Lower Control Arm question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainTikihut, Jan 29, 2019.
  1. Jan 29, 2019 at 12:26 AM
    CaptainTikihut
    CaptainTikihut [OP] Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Been considering a suspension upgrade and noticed most mods don't include new LCAs, even some of the most expensive upgrades such as the ICON stage 9 doesn't include it. In fact I've only found two vendors with aftermarket stock length LCAs (Dirt King and Total Chaos); but Total Chaos LCAs are not compatible with bushing lower rod ends coil overs.
    Can some suspension expert chime in and tell me the advantages of upgrading the LCA (stock length)? And why most guys here don't have them (can't be just cost)? Comparing the factory LCA to the two aforementioned LCAs it appears the aftermarket has better articulation due to better uniball design providing a better body geometry and maybe a lil' more ground clearance?
    Is it lighter than stock besides being "stronger" so they claim?
    Also those that do have both aftermarket UCAs and LCA is there anyone running two completely different brands? Example: ICON UCA & Dirt King LCA?
    thanks bros!
    ERod27 likes this.
  2. Mar 7, 2019 at 10:26 PM
    ERod27
    ERod27 Well-Known Member
    Eddie
    2019 TRD OR DCSB
    King 2.5s with Camburg Kinetik UCA Cooper Discoverer AT3 XLT 285/70/R17 17" 4 Runner TRD PRO SEMA wheels TRD PRO skid plate 5.29 Yukon gears Apogee front bumper with Warn EVO Apogee rear bumper with tire carrier
    Literally wondering the same thing. I bought the IVD stage 8, and looked into upgrading my LCAs. Icon doesn't even make them, so there goes my desire to keep my suspension completely IVD.
  3. Mar 7, 2019 at 10:29 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Because there is really no advantage to it.
    Bajakits also offers them but LCA are upgraded when moving to a long travel kit because the control arms are longer and thus both replaced.
    Upper control arms are really only upgraded to provide better alignment and minimal increase in shock travel.
    Long travel kits are sold as a kit so there really isn’t a reason to run two different brands.
  4. Mar 7, 2019 at 10:33 PM
    ERod27
    Eddie
    2019 TRD OR DCSB
    Makes sense now! Thank you!
  5. Mar 7, 2019 at 10:52 PM
    JoeCOVA
    Joe
    Colorado Springs
    tcjacado and whatstcp like this.
  6. Mar 7, 2019 at 11:26 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Secondly, do you really want your CV/axles flexing at a severe angle?
    Only so much travel you can get out of stock CV/axles before you sacrifice reliability.
    tcjacado likes this.
  7. Mar 8, 2019 at 12:28 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I would be curious to see what TC and Baja says. I decided to run them for a few reasons.
    1. aftermarket LCA ads Zerk fittings which allows the servicing the bushings
    2. Bushing are easy to replace
    3. They are lighter than stock
    4. Supposedly stronger
    5. Better ground clearance in the Race version
    6. Running secondary bypass
    7. According to TC you gain around a 1" of useable travel with the combo.
    If you are trying to max out a mid travel setup its a nice add. Myself and a few buddies are running the TC standard race version and the front end does feel nicer than it did stock. Very smooth or more so than the stock setup. Truck ran great without them but adding the bypasses the TC was more of a good add for me. Already deep into the mid travel setup so pushing it as far as I can.
    tcjacado and ERod27 like this.
  8. Mar 9, 2019 at 7:53 AM
    ERod27
    Eddie
    2019 TRD OR DCSB
    That's kinda my thought process with my mid travel set up. I emailed TC this past Thursday, but they haven't gotten back to me as of yet. Would upgrading my LCAs like you did widen the stance of my rig?
  9. Mar 9, 2019 at 8:44 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    From my perspective, it would be nice to see some 4130 tube and boxed LCAs At stock dimensions based on the strength and peace of mind. There’s gotta be a strength difference between that and stamped/hydroformed sheet metal. Not that I’ve ever broken a LCA... but ive upgraded sillier things with the “it’s STRONGER!” Idea. Oh and they look nice.
    ERod27 and tcjacado like this.
  10. Mar 9, 2019 at 9:31 AM
    nudavinci64
    Robert
    Depends which LCA you order. If you get the stock race version with dual shock mount you need to run a 1.25” spacer. Depends which rims too. I have 1” on my original Ray10’s. Or you can get a 3.5” bs wheel like the new Ray10 or F5 which I have to get mounted. In The end it will be wider. The single or standard version does not require spacers
  11. Mar 9, 2019 at 9:51 AM
    ERod27
    Eddie
    2019 TRD OR DCSB
    I have T4R PRO SEMA rims. I'd rather not run a spacer (most because people tend to tell me to stay away from those), but I'm wanting to see what TC reps say. I emailed Camburg reps too.
  12. Mar 9, 2019 at 10:44 AM
    nudavinci64
    Robert
    Well my last statement is based on taking to TC and the instructions. If you get non race or single shock no spacers needed. Spacers are relative. Plenty of people run them just need to ensure you have good ones and check them. But o agree which is why I got the new rims.
    ERod27[QUOTED] likes this.
  13. Mar 9, 2019 at 1:14 PM
    CaptainTikihut
    NorCal
    TC’s factory length LCAs are not compatible w lower bushing rod end coilovers (OEM Pro Fox) so I’m going to most likely get Dirt King, Baja or the new Camburg once it’s released.
  14. Mar 9, 2019 at 1:24 PM
    ferntr33
    ferntr33 Well-Known Member
    That’s bad ass. I see advantage is to add a bypass without going long travel. I’m waiting to see what the marlincrawler kit is coming out. Moving hub forward and inch will make running larger tires easier.
  15. Mar 9, 2019 at 1:25 PM
    nudavinci64
    Robert
    That would prevent you from getting them yes. If you mentioned that I did not notice. For the price of the lowers I would swap to different extended coilovers so you can get any of the travel improvement. Not sure if you'll see much difference on the OEM setup.
  16. Mar 9, 2019 at 1:26 PM
    nudavinci64
    Robert
    the secondary bypass was a big part of me getting it. I already had the bypasses.
