Lube propeller shaft
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GCC, Jul 24, 2022.
  1. Jul 24, 2022 at 5:56 PM
    GCC
    GCC [OP] Member
    George
    2018 Toyota Tacoma
    I am doing the 30,000 mile maintenance on my 2018 4wd Tacoma. The maintenance schedule tells me to lube the propeller shaft. I can't find any grease fittings. Am I missing something?
  2. Jul 24, 2022 at 6:02 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I believe the front driveshafts grease fittings are in the center of the joints rather than on a cap like the rear
  3. Jul 24, 2022 at 6:06 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  4. Jul 24, 2022 at 6:07 PM
    snakeplissken
    snakeplissken Call me Plissken
    I don’t have fittings on mine… I believe Toyota started removing zerk fittings on tacomas throughout the years.
    drizzoh and cryptolime like this.
  5. Jul 24, 2022 at 6:22 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    2016 had them. 2017+ did not as I remember.
    Bed cubby storage disappeared, glove box divider also.
    Key-Rei likes this.
  6. Jul 24, 2022 at 7:00 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My 2016 has 5 Zerks. Your 2018 may have 2 Zerks on the front shaft. This old thread will show you where all 5 Zerks are if you have any to grease.
    https://www.tacomaworld.com/threads/check-your-u-joints.409042/
  7. Jul 24, 2022 at 7:03 PM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    2021 trd OR here. 0 zerks.
    Toyota started to remove them throughout the 3rd gen years.
    You might have only 2 in the front
    drizzoh and Bry-theTRD like this.
  8. Jul 24, 2022 at 7:04 PM
    TA2016
    Oregon
    Here is an interesting article on greaseable vs. non-greaseable joints.
    "Bottom line on strength: The non-greaseable joint is slightly stronger than a greaseable joint. The exact number, how much stronger, is unknown and we do not believe it to be very significant.
    Bottom line on wear life: A regularly greased greaseable joint will outlive a non-greaseable joint. But a non-greaseable joint will outlive a greaseable joint that does not get greased properly. "
    https://4xshaft.com/blogs/faq/greaseable-vs-non-greaseable-joints-which-is-better
    GilbertOz and cryptolime like this.
  9. Jul 24, 2022 at 7:13 PM
    Bishop84
    Bishop84 Well-Known Member
    A lot of maintenance literature is from old schedules.
    You're supposed to tighten them as well.
  10. Jul 24, 2022 at 7:20 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Toyota lags when it comes to editing the maintenance manuals; especially in regards to lubrication of the prop shaft. Probably copying/pasting...:notsure:
    I believe the 2nd gen had 2 different greases listed; with and without moly.
    Moly was for the CV joint; which only came on 1st Gen Tacomas.
  11. Jul 24, 2022 at 8:13 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    at least u-joints are pretty cheap
    TA2016[QUOTED] likes this.
  12. Jul 24, 2022 at 8:15 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    you can't really do that unless you have zerks on your shaft
  13. Jul 24, 2022 at 8:18 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    My 21 OR has no zerks on the shaft. When it comes time for new u joints.. ehh. I'll probably get grease able at that point.
    Raijin822 likes this.
  14. Jul 24, 2022 at 11:33 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    2017 has on front shaft.
  15. Jan 20, 2023 at 8:42 AM
    osodelnorte
    osodelnorte New Member
    The Torque Spec. Guide | Tacoma World
  16. Jan 20, 2023 at 8:47 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My 09 4x4 has a zerk on every u joint..i was changing the oil on my 23 last night and noticed it doesnt have any ...
    but i think i read thats the way 2wd are
  17. Jan 20, 2023 at 10:20 AM
    Raijin822
    Canada
    2021 TRD OR
    Sometime in the 21's Toyota went to sealed fittings, none of the newer trucks will have any zerks.
  18. Jan 20, 2023 at 10:20 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    the sealed u-joints with no zerks are slightly stronger. guess Toyota decided they would last longer.
  19. Jan 20, 2023 at 10:28 AM
    splitbolt
    NW Arkansas
    shakerhood and HondaGM like this.
  20. Jan 20, 2023 at 10:30 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
