Low Clutch Fluid Reservoir?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Sep 12, 2015.
  1. Sep 12, 2015 at 2:07 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey all,
    I was detailing my truck today and checking the fluid levels, and I noticed that the clutch fluid was low : 256fcd840d808143dea52c01dbf09256_336915889652300f8fc4881c9bb9171702a68d2f.jpg
    It's not below the minimum, but it's semi close. I haven't experienced any issues with my transmission or with shifting, and I also do not have any fluids leaking from my truck. Can I just top it off?
  2. Sep 12, 2015 at 3:19 PM
    Tjsingle26
    Tom
    PA
    Anyone?
  3. Sep 12, 2015 at 3:30 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    That is your BRAKE reservoir. It gets low for only 2 reasons, you might have a leak in the Brake lines, caliper or rear brake expander, or it's time to replace the pads. DO NOT ADD ANYTHING BUT DOT4 BRAKE FLUID TO IT! Your tranny has nothing to do with it.
  4. Sep 12, 2015 at 4:00 PM
    Tjsingle26
    Tom
    PA
    Sorry I wasn't more specific, the picture I posted is of my clutch reservoir, the braking and clutch petal systems are separate
  5. Sep 12, 2015 at 4:05 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Still the same fluid, Tranny has nothing to do with it except pushing in the clutch. DOT 4. Same rule tho, it may be that the pressure plate/clutch is getting worn, causing the fluid to drop. Scared the heck out of me thinkin you would put in Transmission fluid (Either kind). As for the ABS light, what code is showing?
  6. Sep 12, 2015 at 4:19 PM
    Tjsingle26
    Tom
    PA
    Yeah no ATF in those reservoirs :). I will top off clutch reservoir tomorrow with DOT 4. I was a little hard on my clutch a week ago going up some steep grade on bigger rocks, so that may be a contributing factor. I drove over 200 miles after that with no issues with shifting, etc. So I think all I need is to refill it.
    In terms of the ABS light, the code that is being thrown is C0215/34, for the left rear wheel sensor. I cleaned the sensors and the casing on the rear axle and checked the wires. I am thinking that I may need to replace the sensor entirely.
  7. Sep 12, 2015 at 4:29 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    As the brake pads ware the calipers fill with fluid to make up for the space of the pad ware it is normal for the fluid level to drop it also is a good way to let you know it's time to checks the front brakes. Many people make the mistake of filling the cylinder only to have the fluid over flow when the brake pads are replaced.
    Tjsingle26[OP] likes this.
  8. Sep 12, 2015 at 4:40 PM
    Tjsingle26
    Tom
    PA
    That makes sense, thank you for the response. My actual brake fluid reservoir is at the normal level
  9. May 3, 2020 at 3:45 PM
    Vdubwizard
    Vdubwizard New Member
    Gary
    94 Toyota 4Runner, & friend's Toy-T100
    Rear springs on 94 4Runner Super charger by factory in 98 on T100 3.4l
    You MUST FIRST LOOK AT Your Reservoir Cap to see what it Recommends!!!! A 1996 T100 says Dot3 !!! So your fluid my differ! Thanks, G
  10. May 3, 2020 at 3:48 PM
    Vdubwizard
    Gary
    YOU MUST FIRST LOOK AT THE RESERVOIR CAP AND SEE IF THE RECOMMENDED FLUID IS ON THE RUBBER/PLASTIC CAP!!! A T100 1996 asks for Dot 3!!! Tx, good luck too all and, HI!! Gar
  11. May 3, 2020 at 3:50 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Do yourself a favor and flush/bleed the clutch master/slave cylinder. That fluid should be gold’ish. While you have it drained down clean all the algae off the side of the reservoir.
    2 places it can leak are around the master/slave pistons, worth some investigation. I have rebuilt them (there is an OEM kit), but the Denso replacements seem exactly the same as the originals as well.
  12. May 3, 2020 at 4:17 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    5 year old thread
    All Tacomas use DOT 3/4 fluid
    KdF likes this.
