Lower control arm!
Discussion in '1st Gen. Tacomas (1995-2004)' started by TTTown002, Apr 9, 2021.
  1. Apr 9, 2021 at 8:03 AM
    TTTown002
    TTTown002 [OP] Active Member
    sven
    2002 V6 3.4L
    I need new lower control arms and I don't have a lift but still want nice ones. Shoot me what you guys got!!!!!
  2. Apr 9, 2021 at 8:08 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  3. Apr 9, 2021 at 8:29 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    How they should have been made right?
    2004Taco likes this.
  4. Apr 9, 2021 at 9:17 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'll bet you you just need new bushings...
    Those Solo ones are redonk expensive for zero real benefit. OEMs are perfectly fine, and are definitely not the weak point in the system.
  5. Apr 9, 2021 at 9:18 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They actually move the wheel forward a bit for additional clearance on top of being sturdy as hell.
    eimkeith likes this.
  6. Apr 9, 2021 at 9:23 AM
    jbrandt
    Justin
    I don't doubt they're much stronger than stock.
    But people aren't breaking OEM ones, so all that additional strength is kinda not necessary.
    99% of the time when people post here that they "need to LCAs" it's because a shop/mechanic told them they need them.
    I'm really fascinated with the uniball conversion kits they have, but again, the price of entry (LCAs, unis, spindles) is too rich for my blood.
  7. Apr 9, 2021 at 9:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No you're right, LCA's aren't really a weak link in all this (though there are reports of some people cracking them) but the Solo's do provide the benefit of relocating the wheel slightly away from the firewall/cab.
  8. Apr 9, 2021 at 9:26 AM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Wouldnt their long travel kit ride smoother than stock even at stock ride height?
  9. Apr 9, 2021 at 9:30 AM
    jbrandt
    Justin
    odd, they don't mention that in the description. How do they move the wheel forward without F-ing up the alignment? They'd need the UCA to move forward too.
  10. Apr 9, 2021 at 9:31 AM
    jbrandt
    Justin
    That's more a function of your shock settings. Wheel size also plays a role.
    Hopefully people aren't throwing long travel at their trucks because they want a smoother ride...
    Abeyancer likes this.
  11. Apr 9, 2021 at 9:32 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    It makes the alignment and clearance better by moving the LBJ forward slightly and thus increasing castor.
    That being said, for most applications I would just toss new bushings in a set of OEM arms.
  12. Apr 9, 2021 at 9:32 AM
    TacoBike
    Mason
    More caster? I think i remember someone saying that people want more sometimes for our trucks?
  13. Apr 9, 2021 at 9:36 AM
    Madjik_Man
    Colorado Front Range
    I was gonna say I know guys on here who beat the piss out of their trucks, and are running OEM LCAs.
  14. Apr 9, 2021 at 9:39 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I run moogs on mine with no issues
    koditten and TTTown002[OP] like this.
  15. Apr 9, 2021 at 9:41 AM
    jbrandt
    Justin
    The "more caster" thing is a bit of a misnomer. When lifting a truck, you need UCAs that have more caster to correct the alignment at the new ride height, so some people think that means that lifted trucks "need more caster" so they tell their alignment tech to get bigger castor numbers. That's not really true. You need more caster adjustment from the UCAs, but the end numbers should still be within factory spec.
    There are times when you may want more castor than what the factory specifies, but those are pretty specific situations (like racing or something). The rule of thumb should always be to maintain stock alignment numbers.
    MalinoisDad and Xbeaus like this.
  16. Apr 9, 2021 at 9:43 AM
    TacoBike
    Mason
    Stashing that into the back of my head for the future. good info
  17. Apr 9, 2021 at 9:44 AM
    TTTown002
    sven
    2002 V6 3.4L
    Thank you guy. Needed to replace my ball joint was looking to is if there was nice control arms out there and my new 265/75r16 nitto tires do rub a little bit in the back when I turn probably go away once i ride them a bit. Probably just going to go ahead and rock stock control arms and just new ball joint for them. Based on what you guys just said. I am running stock
  18. Apr 9, 2021 at 10:05 AM
    Xbeaus
    Beau
    Same boat as you. Went to get an alignment and they said I needed new upper and lower control arms. WTF? not going there again. just replacing bushings. I swear - customer service is just getting thrown out the window anymore. It's good to find a good place that will not try to screw ya over.
    Taco2021LB likes this.
  19. Apr 9, 2021 at 10:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Bushings as stated in the beginning.
    Shops recommend new arms because they're too lazy to replace the bushings in them.
    Taco2021LB, koditten and jbrandt like this.
  20. Apr 9, 2021 at 10:16 AM
    TacoBike
    Mason
    Are these the kind you have to burn out or am I thinking of a different car
