Lug wrench
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zooyorkajd, Oct 18, 2021.
  1. Oct 18, 2021 at 4:10 PM
    zooyorkajd
    zooyorkajd [OP] Well-Known Member
    Looking to upgrade from the crappy lug wrench the truck came with. I was thinking a torque wrench with a long socket but thats an expensive investment. Is it worth it to get exact torque numbers?
    Edit: Torque wrenches are a lot cheaper than I thought! What brand torque wrench do you have?
    boston23 likes this.
  2. Oct 18, 2021 at 4:27 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are you wanting something for emergency use or doing your own rotation?
    Either way, I use a Milwaukee impact with impact sockets for removal and a torque wrench to tighten.
  3. Oct 18, 2021 at 4:32 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    If you are in Canada then a Mastercraft Torque wrench on sale would fit the bill. I have compared one to a Snap On and a Norbar Torque wrench that I have and the Mastercraft was pretty accurate.
    And breaking free hardware with a torque wrench can ruin the accuracy.
  4. Oct 18, 2021 at 4:47 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Gearwrench & Husky torque wrench will run you about $80-100
    You will also need a breaker bar and applicable socket (mine is a 21mm). I carry impact sockets because occasionally I need to use a 3 lb hammer.
    ConantTaco likes this.
  5. Oct 18, 2021 at 4:49 PM
    zooyorkajd
    Which brand torque wrench?
  6. Oct 18, 2021 at 4:50 PM
    zooyorkajd
    So it’s better to get one of these rather than the ones on Amazon for half the price?
  7. Oct 18, 2021 at 4:58 PM
    splitbolt
    NW Arkansas
    Klein
  8. Oct 18, 2021 at 5:00 PM
    rnish
    Tacoma 2nd gen
    For just lug nuts probably ok. If you get into torquing pan drain plugs or bolts in aluminum castings. I spent the extra $. Also if you get into it, you will end up with 2 or 3 torque wrench’s. I bought another torque wrench (last year) because I needed to do 173 foot lb on a axle nut.
    Edit: If you go budget (~$25) I recommend a flex/strain gauge type.
  9. Oct 18, 2021 at 5:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    You do know (as other suggest) that breaking things loose with a torque wrench is a no-no, right?
    If you cant break lugs loose with the OE wrench, carry a breaker bar and socket.
    Leave the torque wrench at home for adjustments after you return.
  10. Oct 18, 2021 at 5:11 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Proto for the big stuff. Pittsburgh for the little things. But I agree with @Clearwater Bill. Torque wrenches need to be stored properly and the cases are large. Breaker in truck. Torque at home. 20211018_170751.jpg
  11. Oct 18, 2021 at 5:11 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I'm walking talking evidence that cheap torque wrenches have done more damage to the world than they've prevented.
    When buying a 'precision instrument' it's been my experience, unsurprisingly, that more often than not you get what you pay for.
    JoeCOVA likes this.
  12. Oct 18, 2021 at 5:18 PM
    zooyorkajd
    Any breaker bar would do, obviously 1/2 right? The plan is to keep in the the truck to replace the OEM. Do you happen to know the socket size off the top of your head?
  13. Oct 18, 2021 at 5:31 PM
    splitbolt
    NW Arkansas
    21mm.
    It's not a bad idea to get a 21.5mm too, in case your nuts are swollen.:eek:
    tacotroy17 and Speedfreak like this.
  14. Oct 18, 2021 at 5:31 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Tekton torque wrenches from Amazon are good.
    hfjeff likes this.
  15. Oct 18, 2021 at 5:33 PM
    Stocklocker
    17TRDORDCSBAT
  16. Oct 18, 2021 at 5:36 PM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    I have harbor freight's ft-lbs torque wrench to torque my lug nuts.
    It is accurate throughout my usage, since I'm able to verify torque at my work's torque metering tool. So I'm not discouraged about harbor freight torque wrench.
  17. Oct 18, 2021 at 5:38 PM
    jmneill
    SE
    Maybe they've improved, or maybe it's the luck of the draw when you're buying budget friendly torque tools, IDK. But with that said, the only Tekton I ever owned was off by more than 50% out of the box. Stripped the spark plugs threads out of an $1,700 aluminum WaveRunner head with it. That Tekton was the turning point for me with budget Torque wrenches.
  18. Oct 18, 2021 at 5:39 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Just remember, you need the factory lug wrench to lower the spare anyhow, so now your going to have 2 lug wrenches that will get used 1-2 times every 5 years.
    Gunshot-6A likes this.
  19. Oct 18, 2021 at 5:45 PM
    Stocklocker
    17TRDORDCSBAT
    Interesting. I have a very high quality Armstrong Torque wrench as well. I’ll have to compare the two.
  20. Oct 18, 2021 at 5:50 PM
    splitbolt
    NW Arkansas
    Yeah...try to find one with an NIST cerification.
    Greg.Brakes.Tacos and jmneill like this.
