Losing traction in snow in 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by kindashittymechanic, May 11, 2017.
  1. May 11, 2017 at 9:35 PM
    kindashittymechanic
    kindashittymechanic [OP] New Member
    Jake
    96 3.4 V6 Tacoma manual
    3" lift 33" tires
    Hey there guys, I need some serious help here. I bought a 96 3.4 V6 Manual Tacoma last fall. One of the main reasons for the purchase was to take it up to my local ski resort with the 4x4 which is not working out to well. When I get up into the snow and turn 4x4 I have to keep both hands on the wheel at all times. I can't go above 25-30 mph and it feels like the truck is crab walking sometimes. If I push the clutch in she immediately loses traction. It will pull left and then a few seconds later pull right. The way she drives is so terrible I have to turn around and head back. I looked on these forums and thought I had found the solution to my problem. I went to got a simple alignment and they found a few problems of their own. After fishing out myself what was really wrong I brought it to my local mechanic to fix the problems. Im pretty handy with cars but I know my limits. So $800, new Inner and outer tie rods, and control arms later, I thought my problem was fixed. I drove 3 hours to the mountain just to find out that nothing had changed and had to once again turn around. I dont know where to go from here. Ive heard the differential could be locked (it's not), different size or brand of tire (they're all the same), or tires are too wide or too worn (No idea). I dont know where to start. SOS! Please help!
  2. May 11, 2017 at 10:04 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Just throwing it out there you are in 4high right not 4low
  3. May 11, 2017 at 10:08 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    What brand and size tires? How much tread is left? Are you sure the 4 wheel drive system is working correctly, i.e. are all 4 tires spinning?
    Are you experienced driving in the snow? This time of year snow is usually pretty shitty to drive in, just gets slushy and instantly turns tires into slicks (at least where I live).
  4. May 11, 2017 at 10:39 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Tires will make a huge difference in the snow. If you are not sure how the tread is, show us some pictures of the tires and people on here can tell you if that may be the problem.
  5. May 12, 2017 at 12:34 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your 4wd is working like it should .
    There is snow and there is SNOW quite a difference .
    Why do you think The Inuit have so many different words for snow
    Then there is Snow with Ice underneath .
    Are you driving on snow pack or through a foot or more of fresh wet snow.
    Just like skiing or driving conditions change on a constant basis
    Why do you feel the need to go faster then 25 mph if conditions
    Sounds to me like you need more practice
    Temperature ,Tires and the weight in the truck as well as gear selection and rpm all play into the equation.
    Driving Style is adjusted for the changing conditions Over two feet of snow my Tacoma made it out the 500' driveway
    TacomaJunkie8691 likes this.
  6. May 12, 2017 at 5:42 AM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Dear Kind of Shitty Mechanic,
    Sorry to hear about your Tacoma doing strange things in the snow. All of these members responding to your thread have given you some pretty good advice. I have the same rig as you except for the fact mine is a few years newer. Our Tacoma has seen a fair amount of snow since my family has owned it for the past twelve years. They are not bad rigs in the snow. By design, pickup trucks have to be driven carefully in the snow because they are poorly balanced rigs especially the first generation Tacomas with the 3.4 V6 engine. This particular combination has a lot of power for a small wheel base lite weight pick-up truck. The best thing to do is to add weight to the bed if you are going to be going to the snow quite a bit. This will help balance your Tacoma.
    The other thing to remember is do what Wyoming said and drive slowly in the snow. These are pretty capable rigs if you pay attention and drive cautiously. For example, about ten years ago there was a huge snow storm in Western Washington. I had only had my Tacoma for a couple of years, and there was well over two feet of snow on the ground with an icy packed bottom layer. My Tacoma navigated through the storm just fine. I would just get in it and put the thing in first, and I would not try to shift gears or anything.
    Good Luck,
    Paul
    Hobbs, oldtoyotaguy and Wyoming09 like this.
  7. May 12, 2017 at 5:49 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Put a couple hundred pounds of sand in the bed. It'll help.
  8. May 12, 2017 at 6:20 AM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    The pulling right and left could be your front differential finding traction in the snow and sending power to one wheel and then getting traction on that side and sending power back to the other wheel this can go back and forth as you exelerate in low traction conditions.
    Wyoming09 likes this.
  9. May 12, 2017 at 6:28 AM
    vtframer
    vtframer Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    I live in VT and I put about 400lbs of sand bags in the back for the winter - trying to keep the weight centered over the axle
    ARCOVT16 likes this.
  10. May 12, 2017 at 6:32 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Proper tires and some weight in the bed will make a world of difference.
  11. May 12, 2017 at 6:56 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Some aggressive all terrian tires, proper air pressure, chains if its really bad, studded snoe tires, like others have said weight in the back helps alot, and not going fast you should be able to go just about anywhere, I would think 15 20 mph max
  12. May 12, 2017 at 6:59 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Have you verified the gearing in the differentials?
  13. May 12, 2017 at 7:15 AM
    JKO1998
    Utah
    Maybe go see if your 4 wheel drive works not in the snow.
    Get some chains too, they're awesome.
  14. May 12, 2017 at 2:14 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If I need to use Chains or think I might the chains are all ready installed on extra wheels in the bed .
    Lower the pressure in the tires install chains air them back up keeps the chains nice and tight
    A trick from long ago
    Having Worked for Ski areas we always keep the roads in great shape Skiers can`t get to the Hill no $$
    Unless your having a full out blizzard with whiteout conditions .
    Something just does not feel right in my younger days many vehicles got stuck on the access road 95% give me a ride to the mountain I will worry about the vehicle later snow conditions are great !!!
    I am thinking lacking experience maybe first 4x4 ??
    Maybe go with a friend that comes from a place with July and Winter
  15. May 12, 2017 at 2:23 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Are you in 4wd? Did you lock your hubs?
  16. May 12, 2017 at 2:37 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Sounds normal to me. Just sounds like someone with little experience in a 4x4 and/or driving in snow expecting to much. Like all the people who buy a 4x4 and think it makes snowy roads handle like dry pavement.
    TacomaJunkie8691 and aeok18109 like this.
  17. May 12, 2017 at 2:45 PM
    aeok18109
    aeok18109 Well-Known Member
    Ernesto
    1996 Blue Tacoma 4wd 2.7L 5sp
    ^^^^^^^^^^^^^^^^^yep my thoughts.
    get some good tires on there, weight in the bed and slow it down chief. you not gonna be doing 70mph uphill in snow with 4wd
  18. May 12, 2017 at 3:04 PM
    jsi
    jsi Well-Known Member
    native earthling
    Something's not right (duh).
    • When you are driving in the snow is it all snow or kind of patchy snow and pavement? Because patchy snow/pavement could cause that pulling to the left and right behavior. As will driving with spinning tires. Another, don't know how it could happen, scenario is you don't really have 4wd and it is front wheel drive only and you're feeling torque steer.
    • What do you mean it loses traction when put in the clutch? When you put the clutch in you will come to a stop, but I can't see how that would cause the tires to slide.
    • And where are you finding snow to drive in in May?
  19. May 12, 2017 at 3:05 PM
    GDT
    Troll
  20. May 12, 2017 at 3:36 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Hello kindashitty, (don't write that every day!)
    I think that a lifted truck with larger than stock tires compounds what you experience in the cab. I suggest you find an out of the way road and drive it in different gears in 4low and 4high at different speeds to get a feel for the truck. It is hard to know what is going on without knowing your driving style and what kind of tires you are running. Let the forum know what you are running and you will get a better response. Drive safe in the snow and ice.
