Lower Front Ball Joint cup?!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gravelgrinder4, Mar 7, 2022.
  1. Mar 7, 2022 at 2:59 AM
    Gravelgrinder4
    Gravelgrinder4 [OP] New Member
    2011 Tacoma
    Hey All,
    anyone know where I can get a receiving cup that will work to press out these ball joints? Rental ball joint press didn’t have the right size! 2 1/2 ID x 2 3/4 OD
    thanks!
  2. Mar 7, 2022 at 9:04 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    For OEM, the right size comes in a universal BJ kit (got mine from HF). For Moog, you may need to pick up a small pipe from a metal or pipe supply shop, or other metal fab type shop. You may also need to grind out the seam on the inside, but only about half inch from the ends. If you are in Socal area, you can borrow mine.
  3. Mar 7, 2022 at 9:13 AM
    Gravelgrinder4
    2011 Tacoma
    Thanks, Chuy. I will try the universal kit from HF.
  4. Mar 7, 2022 at 9:38 AM
    Chuy
    Lakeside, CA
    Silver Taco
    I dug up my notes ... the ID of the cup to remove OEM BJ was 2 1/4". To remove the Moog I installed, I will need a 2 1/2" ID. These are max ID in order to grab enough of the BJ lip to press it out; otherwise, you hit the ball of the BJ (you might get more clearance by removing the rubber boot). Are you using a press or a large BJ C-clamp?
  5. Mar 7, 2022 at 9:44 AM
    Gravelgrinder4
    2011 Tacoma
    I was attempting to use a C clamp. I just spoke to a local metal fabricator who can sell me a 3" chuck of pipe that is 2-1/2" ID and 2-3/4" OD. I am hoping that will work as the replacement ball joint I purchased measures 2-1/2". The problem I ran into was that the pieces where either too small or too large and rolling up over the side of the LCA.
  6. Mar 7, 2022 at 2:46 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The powerbuilt kit should have what you need. I used it and worked fine.
    TnShooter likes this.
  7. Mar 7, 2022 at 2:50 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
  8. Mar 7, 2022 at 4:14 PM
    Gravelgrinder4
    2011 Tacoma
    Thanks for the thread link. I searched this topic before I posted and I didn’t see that thread!
    6 gearT444E likes this.
  9. Jan 28, 2024 at 3:42 PM
    Chris187
    Chris187 New Member
    3.5 inch rough country lift
    I’m doin my lower bj right now. Having same problem as you n I got the kit from hf.
