Lug nut torque range
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco_6112, Jun 30, 2021.
  1. Jun 30, 2021 at 8:27 AM
    Taco_6112
    Taco_6112 [OP] Member
    Hello all, I recently installed 285/70/17 tires with Method 305. I also installed the 12 x 1.5 mm lug nuts from Method. I’m reaching the 100 mile mark where the lug nuts need to be re-torqued. Saw on tirerack that the range should be 70-80. I asked the shop that did the install and they’re recommending 110. I’d appreciate your inputs on what the correct number should be.
  2. Jun 30, 2021 at 8:28 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    OEM is 83 I believe
    eurowner and #4TOY4ME like this.
  3. Jun 30, 2021 at 8:36 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    83 is factory, but I would probably go 100. At this point you are checking the torque and probably not turning anything.
  4. Jun 30, 2021 at 8:37 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    if your using stock keeps it at the stock 83/85. The one time I let someone else balance and torque the wheels down....... a couple of months later 4/5 studs sheared off and had a lug nut holding the wheel on. This was likely due to over torquing.
    over-torquing will stretch the studs.
    May not want to go back to that shop.
  5. Jun 30, 2021 at 8:43 AM
    Rubicon-n-Taco
    Rubicon-n-Taco Well-Known Member
    JC
    2021 Tacoma TRD DCLB OR, 2016 Unlimited Rubicon, 2005 F250 PowerStroke, 1975 Sicilian Wife 490cc High Profile Natrelle Silicone
    I've taken the mudflaps off?
    nudavinci64[QUOTED] likes this.
  6. Jun 30, 2021 at 8:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I torque to 85 per factory and never had an issue. I would absolutely not overtorque, that's how you stretch and weaken studs.
    nudavinci64 likes this.
  7. Jun 30, 2021 at 8:59 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    85, & done.
  8. Jun 30, 2021 at 9:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    83 ft-lb per the owner's manual. Don't go higher or you can break wheel studs; they're only equivalent to SAE grade 5 strength. I broke one because the crappy Capri torque wrench didn't click if cranked too slowly...
  9. Jul 2, 2021 at 6:55 AM
    Taco_6112
    Thank You all for your responses. I appreciate it. I went ahead and set it at 83/85 as most of you had recommended. However on my drive back home, I started feeling the steering wheel shake after driving over 55 mph. I’ll see if the issue still persists. I have Nitto Ridge Grapplers installed. Any recommendations on the tire pressure? Considering the shop over torqued the lug nuts, I seriously doubt if they set up the correct tire pressure as well. Thank You all once again for taking your time to reply.
  10. Jul 2, 2021 at 6:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Put it around 32. Also, it's possible they didn't balance the tires correctly which is a common steering wheel shaking issue.
    Thejohnnyb21 likes this.
  11. Jul 2, 2021 at 7:09 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    I just hit them with the impact gun and don't think about it. Never had warped rotors etc etc.
    Sungod likes this.
  12. Jul 2, 2021 at 7:17 AM
    Taco_6112
    Thank You for the reply. On a side note, I have Bilstein 6112 on the front and am experiencing a slight rubbing on the front bumper side. I was thinking about going with a viper cut on the front bumper. Do you have any recommendations before I go ahead with the cut?
  13. Jul 2, 2021 at 7:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You've got the right idea. Just cut shit out of the way until it stops rubbing.
  14. Jul 2, 2021 at 7:22 AM
    Taco_6112
    Haha. Thank You from a fellow Virginian.
