them, or how to use them
    LuK is not OEM
    Aisin is
    people don't buy Aisin because it's $800 for a metal disc
    and most people are not lottery winners
    Those are normal prices on most cars
    therefore what you would expect from the brand reputation "Toyota"
    Also, the factory throwout bearing design as well as the cast-in "sleeve" it rides upon, is retarded
    so taking out some shitty parts
    to slap in some new shitty parts (an OE design throwout bearing system)
    would also be retarded
    but at the end of the day, choice is up to OP
    the flywheel will probably be in decent shape
    unless the previous truck owner drove it like an idiot
    aka doing things like clutch in at red light, excessive slippage to "impress the homies by how smooth you shift stick", etc.
  11. Apr 10, 2021 at 6:05 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You don't need shims. It's a minor amount of material and the hydraulic system compensates, just like it compensates for the friction plate wearing down over time.
  12. Apr 10, 2021 at 8:31 AM
    TacoTuesday1
    FL
    the hydraulic system is not adaptive
    some vehicles use an SAC for this reason
    the Tacoma, being a simple vehicle that uses cheap parts, does not have an SAC
  13. Apr 13, 2021 at 1:40 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    LuK and Aisin are both OEM for the Tacoma. An LuK flywheel with an Aisin clutch kit is a low cost way to put a factory setup into the truck.
    While not an SAC setup like you have pictured, the hydraulic system in the Tacoma absolutely compensates for slight variations in height of the spring fingers.
    Jeff
  14. Apr 13, 2021 at 1:53 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Who pissed in your Cheerios?
  15. Jul 18, 2021 at 10:49 AM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    What site did find this combo on? It’s a few dollars more separately on rock auto
