Loud ticking noise in engine, should I be worried/make a fuss at dealer?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by winnipegbeachtacoma90, Mar 10, 2024.
  1. Mar 10, 2024 at 12:05 PM
    winnipegbeachtacoma90 [OP] Wer rastet, der rostet.
    Interlake
    23’ Blue crush A/C TRD OR
    My engine seems to be making quite a loud ticking noise when running? I can’t quite put my finger on it but it doesn’t sound normal and wondering if you guys have come across it and if it’s normal or worth making a big fuss over because I know the dealer will blow it off as normal. Also there’s lots of metal glitter on the dipstick when I wipe it on a piece of tissue paper. Lots of grey metal and it’s WELL past the break-in period. I’ll attach a photo after of oil but first here’s a video of the noise. Owned many trucks but never a Tacoma and never heard the engines make a noise like this.
  2. Mar 10, 2024 at 12:07 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It is a noisy little engine, but to be safe, I would take it in so it's documented. While you are there, and have their attention, I would compare it to a couple on their lot.
  3. Mar 10, 2024 at 12:11 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Glitter isn't good ever. You may see some first oil change due to break in of parts but past that, bad ju ju. If under warranty, take it in and quit driving it.
  4. Mar 10, 2024 at 12:15 PM
    Trail Limo
    Trail Limo Well-Known Member
    Might be worth sending a sample off to Blackstone. Can't hurt to bring it in and see what they say.
  5. Mar 10, 2024 at 12:20 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Make a fuss; no. But definitely change the oil and filter asap and save some for analysis. And do get the ticking noise looked at and documented by your dealer. That's about all you can do at this point. And remember, be nice! :)
  6. Mar 10, 2024 at 12:22 PM
    DesertIceCap
    DesertIceCap Well-Known Member
    Gasoline Forever
    What is "WELL past", 1001 miles, one year, three years?
    RIX TUX likes this.
  7. Mar 10, 2024 at 12:29 PM
    Interlake
    well if it’s this noisy and everything’s fine then ok, but I’ll definitely bring it up to dealers attention. I have a service 3 and full diffs, transfer, transmission oil change coming up along with engine oil as well. I’m surprised I’m seeing lots of grey glitter on the dipstick at 45,000 miles.
    Also sorry for lack of video and picture I keep trying to upload it but I can’t seem to make it work adding to my frustrations for the day.
  8. Mar 10, 2024 at 12:31 PM
    Interlake
    45x past 1,001
  9. Mar 10, 2024 at 12:35 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Is any noisier today, than it was when you bought it? That may alert you of an issue.
    I am not saying you don't have a problem, just that the engine is noisy, and this comes up often. Many around here seem to create problems in their mind, especially as warranty period comes to a close.
    Blak Shinobi likes this.
  10. Mar 10, 2024 at 12:35 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    45k miles on a 23 woah
    Barsoom likes this.
  11. Mar 10, 2024 at 12:40 PM
    Interlake
    Definitely louder than when I bought it. I’ll go get it checked out at the dealer. I’m just surprised I wipe dipstick on some tissue and it’s half grey half golden sparkling like some fairy princess.
  12. Mar 10, 2024 at 1:07 PM
    fxntime
    Save some if under warranty [just a couple of ounces] and send it in to see what metals are excessive. Pull it off with a small diameter hose under vacuum and drain it into a glass container. Before transferring it to the shipping bottle, shake it well to get all the metal particles into suspension.
  13. Mar 10, 2024 at 1:14 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  14. Mar 10, 2024 at 1:42 PM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    I would noy change oil, I would have dealer look at it first and have it documented. Then do oil+filter change and do UOA. If dealer wants to do oil change,drain some from the filter beforehand.
    Jakerou and Chew like this.
  15. Mar 10, 2024 at 1:53 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you have described it several times but a picture is needed or this post is just fairy dust
  16. Mar 10, 2024 at 6:44 PM
    Blak Shinobi
    taco
    n/a
    ikr how hard is it to post a pic , + we are not much help anyways
  17. Mar 10, 2024 at 7:41 PM
    eurowner
    eurowner Duke Sky
    Scoty
    :worthless::worthless:
  18. Mar 15, 2024 at 6:56 PM
    trevor1030
    trevor1030 Active Member
    Trevor
    23 Ice Cap TRD Pro / 23 Lunar Rock OR
    I’ve heard this can also be an injector cleaning cycle
