Lower ball joint replacement or whole lower control arm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Swamp Donkey, Apr 29, 2013.
  1. Apr 29, 2013 at 10:17 PM
    Swamp Donkey
    Swamp Donkey [OP] Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    From doing a bit of searching, seems like replacing a lower ball joint is a major pain in the arse. Buying a whole lower control arm seems like a waste of money. 450 bucks for a Genuine Toyota lower control arm. 85 for a moog ball joint. Just a hair over 400 for a jobber part at Bumper to Bumper.
    I did not find a good write up on how to replace a lower ball joint. Anyone got some advice?
  2. Apr 29, 2013 at 10:19 PM
    CGtaco
    CGtaco Well-Known Member
    Phillip
    07 Tacoma TRD 4x4
    Fog light Mod Total Chaos UCA's Front Icons Rear Icon / res
  3. Apr 29, 2013 at 10:20 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You have to have a way to press the ball joint out and a new one in. You could buy the ball joint and take it to a shop and have them press it if you don't have one.
  4. Apr 29, 2013 at 10:52 PM
    Swamp Donkey
    Fort St John B.C
    LOL. Thanks for the link! At least it was not a "sticky." That would have made my search extra lame! :eek:
  5. Apr 29, 2013 at 10:57 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    I have same prob bad joint. bought LCA for $138.00 from ebay. gonna install this weekend. It looks solid so Im feeling comfortable. only time will tell.
  6. Oct 3, 2017 at 2:23 PM
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
  7. Oct 3, 2017 at 2:31 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I had both LCAs replaced with moog balljoints came with it an got an can bolts also. They are greaseable an totally just as good as stock I have not had not one issue with them. Here’s a side by side pic of the 2.
  8. Oct 3, 2017 at 2:54 PM
    T MAC
    T MAC Well-Known Member
    Tim
    Foothill Ranch, CA
    11 TRD Offroad
    I replaced both of mine with Moog units as well. Their country of origin is China which bothers me a bit, but they are a stout oem replacement. Welds looked good, who knows the quality of the steel used unfortunately. I replaced my alignment hardware with oem when I did mine as one side was seized. Applied a liberal coating of anti-seize to the hardware. I've been running the LCA assemblies for about 10k miles, so no long term results yet, but no issues. I will press new joints into my oem LCA's and swap those back if/when the time comes.
    Both lowers were under 300, and I had it finished up in four hours - most time consuming part was cutting out seized alignment cams.
    BandanaBerg likes this.
  9. Jul 12, 2018 at 6:34 AM
    nwilli10
    nwilli10 Well-Known Member
    Nick
    Houston, TX
    07 Tacoma Double Cab TRD Off Road
    Where did you order your MOOG parts from? Trying to find the best deal on them....
    singletrack_ftw likes this.
  10. Mar 24, 2019 at 4:40 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    It’s almost impossible to find the Moog lower ball joints by themselves. Seem to only find the entire assembly.
  11. Mar 24, 2019 at 4:41 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Although I am finding some joints from 1A-Auto, anyone have experience with this company?
  12. Mar 24, 2019 at 5:12 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    They’re some no name brands on eBay, they seem to be wel contracted units.
  13. Mar 24, 2019 at 5:15 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I’m finding tons of other brands I’ve never dealt with or some I’ve never heard of, but honestly the prices are awesome. My thing is, I haven’t really been able to find a person that has had serious issues with these offbrand parts. Everyone bashes them, but can’t show me a failure that’s caused by the part itself. (Failure from off road or trail use doesn’t count).
  14. Mar 24, 2019 at 5:18 PM
    TegoTaco
    Ontario, Canada
    Exactly! I’m due soon for a replacement, I can get a set of both the left/right for under $300cdn. Can’t be any worse than my LBJ that are leaking.
  15. Mar 24, 2019 at 5:30 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I thought about doing the entire lowers. But honestly I just spent a crap load of money on other parts. And the only part that I could see for sure that needed replacement was the ball joints. So I may end up just getting those and keeping the stock arms. Also need new tie rods, but I can’t tell if my inners are bad, just the outters are obvious
  16. Mar 24, 2019 at 6:07 PM
    Jethroww
    Jethroww Member
    Cambridge, Ontario
    2009Tacoma2.7 4x4
  17. Mar 24, 2019 at 7:52 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Mannn, you’re killing me. Just ordered full set of lower control arms. I blame you.
    The only didn’t I didn’t order was the alinement bolts. I’m really hoping I don’t have to, because the OEM ones are ridiculously priced. And the aftermarket ones break when doing an alinement from what I’ve heard from a lot of people
