LSD noise after gear oil chg.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loopdog, Aug 2, 2010.
  1. Aug 2, 2010 at 8:07 PM
    Loopdog
    Loopdog [OP] Member
    Pete
    Ca
    06 Tacoma SR5 4x4
    Stock
    I just changed the oil in the rear diff. (limited slip) and now its making a rubbing, dragging noise when turning. 2006 Tacoma 4x4, v6, 6 speed manual, 40,000 miles. I used Valvoline gear oil that had "Limited Slip" on the label. Any ideas??
  2. Aug 2, 2010 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you add 4 ozs. of LS Addative?
  3. Aug 2, 2010 at 8:18 PM
    Loopdog
    Loopdog [OP] Member
    Pete
    Ca
    06 Tacoma SR5 4x4
    Stock
    Can you get that at Autozone, PEP Boys etc.??
  4. Aug 2, 2010 at 8:26 PM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Cool you have a manual. I just couldn't get one. Everyone has automatic. I hate automatics.
    Yes, you should be able to get the additive at Napa, Pep, etc.
  5. Aug 2, 2010 at 8:33 PM
    Loopdog
    Loopdog [OP] Member
    Pete
    Ca
    06 Tacoma SR5 4x4
    Stock
    thanks all, gonna try an additive first and see what happens.
  6. Aug 3, 2010 at 3:27 AM
    tracker
    tracker Active Member
    2008 4x4 doublecab long box
    I had to add a tube of TransX to my dino rear end oil that had the LS in it.
  7. Aug 3, 2010 at 4:25 AM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    Pete,
    Add the LSD additive like Chris stated. Then take the truck to an empty parking lot and make about 10 full circles slowly to the left and 10 full circles slowly to the right to get the additive worked back into the clutches and you will have no more problems. :D
    Fred
  8. Aug 5, 2010 at 11:15 AM
    IslandBoy71
    IslandBoy71 Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    Dp all 2nd gens have LSD's?
  9. Aug 5, 2010 at 11:29 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    05-08 (TRD sports + Most 4x4 Double Cab Long Beds + specific orders. )
  10. Aug 5, 2010 at 11:35 AM
    IslandBoy71
    Reggie
    Lakewood, CA
    Is there a write up here on how to change rear diff oil? mine has 125k and I know I'm overdue.
  11. Aug 5, 2010 at 11:39 AM
    BlueT
    NorthEast
  12. Aug 5, 2010 at 11:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  13. Aug 5, 2010 at 12:10 PM
    IslandBoy71
    Reggie
    Lakewood, CA
    Thanks! I'm doing mine today. Yes the truck runs great no weird noise or anything like that. Did you use synthetic gear oil?
  14. Aug 5, 2010 at 12:19 PM
    BlueT
    NorthEast
    O no you dont get noise, just you won't get power distribution to both wheels.
    Yep synthethic, but read the thread Janster posted.
    It took some time to figure out what works with that LSD due to Toyota forgetting to include info in FSM.:rolleyes:
    I am running Mobil 1 Delvac with two bottles of GM limited slipp additive.
