Lowering options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZR-1Jeff, Jul 29, 2023.
  1. Jul 29, 2023 at 10:33 PM
    ZR-1Jeff
    ZR-1Jeff [OP] Member
    Hi everybody,what kind of options are there for lowering a 23 Tacoma,I've seen kits for 3.5 in the front and 4 in the rear. Is this the standard setup for lowering a Tacoma?
  2. Jul 29, 2023 at 10:50 PM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece all Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
  3. Jul 29, 2023 at 11:04 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Speed bump scraper low as the goal?
  4. Jul 29, 2023 at 11:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    Where are you seeing kits for '24 Tacomas?
    And there is a 4th gen forum, which is what a '24 is.
    Chew likes this.
  5. Jul 30, 2023 at 12:22 AM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the 24's are not out so how could there be a kit?
    e6400ultra, V01dnet and Chew like this.
  6. Jul 30, 2023 at 1:00 AM
    west4x4
    west4x4 Un-known Member
    San Bernardino County, CA.
    2019 Tacoma TRD Off-road
    A lowered stance 3rd gen Tacoma sounds about nice. You got any pictures
  7. Jul 30, 2023 at 2:12 AM
    ZR-1Jeff
    Meant 23. I'll be looking at a new Tacoma and the determining factor of whether or not I buy one is if I can lower it or not and get it as low as I want it. Everything I own is lowered pretty much,nothing is stupid drag shit on the ground lowered,just very little gap between the tire,fender. So far all I've seen are 3 front and 4 rear. Is this the max anybody makes for these,any coil over applications? Thanks to all for any positive info.
  8. Jul 30, 2023 at 2:14 AM
    ZR-1Jeff
    No,just low enough.
  9. Jul 30, 2023 at 9:46 AM
    Clearwater Bill
    Billy
    Largo Florida
  10. Jul 30, 2023 at 9:48 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Edited the year in the first post
    ZR-1Jeff[OP] and 4x4spiegel like this.
  11. Jul 30, 2023 at 11:54 AM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    How about not lowering? I should take this taco away from you and give it to someone.
    cryptolime likes this.
  12. Jul 30, 2023 at 11:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why not?
    98.75 % of the lift/big tire/black wheel/light bar crowd don't need any of it for how they use the truck. They just like the look.
  13. Jul 30, 2023 at 12:00 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    then keep it stock. i don't see the point in going lower. kind of defeats the purpose. lifting it doesn't improve off-road performance unless you add bigger wheels. and if you add bigger wheels then you are going to be super slow unless you regear.
  14. Jul 30, 2023 at 12:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Start by using a 255 80 17 or 255 85 16 tire on wheels with the same specs as your OE wheels.
    That will fill a lot of wheel well with no massaging needed.
  15. Jul 30, 2023 at 12:07 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Ease of access, lower CQ, better handling, because its his truck and he wants too.
  16. Jul 30, 2023 at 5:18 PM
    west4x4
    I hope it’s a basic model Tacoma your going to lower.
  17. Jul 30, 2023 at 7:32 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
  18. Jul 31, 2023 at 3:43 AM
    west4x4
  19. Jul 31, 2023 at 3:50 AM
    ZR-1Jeff
    Why does it need to be a basic truck? Access cab,V6 and keyless entry are what I'm looking at,I'd go for a standard cab but that's not possible,I'd like a MT and a sunroof but don't want to spec the options just to get those features. Not sure on color,maybe Ice White. I can understand some not seeing the reasoning in lower something,pretty much the same mindset as people that jack a truck sky high and put on polished wheels and short tires. If my plan comes together this little truck will be bad ass.
  20. Jul 31, 2023 at 7:55 AM
    Clearwater Bill
    Billy
    Largo Florida
