Lugnuts for Toyota OEM wheels ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3X4X4, Sep 22, 2018.
  1. Sep 22, 2018 at 8:57 AM
    3X4X4
    3X4X4 [OP] Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    What lugnuts are needed for a TRD O/R with the OEM wheels. Mine are ruined it seems due to overzealous mechanics and no longer fit my wrench.
    So I order a McGard set that claimed to fit Tacoma and I get this:
    Does not look compatible to me?
    Do Toyota wheels require special lugnuts?
  2. Sep 22, 2018 at 9:15 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Any autozone will have the OEM lugs in stock. I had rounded one on accident and had to replace it.
    Those ones you ordered don’t look like they will work.
  3. Sep 22, 2018 at 9:20 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They’re not special, they just need shoulders for OEM wheels (like the OEM nut in your pic).
    Fits Tacoma just means they’ll thread on correctly to the wheel stud. Different wheels use different types of lug nuts, most aftermarket wheels use the bottom type of nut.
    You can find colored replacements for OEM wheels if you want that type of thing, just make sure they’re the correct type.
  4. Sep 22, 2018 at 9:43 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I got a few replacements for my Corolla at O'Reilly. They are similar and they have a pretty good variety. Just take an old one with you.
    Some of the old ones have a thin steel wrap on the head. When the nut rusts underneath it, the casing swells up making it difficult to get the correct socket to work. I've had to replace a few on my wife's van too.
  5. Sep 22, 2018 at 10:39 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    tacoma2g, Biscuits and bullaculla like this.
  6. Sep 22, 2018 at 1:31 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    How many do you need. I think I have some around somewhere I can send you if you cover shipping.
    Biscuits likes this.
  7. Sep 22, 2018 at 1:41 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    The top one is a shank style lug nut for Toyota alloy wheels. The bottom is an acorn cone seat lug nut that is pretty generic for steel wheels. If you have OEM alloy wheels you need the top one for sure and they aren't cheap if get them from the dealer. There are aftermarket ones like mentioned, though.
    You notice the OEM shanks have a taper at the bottom so they work with steel spare wheels but on OEM alloy wheels shouldered shank part is what is actually centering and holding the wheel.
    I'm not sure McGard makes OEM style shank lug nut for Toyota. AFAIK you could use those McGard lug nuts on OEM steel wheels, though.
    TheDevilYouLove likes this.
  8. Sep 22, 2018 at 5:27 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I have a whole set from a 2010 sport wheels . If you need some
  9. Sep 22, 2018 at 5:50 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Stryker420 likes this.
  10. Sep 22, 2018 at 8:01 PM
    3X4X4
    JR
    KS
    Thanks guys, appreciated. I guess I forgot that OEM wheels use those weird lug nuts.
  11. Jan 29, 2019 at 10:02 AM
    usadaytrader
    usadaytrader Well-Known Member
    Mines a 5 lug. Went with Genuine Toyota lugs for $2.75 a pop-$55 OTD. The Gorillas are $19 for 4 lugs. They ended up being $95.
    When the OEMs wear out, I'll just replace them again if I keep the vehicle that long.
