Lot of issues with 2009 Tacomas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zimmer80, Jun 19, 2020.
  1. Jun 19, 2020 at 7:19 AM
    Zimmer80
    Zimmer80 [OP] Well-Known Member
    Found a couple of threads on here about what was best and worst years of the 2nd gens. On a chart it showed the 2009 and being the worst year. I found an 09 access cab near me i was considering looking at until i saw that graph. What exactly was wrong with the 09? I noticed on edmunds they got so-so reviews for that year model also
  2. Jun 19, 2020 at 7:24 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    That thread that showed the graph didnt say what the issues were? At the core, all 2nd gens are pretty much the same. '05 and '06 tend to have issues with the head gasket on the V6 so theres that.. And obviously the older the truck the more likely it is to have rust, thats just nature / physics.
    Right off the top of my head though I cant think of anything specific to 2009. That might have been the year traction control became a standard feature on all Tacos? And maybe they added the secondary air injection pump around that time.. Not 100% sure
    whatstcp likes this.
  3. Jun 19, 2020 at 7:25 AM
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    I had a 2009. I know they had issues with the radios...I went through 8 from the dealership. Otherwise, sames issues as all other years for the most part.
    HolycityTaco and whatstcp like this.
  4. Jun 19, 2020 at 7:26 AM
    DesertRatR
    DesertRatR My favorite dog is what I got.
    Southern AZ
    2019 TRD 4WD Off-Road
    I had one, bought new in 2009. Never had any trouble with it. I liked it a lot. Two years ago it got rear ended by a much bigger F350 that bent the frame so it was totaled. Grrrr .... I prefer the old V6 over the new one.
    BTW, I know it runs without oil! Well sort of. On its second oil change the shop forgot to add oil. The LP cutoff if killed it after a couple of minutes. Let's just say the shop owner and I had a discussion. I called the dealer service manager and he told me to drive it hard and get a few hundred miles in a few days. Then have the oil changed. Mean while get a test kit from the local CAT dealer and send a sample to their oil test lab. I put 700 miles on it over the weekend (during hot summer in AZ) and sent the sample in. It came back clean with no metal. I changed oil every 3K miles and sent in a sample for the next 10 or so changes. All came back negative. I did dodge a bullet on the one. Or the shop did.
    b_r_o and SR-71A like this.
  5. Jun 19, 2020 at 7:31 AM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Think they added the secondary air injection pump in 2012. I have a 2011 and to my understanding it does not have it.
  6. Jun 19, 2020 at 7:32 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I had a 2009 4-cyl MT Access Cab bought new, just sold it last week on TW. Only thing "wrong" was the radio that would turn itself off randomly. Replaced under warranty, then the replacement eventually started doing the same thing out of warranty. Replaced that one with an aftermarket radio. Couple of recalls... the major one was for the leaf springs. Also a seatbelt tensioner recall, and the "melting running lights" recall. But no repairs issues, just regular maintenance for 71k miles.
    HolycityTaco and PzTank like this.
  7. Jun 19, 2020 at 7:36 AM
    MoTacoX
    MoTacoX Well-Known Member
    I call BS on any notion the '09 is inferior. I've had one for year and a half and it's perfect. 155k miles going for 500
    SR-71A likes this.
  8. Jun 19, 2020 at 11:46 AM
    RockyMtTaco
    RockyMtTaco Well-Known Member
    OH (but longing for CO)
    2009 DCSB TRD OR 4.0L V6 (BSP)
    I purchased my 2009 DCSB TRD OR new on 3 July 2009. Since then, I've put 141,000 miles on it on both coasts and throughout the Rocky Mountains. I've even lived in the salt fields of Ohio for the last 3 years. I can honestly say, unequivocally, that it has been the best purchase of my life. The only problem I experienced was failed wheel bearings (1x) on my driver's side front. No radio problems. No head gasket issues. Minimal frame rust, but that's expected considering how the Midwest abuses their roads during the winter. No suspension issues, vibrations, wobbles, electrical issues, transmission issues, or otherwise. I do take deliberate steps to perform routine mx myself (synthetic oil changes every 6k miles, synthetic differential and t-case changes every 15k, grease the zerks, bleed the brake lines, clean the MAF, fully disassemble and thoroughly clean the throttle body... basic stuff). Again, in my opinion, this truck is incredible and has been beyond reliable and predictable for me during the last decade. I hope to take it to 350-400k miles minimum.
    SR-71A likes this.
  9. Jun 19, 2020 at 11:59 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I've had mine for about 8 years (can't recall exactly). The radio went south a couple of years ago. The springs were replaced in a recall; one broke just before the replacement. I replaced the original battery last year because I feared a failure when in a remote area. I guess the major reliability problem has been the hub caps--the springs that grip the lug nuts have failed on two or three wheels.
  10. Jun 19, 2020 at 12:26 PM
    Zimmer80
    Nevermind truck is still available. May go look at it this weekend. What all should i look at / questions to ask dealer before i consider purchase?
  11. Jun 19, 2020 at 12:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    2010 was the best year . Very few issues, and none major unlike 2008,2009, 2012, 2013, 2014
    Bodyguard89 and TACOMA2NDGEN like this.
  12. Jun 19, 2020 at 1:15 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    I call BS on those threads as well. I have a 2009 Tacoma SR5 Pre-Runner v6 AC with 113k, Love it. Zero major issues. But, what I would say is the OEM sound system is garage. Had all that replaced. I did have to replace the usual suspects for my milage:
    Tire pressure sensors, both wheel Bearing/Hubs, Charcoal canister, REM Alternator, Serpentine belt, Tension Pulley.
    I've owned a 93, 03 and currently the 09 by far my favorite
  13. Jun 19, 2020 at 1:38 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    False, 2013 was the best year unlike 2010
  14. Jun 19, 2020 at 1:58 PM
    TexasWhiteIce
    Texas
    nah...
  15. Jun 19, 2020 at 2:06 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I have an 09 with 107k miles on it. Bought it new and I can tell you it has never once broken down ir needed any repair. Yes now it needs some wear item attention but that’s it. There is no issue with the 09.
    theolee likes this.
  16. Jun 19, 2020 at 9:09 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Nothing wrong with 09 Tacoma's.
  17. Jun 19, 2020 at 9:14 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I have an 09, Off Road with RR locker. Brought it brand new. I Haven't had nothing but FUN with the truck. I've taken it places most people wouldn't take their trucks. I honestly am surprised it has NO leaks. I would buy the same truck, same year, same trim.
    Yes I ripped the tranny at 80k, I'm on my 3rd set of gears, not a single bolt is stock from the suspension (front and rear), etc, etc. Then again, this truck has seen and done some stuff. LMFAO
  18. Jun 19, 2020 at 9:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Cant believe everything you read on the internet, there's nothing wrong with an 09. People split hairs around here and we're all pretty spoiled in general with these trucks. They rarely break at all compared to other manufacturers
  19. Jun 20, 2020 at 12:15 AM
    241240
    241240 Sir Lurks-A-Lot
    09 base double cab 4.0 MT
    Sat my fat rear end in it.
    '09 owner with ~130k miles. The radio was a fun one...turn the volume knob and the volume would change, but in what direction it would change was randomly independent of what direction the knob was turned.
    Other than that, I got the recalls done for the rear springs and driveshaft joints. The clutch chirps. It's still dirty where the in-law's cows licked it...
  20. Jun 20, 2020 at 1:09 AM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    Got a 2010 here and I had radio issues. The dot display would go blank and stuff would be weird. I forget exactly what happened. Eventually it stopped doing that and worked again perfectly. Weird.
    Might be just me but I think the taillights on the 05-08 look super dated. The led tails on the 09+ are much better.
