Lubricated the driver's door key/lock...a mistake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Mar 18, 2019.
  1. Mar 18, 2019 at 10:34 PM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Recently I was lubricating all of the locks in my house, been using this dry lube stuff that specifically is for locks. Man! It's been fantastic, all of my doors open super smooth and the locks turn really easy.
    Well I may have gotten a bit overzealous, I thought it might be a good idea to spray a bit on the key, put it into the door keyhole and lubricate the internal door lock on the truck...
    Since then it's just gotten worse and worse and worse, it takes more effort and sticks now... Shit.
    Any idea if I can fix this? Or did I miss it up?
    I was thinking that maybe it doesn't like dry lubricant, I could try a tiny bit of 3 in 1 but I'm afraid to do anything else...haha
  2. Mar 18, 2019 at 10:34 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Graphite
    jross20[OP] likes this.
  3. Mar 18, 2019 at 10:37 PM
    jross20
    Georgia
    I think I have some of that, does it go bad? Might be old...haha.
    Okay, so a little on the key and then work it back and forth?
    El Duderino[QUOTED] likes this.
  4. Mar 18, 2019 at 10:51 PM
    El Duderino
    Jeremy
    HI->PNW
    Yup. Graphite is what I use in my salty air environment have never had an issue
    jross20[QUOTED][OP] likes this.
  5. Mar 18, 2019 at 10:51 PM
    Grumpy
    Grumpy My 1st Tacoma
    Maurice
    Oahu, Hawaii
    14/DCLB/V6/4x4/SR5
    17" Method Grid Titanium rims w/ Pro Comp Sport A/T 265/70/17 tires, Mobtown Offroad ribbed Tailgate skin, installed LED lights in painted rear bumper black, faux TRD grill, color match grill surround. LEDs in map, license plate, center console, and dome lights. Anytime driving lite mod, debadged, vent visors, AA Maglite mounted under center console armrest. Antitheft hose clamp on tailgate, LED bed lighting kit. LED spot lights in lower front bumper. Weathertech floor mats. Painted various interior parts black, homemade 7 pin relocation bracket, Valet under door LEDS, CMC, SPC UCA, Bilstein 5100, OME 885, Headstrong AAL. Pop&Lock.
    Did you use a penetrating fluid to lubricate the truck lock? If so you probably washed out all the graphite based lubricant and that's why the lock is acting the way it is now. Be careful spraying the Graphite lube around any electronics. Graphite lubricant shouldn't go bad sitting on the shelf so if you have old can it should be good to go. Screen Shot 2019-03-18 at 7.47.55 PM.jpg
    El Duderino likes this.
  6. Mar 18, 2019 at 10:52 PM
    El Duderino
    Jeremy
    HI->PNW
    Yes thanks forgot about the electronics warning
  7. Mar 19, 2019 at 12:38 AM
    Muddinfun
    Muddinfun Well-Known Member
    The door lock comes out really easy. There's a black plastic plug on the edge of the door. Pop it out. Then, in the hole is a bolt. Unscrew it. It's captive so it won't fall out. Then you just pull the lock assembly out. Snap the plastic cover off and you have the lock in your hand. Then you can spray the living daylights out of it. The locksmith I use recommends Triflow.
    Blockhead and El Duderino like this.
  8. Mar 19, 2019 at 1:04 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    What may work for the guy in Hawaii may not be the right product for you if you are in a colder climate. I avoid spraying anything in a lock unless it is already having issues. Frost (moisture) collects on dirt before a clean surface. Therefore dirty locks or ones with crap in them will attract moisture and freeze more often than a clean lock.
    We can discuss products that repel moisture or should have this characteristic or another. This is my experience and the internet engineers can argue the finer points all they want.
  9. Mar 19, 2019 at 2:22 AM
    JoshuaS904
    JoshuaS904 Member
    Joshua
    2011 Black DC PreRunner
    You might be able to douche out the junk with compressed air. Pencil lead works great as key lubricators, and crushing it into dust and blowing it into locks is a cheap, but effective way of lubing a lot of locks (mostly padlocks.. but kinda not so much with car doors)
    Cars use wafer locks, since they are an easy way to use a double sided key. You probably just clogged the tracks the wafers ride in with whatever is in the dry lube (ptfe based stuff?)
  10. Mar 19, 2019 at 5:32 AM
    jross20
    Georgia
    I used 3 in 1 lock lubricant. I figured since it was for locks it would be okay.
    You don't happen to know if there's a write-up or photos showing this do you?
    I'm in Georgia so we don't get super cold around here...haha, just super humid. Yuck.
    Wow is that the door lock? I guess it wouldn't hurt to take it out and clean it up.
    Grumpy[QUOTED] likes this.
  11. Mar 19, 2019 at 6:02 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Pencil lead is Graphite.
  12. Mar 19, 2019 at 7:00 AM
    Muddinfun
  13. Mar 19, 2019 at 7:11 AM
    JoshuaS904
    JoshuaS904 Member
    Joshua
    That’s kinda the point.
  14. Mar 19, 2019 at 10:47 AM
    jross20
    Georgia
  15. Mar 19, 2019 at 12:11 PM
    Muddinfun
    I think I paid about $80 or $90 for new speedway blue color matched handles and lock covers for my access cab. Not sure what I did with my black ones. Make sure you get the correct "lock cover" for the passenger side based on if you have a passenger side key lock or not.
  16. Mar 19, 2019 at 12:13 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It takes about 5 minutes to remove the locks. Super easy. Had to change mine out
  17. Mar 19, 2019 at 12:21 PM
    jross20
    Georgia
    Damn. I guess I'll just clean mine and throw them back on haha.
  18. Mar 19, 2019 at 12:21 PM
    Muddinfun
    My locksmith guy is very good. I have seen him do some amazing things. This is what he recommends, so that's what I go with. It also works great for motorcycle/ATV chain lube in the dunes.
  19. Mar 19, 2019 at 1:47 PM
    jross20
    Georgia
    Thanks I'll try to pick some up. Do they sell it in places like Lowe's or Ace?
  20. Mar 19, 2019 at 1:49 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    This is what I use. I spray it on everything...squeaky bushings, bearings, door locks, etc. It doesn't attract dirt like regular WD40 or lithium, silicone, etc. does.
    I've learned the hard way never to spray silicone on bearings or bushings, might make them quiet at first but the dirt that it attracts will ruin them in short order.
    I spray the dry lubricant though right into the keyhole on my trucks doors and it works well.
