Lubrication points under chassis?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joncure, Nov 10, 2021.
  1. Nov 10, 2021 at 9:51 AM
    joncure
    joncure [OP] Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    I was crawling under truck inspecting frame, shafts, axles etc. Was looking for any grease zerks or other lube points. No zerks found. Anyone know if there are any or know of good places to lube up?
  2. Nov 10, 2021 at 10:06 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    driveshafts on mine had 3 or 4 points to lubricate..
    gudujarlson likes this.
  3. Nov 10, 2021 at 10:13 AM
    joncure
    VA
    wonder if that has changed for the ‘21? Are yours on the shafts and u-joints? I couldn’t find any.
    cryptolyme likes this.
  4. Nov 10, 2021 at 10:14 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    I can't find anything to grease on my 19.
    Vmax540 and MOC221_ like this.
  5. Nov 10, 2021 at 10:17 AM
    joncure
    VA
    :confused: Maybe Toyota sealed everything up after a certain year?
  6. Nov 10, 2021 at 10:19 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    the 2016 3rd gen service manual says there's a bunch of zerks down on the driveshaft. I can't find any of them on my 2021.
  7. Nov 10, 2021 at 10:23 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    Late 2016 and newer models don't have zerks on rear drive shaft, but should have them on front shaft u-joints. That's it though for OEM.
    cwdog, monoman and Beerpayzdabillz like this.
  8. Nov 10, 2021 at 10:26 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    all mine were on the driveshafts. i honestly can't remember if the u-joints had them? but will check
  9. Nov 10, 2021 at 10:30 AM
    joncure
    VA
    Interesting, I’m under there right now and can’t find any on front or rear shafts!
  10. Nov 10, 2021 at 10:31 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    2017 and only 2 on the front driveshaft. If you don’t find any on yours then Toyota has fully switched to lifetime grease u-joints and now need to grease anything.
    cwdog likes this.
  11. Nov 10, 2021 at 10:37 AM
    joncure
    VA
    I’d say that’s the case with my truck.
  12. Nov 10, 2021 at 10:49 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Unless Toyota changed things up during the 2019 MY, you should have two on your front driveshaft.. mine does.
    Well, unless you're 2WD lol.
    The zerks are not super easy to spot on the front driveshaft, as they poke out from the middle of the joint, not from an end cap. At least the joint closest to the transfer case is like that, I can't remember what the front joint looks like.
    Skydvrr likes this.
  13. Nov 10, 2021 at 11:19 AM
    aturk
    Tony
    Charlotte, NC
    I will look again this weekend as I need to do tcase fluid. I've looked a few times and didn't see anything.
  14. Nov 10, 2021 at 12:06 PM
    joncure
    VA
    I was just under there re-checking. Pushed my fingers anywhere they would go in the u-joints and nothing. I’m definitely used to finding and using zerks with other vehicles. Can’t find the 1st one on my 2021, front or rear.
  15. Nov 10, 2021 at 12:15 PM
    cryptolyme
    Virginia
    none on the u-joints that i can find either
  16. Nov 10, 2021 at 12:21 PM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    I always heard. You can't wear out something that makes its own grease. :notsure:
  17. Nov 10, 2021 at 12:21 PM
    joncure
    VA
    Well I guess it’s a good thing? Maybe? It is nice to be able to grease up the parts that need it though.
  18. Nov 10, 2021 at 12:23 PM
    joncure
    VA
  19. Nov 10, 2021 at 1:09 PM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    My early 2020 (before the trans cooler was removed/ has antenna fin pushed further back) doesnt have any grease zerks anywhere
  20. Nov 10, 2021 at 1:11 PM
    DMel
    DMel Well-Known Member
    2020 TRD OR Cement
    my 2020 (built Oct 19) doesn't have any zerks too
