Low speed grinding noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turtletacoma, May 21, 2020.
  1. May 21, 2020 at 4:26 PM
    Turtletacoma
    Turtletacoma [OP] New Member
    Mississippi
    13 Taco TRD 4wd 4.3l
    New board member. Bought a 2013 Taco 4wd April 30. Two weeks later the belt breaks. Took it to mechanic and the alternator was bad and the belt that broke messed up the front crank seal. He go all that fixed.
    Two days after getting it home it started making a weird grinding noise. Noise only happens when I pull in the driveway at slow speeds with the wheel turned or in reverse with the wheel turned. Only lasts for about 2 seconds and then it quits. Any ideas?
    Also, mechanic noticed it didn’t have a front skid plate. Any suggestions on a skid plate for just regular road driving?
    thanks
  2. May 21, 2020 at 4:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Welcome to the forum. Find your regional thread and ask in there if anyone has a stock skid laying around. You’ll most likely get it for free. As far as the noise, what size tires do you have? Are they larger than stock? Could just be it rubbing on some plastic.
    tcBob and tinker_troy like this.
  3. May 21, 2020 at 4:37 PM
    Turtletacoma
    Mississippi
    Thanks for the fast reply. Tires are brand new Kelly Edge HT 265/70r16
  4. May 21, 2020 at 4:47 PM
    Zersko
    Zersko Well-Known Member
    Northeast
    2016 Tacoma SR5
    I think the noise you’re hearing is the tire rubbing. I put 265 tires with deep tread on when I first bought mine and had the same issue in slow, sharp turns. Welcome to TW.
  5. May 21, 2020 at 4:52 PM
    Toytoa4life
    Toytoa4life Well-Known Member
    Koro
    New Brunswick, Canada
    2012 Tacoma SR5
    I second, or third the tires rubbing. I have the same size as you the catch every now and then at full lock or when tuning over the right bump. Seems to happen more in reverse.
  6. May 21, 2020 at 5:01 PM
    Turtletacoma
    Mississippi
    Many thanks. Hopefully it’s nothing to worry about
  7. May 21, 2020 at 5:47 PM
    Zersko
    Northeast
    2016 Tacoma SR5
    You can also have someone else drive your truck into the driveway really slow so you can see how bad the rubbing is.
  8. May 21, 2020 at 9:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you are still running the front mud flaps.
    Check them for rub marks. You “usually” don’t see this issue until 265/75/16.
    But as some have noted, there are some 70’s that will rub.
