Lower Control Arm camber / caster eccentric adjustment frame tab broken
Discussion in 'Suspension' started by xodeuce, Mar 21, 2011.
  1. Mar 21, 2011 at 12:47 PM
    xodeuce
    xodeuce [OP] mmmmmmbourbon.
    Alabama
    2004 UZJ100
    I took my truck to the dealership to get it aligned after installing an OME kit. 885's, shocks, and LR UCA's up front. The dealer took 2 hours aligning it, and then came to inform me that "they couldn't get it in spec," and that I needed to take it to a specialty shop. I told them I did not feel like I should pay for the alignment if they couldn't get it done correctly. They also seem to have installed the eccentric washers upside down. I got out for $49.
    This morning, I took it to an off road shop that does alignments on lifted vehicles all the time. They explained their alignment procedure, it sounded solid, so I left it there. They called me a couple of hours later to say that they pulled the skid plate off to do the LCA adjustment, and that the tabs were bent preventing them from being able to adjust the eccentric fittings to complete the alignment. I told them to take pics and send them to me, take the truck off the rack, and I would take it to the last person that touched the LCA (Toyota dealership,) and see what they said.
    Basically Toyota says that the other shop did it, that "This is a common problem, and our guys know not to do it. You have to loosen the adjustments from the front, if you do it from the back it will do this."
    Anyway, according to Toyota, they'll just try to bend the tab back in place, and if it breaks, they'll "send it over to the body shop and get it welded right up."
    The off road shop said the same thing, but they said regardless of if it breaks or not, they want to pull the LCA so that they don't melt the bushings when they weld right next to where they mount, then put a bead on either side of the tab, and grind the interior surface flat so that the eccentric washer sits flat. I'm no expert, but that sounds like the correct way to do things.
    Any pointers or tips?
    Pics below:
    G3T LO5T likes this.
  2. Mar 21, 2011 at 12:50 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    The bead is the best solution for this fix. Check out BJmoose's full install on the OME lift kit. He had the same issue.
  3. Mar 21, 2011 at 12:56 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Extremely common issue. The bead solution will hold up better than simply bending the metal back in place.
    Since you'll have stuff pulled apart anyway, make sure they lubricate the parts before reassembling everything. The alignment cams are not lubed from the factory and tend to seize in the LCAs.
  4. Mar 22, 2011 at 11:16 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    fairly simple fix shouldnt be too much :) a shop bent mine over, went to DMZ and tim hooked me up!!
  5. Mar 22, 2011 at 11:30 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I think they welded mine "in place."
    You'll blink when you see the shop rate labor estimate to remove-repair-reinstall both LCAs.
  6. Mar 22, 2011 at 11:37 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Same thing happened to mine. Bent back and shop said if it happens again he'll just put a bead on it.
  7. Mar 22, 2011 at 1:20 PM
    xodeuce
    Alabama
    2004 UZJ100
    Any worry about melting the bushing? Or did they just do a series of tacks to keep it from heating up?
  8. Mar 22, 2011 at 1:28 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Shop didn't mention anything about the bushing, and I wasn't there to observe their technique, sorry.
    I got hit for three hours labor total, IIRC. So it's possible they pulled each bolt and bushing separately before welding down the bead.
  9. Mar 23, 2011 at 12:37 AM
    plee33
    Peter
    Sacramento, CA.
    There any way you can go under and take a picture of how they bead yours.
  10. Apr 6, 2011 at 6:05 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  11. Dec 6, 2016 at 2:21 PM
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
    Thread revival!
    For those of you who have had this fixed with a bead, was the bead run on the outside of the tab after bending it back into place?
    I am taking mine to a welder here in town and I want to make sure we are both on the same page when I tell him what needs to be done.
    Thanks.
  12. Dec 8, 2016 at 7:48 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    Yes on the outside of the tab.
  13. Nov 28, 2017 at 10:08 AM
    PetraD5
    PetraD5 New Member
    At first the ecentric bolts are all frozen and nothing wants to move so the cams on the camber bolts want to jump the tabs. The solution is lift the front tires off the rack and get everything moving. Then set it back down. If they set the tires on plastic grocery sacks they will silp into place easier than without. I didnt put anti seize on the bolts, but when i take my truck in to have the alignment perfected im going to take anti seize with me and have them apply it to the camber bolts.
    I did not have to weld my tabs, but you could see the cams were wanting to jump over the tabs when the tires were on the ground.
    I lost my positive camber angle when i replaced my front struts and the tires were wearing on the inside. The shop that works on my truck was 3 days out so i tried to set the camber using a bubble and digital level. We used a string to true the front wheels to the back wheels and a tape measure to set the toe (1/8" in, in the front). The digital level was on my android tablet and didnt work so good so we used the bubble level and eye sight and the string looped over the back end of the back springs. (Other people (on you tube )used 4, 5 gal buckets and 2 strings and a tape measure to square the strings).
    Because the caster setting is set with the camber bolts it makes it very difficult and maybe imposible to set the caster angle at home. Someday... with a little more practice I should be able to work on my front end and then set everything back up without loosing tread on my tires.
  14. Jan 25, 2018 at 7:11 AM
    Galacticmartian
    Galacticmartian New Member
    Ty
    17 gx460 07 350z
    None yet
    CD91D57C-F338-4BD9-8B8F-55A24265342C.jpg CD91D57C-F338-4BD9-8B8F-55A24265342C.jpg F81FD6C7-0EFC-4BB5-B00D-C473D2169F3F.jpg I don’t have a Tacoma but my 2017 fj150 gx460 with only 9k miles on it has this problem currently but is not bent completely, I work constantly so I couldn’t look at the truck my self for about two weeks, I heard this clunking noise while I pulled in and out of my garage after the truck was aligned at my closet Lexus dealer, I took it back in for service 3 times and explained to the service advisor what I was hearing took him for a ride he heard the noise and put it in for service, I get the truck back and I’m told it’s a normal characteristic of the fj150 and that the noise I’m hearing is the brakes unloading and shifting in the caliper, at this time I have to control my self because not only working on cars myself for 5 years before my current job and being Ferrari certified, I know what brake pads shifting sounds like and that noise is not it! I took the truck back in after not driving it for 3 days explained I wanted my u joint and lca bolts checked and was told by the dealer that the truck was deemed safe and they would no longer look at this issue. So I look my self and within 5 minutes and the light on the back of my iPhone I find the issue (see pictures) improper tightening of cam bolt resulting in eccentric depression of outer sub frame tab. If anyone has a clunking or loud click when shifting weight I would suggest to give your lca bolts a check and make sure your eccentrics are straight with the spec line.
  15. Feb 2, 2018 at 3:34 PM
    tijking
    tijking Active Member
    T.J.
    Florida
    2007 6spd
    Rockslayer Offroad front and rear 4 link SAS Dana 60 front axle Sterling 10.5" rear axle 5.38 gears Yukon Grizzly lockers front and rear
  16. Mar 8, 2019 at 4:45 PM
    G3T LO5T
    G3T LO5T Well-Known Member
    San Diego CA
    2014 4Runner SR5
    4" Maxtrac Spindles 3" All Pro Leafs 5100's Headlight Projectors HID Fogs K&N Short Ram Intake Flowmaster Exhaust PA Alpine
  17. Mar 10, 2019 at 11:35 AM
    tijking
    T.J.
    Florida
    2007 6spd
    I think its worth it to do the tabs if you wheel hard enough to bend the stock. I would say chances are you'll bend more of them as time goes on. I replaced the bolts/bushings while I was in there as well. And then I went SAS haha
    whatstcp likes this.
  18. Mar 16, 2019 at 7:32 AM
    G3T LO5T
    San Diego CA
    2014 4Runner SR5
    I agree, thanks!
  19. Mar 20, 2019 at 10:05 PM
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
  20. Jul 31, 2019 at 6:23 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    I’m looking to adjust my caster with my nonadjustable TC UCA’s. Hoping I don’t run into this issue...
