Lower ball joint symptoms
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Mar 11, 2022.
  1. Mar 11, 2022 at 5:40 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    I’ve been around long enough and had my fair share of ball joint failures before I wasn’t even knowledgeable about ball joints. My passenger side lower has been making a pop noise I recently had to take it out cause I replaced my front suspension with LT. I have a moog replacement already, but I haven’t gotten to it. Has anyone had pop issues then shortly losing the ball joint entirely? I had it off the truck and it has some spots that seem tough to push around it wasn’t loose or wobbly. But I’ve been told popping relates to the ball and the joint having play which I didn’t feel any.
  2. Mar 11, 2022 at 7:31 PM
    KStateTaco
    KStateTaco Well-Known Member
    James
    Kansas City
    01 Reg Cab 4x4
    Aftermarket LBJ's aren't going to last. I have a couple extras if you need one
  3. Mar 11, 2022 at 7:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just replace them, it really is a no brainer?
    JudoJohn and Nessal like this.
  4. Mar 11, 2022 at 7:50 PM
    Allex95
    allex
    Well yea lol but I mean the fact you can’t really test them to know if it’s bad, I was just asking cause sometimes they appear and move normal but fail anyways lol
  5. Mar 11, 2022 at 7:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can, the FSM lists a specific level of play that is within tolerance.
    Any more than that and it's due for replacement.
    MalinoisDad and Abeyancer like this.
  6. Mar 12, 2022 at 6:11 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    StihlToyota and JudoJohn like this.
  7. Mar 12, 2022 at 8:11 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    If you invested in LT, new OEM lower ball joints should be the equivalent of getting yourself a ham sandwich. Treat yourself to not kissing a roadway.
  8. Mar 12, 2022 at 8:38 AM
    ridefastflyfar
    ridefastflyfar Well-Known Member
    Tasche
    Hailey, ID
    '02 DCSB, '19 DCSB, '78 FJ40
    Yes, popping is bad. When this one came out it was galled, and explained the popping. My son drives this truck and he said it had been making a few noises prior. When we got in there, we ended up doing all four ball joints, one wheel bearing, and two CV axles. All in a student parking lot at Montana state. Not exactly Matt's off-road recovery, but was definitely dad's parking lot recovery.
    leid, Cloud99, DavesTaco68 and 5 others like this.
  9. Mar 12, 2022 at 9:50 AM
    Colorado Truck
    Colorado Truck Active Member
    Chuck
    1995 Tacoma V6, 5spd 4wd
    99 4-runner engine V-6 2007 Tacoma rims Late 1st gen electric side mirrors (and interior switch) Fabtech add a leaf lift Hella headlight housing for bulb only replacement SickSpeed "old school" gear shift knobs
    I thought I recalled reading that once you can “feel” play, it is well beyond wear standard for replacement- meaning, no way to know when it will fail which is why the recommendation to just change it…
    Considering the consequences if it fails.
    Nessal and MalinoisDad like this.
  10. Aug 19, 2023 at 12:08 PM
    YotaBro
    YotaBro Well-Known Member
    98 Tacoma
    what’s an acceptable amount of play? i have about 1mm of movement, just the slightest amount on my passenger side but driver side is ok, should i replace?
  11. Aug 19, 2023 at 12:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The video posted above lists how to check for play.
    My personal opinion; unless I know without a shadow of a doubt that the LBJs on my truck were recently replaced with OEM parts, I'd just replace them.
    Did that when I got my Tacoma and same with my 4Runner. It ain't expensive and it'll save tons of potential headache.
    Nessal likes this.
  12. Aug 19, 2023 at 12:48 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    If you dont know this trucks history....
    .....this one of the first things you do.
    Move it to the top of the list.
    On a scale of 1 to 10.......these are about a 2....
    This just happened to my neighbor's ram two weeks ago.....
    backed out of his drive....and made two houses......then
    BAMB!
    Everybody on the block heard it.....
    At least it was on a sunday morning.....
  13. Aug 19, 2023 at 12:54 PM
    O'Silver_Taco
    MD
    I prefer the premium ones from napa.......the one's with the grease zert.....
    the oem ones are on the same level as their denso radiator,....
    that is 'barely adequate' ......
  14. Aug 19, 2023 at 1:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Yes. Without question.
  15. Aug 19, 2023 at 1:09 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Moogs are $100 for both lowers. You can change both in under 30 minutes. I like Moog because they're greaseable.
  16. Aug 19, 2023 at 1:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Never stated they were difficult to replace or that it took long at all. Not much more either for OEM.
    But due to the design, I'd opt for the strongest I could get which is why I'd recommend OEM lbjs as well as OEM bolts.
    Your truck not mine, you do as you wish.
  17. Aug 19, 2023 at 1:18 PM
    tacoman2001$
    Never said you were wrong OEM is great. They're $100 each for OEM plus bolts. Anything is better than a worn-out balljoint though. If you ever have doubts about a ball joint or suspect a noise I'd replace it.
    Kwikvette[QUOTED] likes this.
  18. Aug 19, 2023 at 1:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    100% agree.
  19. Aug 19, 2023 at 4:40 PM
    02hilux
    Planet: EARTH
    Tons is the only solution....
  20. Aug 19, 2023 at 4:42 PM
    tacoman2001$
    King pin dana 60
