Lower Ball Joint boot leaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by asarhangpour, Nov 15, 2021.
  1. Nov 15, 2021 at 8:00 PM
    asarhangpour
    asarhangpour [OP] Member
    2018 Tacoma TRD Off-Road
    Hi all,
    Just got back from off roading in Ocotillo Wells and noticed my lower ball joint boots were leaking grease on both sides. What’s the fix for this? Or is this normal? I’m not sure.
    Thanks!
  2. Nov 15, 2021 at 8:06 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Wipe the grease off and check for torn boots. If the boots are torn, they should be replaced.
    bulalo likes this.
  3. Nov 15, 2021 at 8:13 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    normal imo
    Big tall dave likes this.
  4. Nov 16, 2021 at 7:24 AM
    asarhangpour
    Ok thanks, I will check that out.
  5. Nov 16, 2021 at 7:58 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    On a serviceable ball joint this is normal. There are usually some holes for venting when greasing. So if it has a zerk fitting you're good. If it is not serviceable and has no zerk fittings then that is an indication that it is torn. The nonserviceable ball joint boots do not have holes.
  6. Nov 16, 2021 at 12:00 PM
    JustDriveItYo
    JustDriveItYo Member
    2nd gen taco
    Stocker, not even a locker
    I would replace everything in that picture
  7. Nov 16, 2021 at 2:26 PM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    why?
