Loud squeaking from front passenger side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acmair, Apr 8, 2020.
  1. Apr 8, 2020 at 9:26 PM
    acmair
    acmair [OP] Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    Hey guys,
    I am running BFG AT KO2 285s on my 2010 Tacoma Double Cab with a level kit with Bilstein 5100s. I did it myself a year ago but did not replace the upper control arms or anything else.
    Lately, when I drive roughly 80 mph, depending on wind conditions, the truck makes a loud squeaking/whistling sound from the front passenger side. Has anyone experienced this? I've been watching videos about worn bearings and ball joints but the sound doesn't seem the same.
    Anyone have any suggestions or similar problem?
    Thanks!
  2. Apr 8, 2020 at 9:28 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Only at that speed? And why so fast? You in a rush all the time?
    It could be the plastics making the whistle. The squeak sounds like either the UCA bushing or the spring rubbing on something
  3. Apr 8, 2020 at 9:33 PM
    acmair
    Andrew
    Hahaha, I don't normally drive nearly that fast. Was on a 1500 mile cross country drive and it would make that sound during the drive.
    I've noticed it mainly when it's windy and I turn the wheel lightly to the left, while going at higher speeds.
    Thank you! I will look into the uca bushing!
  4. Apr 9, 2020 at 7:47 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    When you turn? Could be the steering rack or the tie rods. Although I doubt the tie rods. The issue is, since it's at high speed when it happens, it's very hard to pinpoint where the sound is actually coming from. It may sound like front passenger side. But you'd be surprised how driving can change how and where you think the sound is coming from.
    Try jumping on the truck up and down in different places while parked. Also try turning the steering wheel while someone is next to each wheel so they can look and listen closely
  5. Apr 9, 2020 at 10:02 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    You sure it's not the kazoo sound from the weather stripping? Happens during crosswind situations. I've had my truck for for 15 years, and only heard it maybe twice, but it's a well known issue with these trucks.
    SR-71A likes this.
  6. Apr 9, 2020 at 10:11 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Is it just speed sensitive or is it RPM sensitive? Does it do it in both 2 wheel & 4 wheel drive? Does the sound change in left or right turns? Does it change when you hit bumps?
  7. Apr 9, 2020 at 3:44 PM
    acmair
    Andrew
    Thanks, I think that's it! Did some googling after you mentioned it and came across this video. This is the same sound.
    https://www.youtube.com/watch?v=2gS4vM0OXo4
    JimIowa and Fitz235[QUOTED] like this.
  8. Apr 10, 2020 at 2:02 AM
    Fitz235
    Rob
    New Hampshire
    zengineer and JimIowa like this.
  9. Jun 14, 2024 at 2:50 PM
    dnhzz_
    dnhzz_ Member
    2015 white double cab 5 lug
    Fitz235[QUOTED] likes this.
  10. Jun 14, 2024 at 2:54 PM
    TacoAG2017
    TacoAG2017 Member
    Jonathan
    Aggieland, Texas
    2023 Ice Cap Tacoma SR5
    My 2023 SR5 squeaked bad from the rear leaf springs. It's a pavement princess and only has 7k miles. The dealer said the bushings were dirty so they cleaned them and the next day it was squeaking again. Now they are replacing all the bushings, springs and cab in all.
