LS3 AWD Swap!! pics and dyno video
Discussion in 'Performance and Tuning' started by jlee541, Oct 9, 2012.
  1. Oct 9, 2012 at 7:40 PM
    jlee541
    jlee541 [OP] New Member
    john
    Canton, GA
    Slow
    Trucknorris likes this.
  2. Oct 9, 2012 at 7:49 PM
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    yep, i know what ill be doing to mine once the engine goes or i get tired of it..lol
  3. Oct 9, 2012 at 7:49 PM
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
  4. Oct 10, 2012 at 8:39 PM
    Twistinemup307
    Twistinemup307 Well-Known Member
    Alex
    Wyoming
    2012 DCLB tacoma SC sport
    BAD ASS!!!!!!! :)
  5. Oct 12, 2012 at 9:33 PM
    sandman29306
    sandman29306 Well-Known Member
    Andrew
    Chattanooga TN
    01 PreRunner DC
    Icon COs and rear resis, Deaver leafs. ARB locker in rear. ARB front bumper...Pissed at Gadget for abandoning the Rotrex 3.4 supercharger.
    Do you know if a shop or an individual did this installation?
  6. Oct 12, 2012 at 9:35 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Mother of God!
  7. Oct 13, 2012 at 10:23 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Jesus Christ! :bowdown:
  8. Oct 13, 2012 at 10:27 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Amazing! please tell me your pulling the tiny Toy axles?
  9. Oct 13, 2012 at 10:38 AM
    jandrews
    '09 FourDubDee TRD OR
    This. I would think the entire drivetrain would need to be swapped to keep from snapping shit.
  10. Oct 13, 2012 at 10:42 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    this is badass!!!! So op its not ur truck, whos is it!? R u doing the work on it?
  11. Oct 13, 2012 at 4:57 PM
    Large
    Large Red
    Where is this located
  12. Oct 13, 2012 at 5:22 PM
    jlee541
    john
    Canton, GA
    Slow
    Yes, I did all the work at my shop in Atlanta. Owner lives in Florida.
    As for the front diff and rear axle they will get changed (prob when they break LOL) But first thing needed is a trac bar of some sort. That rear u-joints hatin life right now!!
    Before the trans was sent off to get modified and the Spec 3+ clutch that I used
    Heres where I had to notch the oil pan to clear the front diff. This swap would not have been possible had the truck not had the Fabtech front lift kit. Also had to use a Canton remote filter adaptor.
    Modified pump assembly. Bosch 044 and I put in an Autometer 240-33 ohm sending unit to work with the Camaro gauge. Which turned out I had to put a series of diodes and resistor in to get the LS3 ECM to read it properly. Camaros have two senders in the saddle tank. That took quite a bit of testing to make work. But the dash now gives instant mpgs and miles to empty WOHOO!!
    Gas pedal mount. This was a task in itself as the e-brake mechanism was all in the way. Had to modify this mount a few times to get the pedal in the right spot.
    Headers (before ceramic coating)
    Trying to get a good angle of how tight this is in the truck
    And this is how tight the front is. I used the stock radiator, made an aluminum plate with two 9" and one 16" fan. Running off LS3 ecm I programmed them to come on in series. Absoutely zero overheating problems. , the big fan cycles between 187 and 181 for about 20 seconds.
    Used all 08+ Corvette accessories as they are the tightest to the block and had to put a little bit narrower battery to clear the alternator. Also had to notch the frame on the pass side for the ac compressor and hoses.
    Full Dual 3" exhaust into a Magnaflow x-pipe muffler with turndowns YEEHAW!! Actually it isnt redneck loud, sounds awesome and absolutely no fumes or anything inside the cab.
    This is what controls the transfer case, out of an Astrovan :) Its basically an on demand AWD and with a switch I can send 6-8 volts to the encoder motor to force it into AWD. Or disconnect the power and the ADD for 2wd operation.
    Owner took the truck back to FL today and hopefully get some pics of the finished interior/dash soon.
    Also, hes gonna do some sort of hood scoop(s). Why I built the intake that way.
  13. Oct 13, 2012 at 5:45 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Nice work. Like to see more
  14. Oct 13, 2012 at 5:56 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  15. Oct 13, 2012 at 6:00 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
  16. Oct 13, 2012 at 6:02 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  17. Oct 13, 2012 at 6:11 PM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    My thoughts exactly
  18. Oct 13, 2012 at 6:13 PM
    ajohnson
    Andy
    Charlotte, NC
    What are the dyno numbers?
  19. Oct 13, 2012 at 6:18 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    that is freaking awesome
    too bad the rest of the truck is, well.... uh...uh...uh... undesirable.
  20. Oct 13, 2012 at 6:19 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    how much hp did it threw?
