Lower Ball Joint Broke
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98RedSR5, Sep 21, 2019.
  1. Sep 21, 2019 at 5:36 AM
    98RedSR5
    98RedSR5 [OP] Active Member
    Greetings to the Folks of Tacoma World. I recently had a part snap off while driving and am in need of an affordable fix. Instead of going to a mechanic and spending who knows how much, I decided to enlist the help of someone who is retired and see if he is able to fix it in my driveway. I am wondering what part would fix the issue at hand. Pictures attached. Thanks in advance for any tips/suggestions.
  2. Sep 21, 2019 at 6:33 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Looks like the lower ball joint. If it broke while driving you may have broke or bent other parts. How fast were you going? This is a weak point for 1st gen Tacomas, and many members here replace the ball joints proactively.
    You should edit the title of this thread to say something about "Lower Ball Joint Broke" and you will get more responses.
  3. Sep 21, 2019 at 7:26 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    98RedSR5[OP] and Black DOG Lila like this.
  4. Sep 21, 2019 at 8:09 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to YodaWorld what he said ^
    98RedSR5[OP] likes this.
  5. Sep 21, 2019 at 9:21 AM
    98RedSR5
    Dr Z, I was driving around 65 mph. The tire went sideways I was lucky to not get into a serious accident. Thanks for the tip! Ill purchase a Lower Ball Joint when I get the chance. Besides that, anything else you think I will need?
  6. Sep 21, 2019 at 9:23 AM
    98RedSR5
    Wsidr1, thanks for your reply.
    I clicked the link you sent and it said the part is for 4WD.
    Will that make a difference?
  7. Sep 21, 2019 at 9:29 AM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    Yes you need to make sure it fits your truck. Ball joint failure can be serious as you found out. Buy a good replacement part, OEM if you can afford it.
    You should have someone look around at both sides and see if anything looks bent or has any wear that the other side doesn't. You should get an alignment after installation as well, and they will let you know if it's alright.
  8. Sep 21, 2019 at 9:35 AM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    You should replace the lower ball joint on the other aide while you’re at it. They’re pretty easy to replace and it would prevent you from worrying about the other side breaking as well
    DrZ and BillsSR5 like this.
  9. Sep 21, 2019 at 9:58 AM
    98RedSR5
    Thanks underaroof.
    do you recommend AutoZone as a place to order a Lower Ball Joint?
    Someone I met recently has offered to fix it in my driveway. do you think that is possible?
    Thanks again!
  10. Sep 21, 2019 at 9:59 AM
    98RedSR5
    Ok. so replace both lower ball joints. anything else to fix besides that?
  11. Sep 21, 2019 at 10:00 AM
    98RedSR5
    Thanks underaroof.
    Thanks again!
  12. Sep 21, 2019 at 10:11 AM
    Madjik_Man
    Colorado Front Range
    The consensus is to order OEM ball joints. Even though they are a weak point in this truck they will be vastly superior to anything you buy at auto zone. The other consensus opinion is to buy those 555s from Low Range.
    Good luck. At that speed during failure, you should really check everything. Eg your spindles, etc.
    GQ7227 likes this.
  13. Sep 21, 2019 at 11:08 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Yes, LBJs can be replaced in your driveway or in your garage, and by you, if you have the right tools (ball joint separator and a torque wrench). And be sure to have the front end aligned when you are finished.
  14. Sep 21, 2019 at 11:36 AM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    I wouldn’t worry much about any other parts unless they look damaged. Once you replace both lower ball joints (go with OEM Toyota for piece of mind) have an alignment shop try to align it. They’ll tell you if anything else seems out of whack
  15. Sep 21, 2019 at 11:39 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Do Not buy a lower ball joint from AutoZone. If you can't afford the OEM Toyota part then at least do the Moog/Sankei 555 branded one.
    Lower ball joints are a common weak point on these trucks as you've found out, and cheap aftermarket ones are even more likely to fail.
    Its a very easy job with the right tools, where are you located?
    underaroof and CS_AR like this.
  16. Sep 21, 2019 at 11:40 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    OEM the best if can spring the money$
  17. Sep 21, 2019 at 11:42 AM
    eon_blue
    Azusa, CA
    If I recall I got my oem LBJs for around $110 each from toyotspartsdeal.com. Basically just a conglomerate website that sources the cheapest OEM prices from dealers all over the country. Good way to find cheap OEM parts but if you have an issue with your order the return process is brutal.
  18. Sep 21, 2019 at 11:51 AM
    BillsSR5
    bill
    2014 SR5
    at one time there was a recall on the LBJ's for certain year gen1 TACOMAS my 2004 had them replaced for free by the dealer, wonder if the OPs truck even had them done if you run the VIN to find out might get a freebie from Toyota corp.https://www.toyota.com/recall I don't think theres a timeline limitation on recalls
  19. Sep 21, 2019 at 11:52 AM
    98RedSR5
  20. Sep 21, 2019 at 11:57 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    View this video before you start. I borrowed the pullers I needed from O'Reilly. Other parts stores loan the tools. Don't forget to use loctite thread locker on the BJ bolts.
    https://youtu.be/bfLvtEnX9qk
    underaroof, GQ7227 and eon_blue like this.
