Lucas or Chevron Techron
Discussion in 'Product Reviews' started by CheeseHead…WI, Jan 1, 2024.
  1. Jan 1, 2024 at 5:41 PM
    CheeseHead…WI
    CheeseHead…WI [OP] Member
    Milwaukee
    23 Ice Cap TRD OR
    Any difference in Lucas fuel treatment vs Chevron Techron fuel systen cleaner?
    or is it a gimmick and waste of money
  2. Jan 1, 2024 at 5:43 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I’m quite sure all the fuel additives like gumout are gimmicks but I’m not a mechanic so maybe I’m wrong. I’d be curious to hear other opinions from people who are more knowledgeable.
  3. Jan 1, 2024 at 5:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's a new truck, why would you be using fluids and that sort of stuff on a new vehicle
  4. Jan 1, 2024 at 5:46 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
  5. Jan 1, 2024 at 5:49 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Just use high quality gasolines, I’ve never used additives
  6. Jan 1, 2024 at 5:49 PM
    MGMDesertTaco
    I've used both. I don't notice any difference with the Techron, but not saying it doesn't work. The Lucas seems to be more noticeable. Probably a higher concentration formula. Lately all I buy is the Lucas deep clean total fuel system cleaner.
    edit: and Costco gas
  7. Jan 1, 2024 at 5:51 PM
    MGMDesertTaco
    I used to run strictly Shell gas, but Costco has them beat by $.60 to $1 a gallon at times.
  8. Aug 17, 2024 at 5:04 AM
    htxbrute
    htxbrute Member
    2019 Red Tacoma Sport
    If you buy gas from anywhere with that Top Tier logo you should be good to go. They all contain the same detergents you get in a bottle of Techron afaik.
    Booman likes this.
  9. Aug 17, 2024 at 5:22 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I have no idea if it works or not, but I use a bottle of Techron at each oil/filter change (5K).
  10. Aug 17, 2024 at 8:18 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    All major chain gas stations and many others including Costco use top tier gasoline. Top tier. means that the additives/detergents exceed EPA requirements and standards. The additives and detergents are not all the same. Each company has their own patented formulation. The Techron additive may be the best , it is to most expensive to formulate. I have a friend who is a retired Chevron executive that tells me Techron is the best based on their testing and it costs more to make than other companies formulations. Yes he’s prejudiced but I believe him. I generally don’t use Chevron gas as here in California it’s generally 40 to 50 cents a gallon more than other brands. Shell is also about as expensive as Chevron and their additive formulation by many is considered as good as Chevron.
    So does adding a bottle of fuel treatment such as Techron do anything extra ? I don’t know for sure, but it can’t hurt. I personally add a bottle to the tank every oil change. Sometimes every other oil change. I look at it like this, the amount of additives in the gas by the gas companies is minimum. There’s no doubt it does a great job cleaning deposits in our engines. I figure adding more every once in a while may help eliminating some “stubborn “ deposits that the amount in the gasoline doesn’t completely eliminate.
    It’s like washing clothes, when you have heavily soiled clothes you may add more detergent to the washing machine to better clean. I kind of look at fuel additives the same way. To each his own.
