Low Tire Pressure Light Stays On
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raymondo17, Feb 6, 2020.
  1. Feb 6, 2020 at 12:45 PM
    Raymondo17
    Raymondo17 [OP] Well-Known Member
    Ray
    Sacramento
    '06 PreRunner
    Last week I had my tires rotated. Yesterday I noticed my tire light was on, and I thought it odd since my '06 Tacoma was just in the shop. I took my kid to school, then let the truck sit for two hours and checked the pressure in all four tires. I found that all four tires were overinflated, one as much as ten pounds over the PSI specified in the door jamb! I went around and deflated each tire to the recommended 29PSI. But this had no effect on the tire light -- it stayed lit. Could my deflating the tires have caused some weirdness in the system? Could the overinflation have caused issues? What's my next move, take my Tacoma into the dealer?
  2. Feb 6, 2020 at 12:47 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Have you checked the spare tire?
    Muddinfun, EdgemanVA and rnish like this.
  3. Feb 6, 2020 at 12:47 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Is there a sensor in the spare?
  4. Feb 6, 2020 at 12:49 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Yep
    Beer:30[QUOTED] likes this.
  5. Feb 6, 2020 at 12:54 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    QMEDJoe likes this.
  6. Feb 6, 2020 at 1:03 PM
    KILLINTIME
    KILLINTIME Like a Villain
    Took mine out a long time ago, they are pretty useless.
  7. Feb 6, 2020 at 1:04 PM
    TacoTuesday!!
    TacoTuesday!! Well-Known Member
    '10 Metallic Gray 4.0 V6 4x4 DCLB
    6 in Rough Country Lift, Body Armor Front and Rear Steel Bumpers, Spare Swingarm, Smittybuilt X2O Winch, ProComp rims on 35"s, Bilstein 5100 shocks, Tuff Country UCA's, Wheeler's Off-Road multiple leaf add-a-leafs, BlackOak LED fogs, BlackOak LED backup lights, Rough Country curved light bar, Yakima Roof Racks, Morimoto Projector Headlight conversion with Halos, smoked tail lights, Grill Raptor lights, Custom Grill with Tacoma lettering, Studded Fender Flares, Bedrail quickgrips, Diamondback bed topper, VIAIR onboard air, Train horn, Viper remote start alarm system, Katskinz leather interior, 2x12” JBL subs, and more
    how did you get the light to shut off after you removed your TPM's?
  8. Feb 6, 2020 at 1:07 PM
    KILLINTIME
    Put a piece of black electrical tape over it. :rofl:
  9. Feb 6, 2020 at 1:11 PM
    TacoTuesday!!
    tempted to...I'm guessing the real solution is tear apart the dash and remove the bulb
  10. Feb 6, 2020 at 1:13 PM
    KILLINTIME
  11. Feb 6, 2020 at 1:17 PM
    TacoTuesday!!
    thanks for the link. took a look at it briefly and holy s* that looks more complicated than my pay grade
    disconnecting the signal box seems like a good alternative
    KILLINTIME[QUOTED] likes this.
  12. Feb 6, 2020 at 1:24 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    Thanks for the quick replies here.
    I have not checked the spare. But now that's on my to-do list. I guess, auto shops don't typically do that as part of the tire rotation?
    Regarding a faulty sensor, I will say that about two months ago while driving on the freeway, my TPMS light did come on, but it was blinking. I pulled over and checked my tire pressure, but they were fine, so I thought it must be a faulty sensor. But the next day it was fine and hasn't come back on flashing since. If it was faulty, wouldn't it flash as opposed to be steadily on?
  13. Feb 6, 2020 at 1:26 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    Il Capo, thanks for the video. But I gotta say that in nearly a decade and a half of owning my truck, I have never noticed that button. I'm nowhere near my truck to go look at the moment, but I'm wondering, is that button standard equipment in the '06 Tacomas?
  14. Feb 6, 2020 at 1:26 PM
    Ren
    Ren Well-Known Member
    Denton, TX
    White 2012 Pre-Runner DCSB
    If you've checked your tires and they are all the correct psi, then you probably just need to reset, which basically reprograms to the new pressure setting. I believe someone posted a video. Easy to do. Once you reset, the light should go off.
    If that doesn't work, then you may have an issue with a sensor.
    whatstcp likes this.
  15. Feb 6, 2020 at 1:27 PM
    TacoTuesday!!
  16. Feb 6, 2020 at 1:29 PM
    Muddinfun
    Muddinfun Well-Known Member
    Disconnecting the signal box above the headliner is the TPMS equivalent of unlocking a car with a tennis ball. Out of probably 100 TW members that have tried it, only the OP of that thread was able to make the light go out that way.
  17. Feb 6, 2020 at 1:36 PM
    TacoTuesday!!
    hmmm...thanks for the heads up. might not do that then. is cutting the wire to the TPMS ECU (https://www.tacomaworld.com/threads/complete-tpms-disable-guide.161292/) failproof?
  18. Feb 6, 2020 at 1:42 PM
    Muddinfun
  19. Feb 6, 2020 at 1:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    Remove this wire
  20. Feb 6, 2020 at 1:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    See if this works...
