Lug nuts
Discussion in 'Wheels & Tires' started by Gallo88, Aug 3, 2017.
  1. Aug 3, 2017 at 10:24 PM
    Gallo88
    Gallo88 [OP] Member
    Felipe
    2015 MGM PreRunner 2.7L
    I was wondering if anyone has used none spline lug nuts on scs Ray 10 wheels? Regular acorn type specifically.
  2. Aug 3, 2017 at 10:27 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    If you want to smash up the finish of the lug seat then go for it. I would just get some ET spline lugs for them so you don't scar up the wheel they are to beautiful to treat em that way
    Gallo88[OP] likes this.
  3. Aug 3, 2017 at 10:45 PM
    Gallo88
    Gallo88 [OP] Member
    Felipe
    Thanks for the reply. I have spline lugs at the moment. Two of them broke, hence why I'm looking at other options. Rather not have to drill out my wheel studs again lol
  4. Aug 3, 2017 at 10:54 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Yeah that sucks. Did you use a impact gun on them? That's known to brake them. 100ft lbs is all they need to be tight
  5. Aug 3, 2017 at 11:01 PM
    Gallo88
    Gallo88 [OP] Member
    Felipe
    No impact gun. Was actually loosening them, all I wanted was to rotate my tires :eek:
  6. Aug 10, 2017 at 4:38 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Use ET spline lugs with our wheels. The lug bore is narrow so using spline lugs will prevent unnecessary damages. We should have them back in stock in about 1wk.
    The Tacoma lugs only need to torqued down to 85-86ft lbs. Over torquing them will weaken the studs and stretch them. This can lead to them just snapping/breaking right off.
  7. Aug 10, 2017 at 6:57 PM
    Gallo88
    Gallo88 [OP] Member
    Felipe
    Thanks Vin for the reply. I actually just purchased some Gorilla ET spline lugs and I did torque them down to Toyota's specifications. I was hoping to purchase them from you, but I noticed you were out of stock and wanted to get the old lugs switched out quick.
  8. Aug 10, 2017 at 9:25 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    :thumbsup: The Gorilla lugs will serve you well!
