Losing coolant can't find the leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by 860yota, Feb 28, 2017.
  1. Feb 28, 2017 at 1:17 PM
    860yota
    860yota [OP] Member
    Hey guys got a 97 Tacoma 3.4 with a coolant leak..Havent found where its going but oil is clean so far.I did a head gasket replacement on this truck 2 years ago and changed everything but the radiator. Its not blowing smoke and when there is coolant it doesnt have oil in it. Any feedback would be great thanks..
  2. Feb 28, 2017 at 1:21 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Could be leaking on the top of the manifold and getting hot and burning off while running. Could be leaking around water pump and running backwards toward trans while in motion. Take the radiator cap off while it's running and see if there's bubbles indicating another leaking head gasket.
  3. Feb 28, 2017 at 1:28 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Can you smell coolant ??
    Just how much are you adding ??
    Hour ??
    Every day??
    Week ??
  4. Feb 28, 2017 at 1:33 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Pressurize cooling system.
  5. Feb 28, 2017 at 1:35 PM
    860yota
    860yota [OP] Member
    this what the coolant looks like I add about a half a radiator full every 3 or 4 days..and there are no smell of coolant so fartruck2.jpg
  6. Feb 28, 2017 at 1:38 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    do you have an automatic, and is is going into your transmission ?
    check tranny dipstick for....foam
    a 20 year old rad and automatic transmission is a ticking time bomb
  7. Feb 28, 2017 at 1:38 PM
    860yota
    860yota [OP] Member
    No its a 5sd
  8. Feb 28, 2017 at 1:40 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    head gasket, it is blowing out the tailpipe... it has to be at that rate of loss
    do the hobo taste test at the water drops in exhaust. dead simple nasty but safe enough test, sweet ? dead giveaway it's blown
  9. Feb 28, 2017 at 1:41 PM
    10MGM
    2010 AC MGM 4x4
    Remove spark plug and check for evidence of steam cleaning.
    Xbeaus likes this.
  10. Feb 28, 2017 at 1:43 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Looks like oil in the coolant. Cracked head/head gasket?
    cruiserguy likes this.
  11. Feb 28, 2017 at 1:44 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Check for a bad seal on your radiator cap/filler neck with a piece of glass.
    Loosing that much coolant and not seeing any sign has to be evaporating out a hose,cap or radiator.
  12. Feb 28, 2017 at 1:46 PM
    860yota
    860yota [OP] Member
    I did check the plugs there not steam cleaned and rad cap wasnt holding pressure so i changed it out as well
  13. Feb 28, 2017 at 1:48 PM
    860yota
    860yota [OP] Member
    The engine light is on for a knock sensor but i dont think would have anything to do with
  14. Feb 28, 2017 at 1:57 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    taste tailpipe [headgasket test] I'm tellin ya
  15. Feb 28, 2017 at 1:59 PM
    Caligula
    Los Angeles, CA
    It only works if you play 70's bow chicka chicka bow bow porno music when you taste it.
    Brian007Taco likes this.
  16. Feb 28, 2017 at 1:59 PM
    10MGM
    2010 AC MGM 4x4
    Pressurize cooling system and start engine. Water pump seals sometimes leak only when shaft rotating.
  17. Feb 28, 2017 at 2:15 PM
    860yota
    860yota [OP] Member
    I got buddy bringing me a pressure tester so I will try that and if that doesnt tell me anything Ill do the hobo test to some porno music..thanks guys
  18. Feb 28, 2017 at 2:20 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine was losing little bits and building a pink stalagmite behind the water pump pulley but wasn't any half a radiator worth, maybe half of what is supposed to be in the overflow tank was all mine was losing. That green coolant doesn't look the right color green to me. Somethin's up, 3.4 history makes me bet on bad head gasket..............isn't there one on one side that's infamous for this? Wanna say towards back of passenger side head
  19. Feb 28, 2017 at 2:35 PM
    10MGM
    2010 AC MGM 4x4
    It is indicating head gasket degradation but I prefer to check everything before diving into a major operation. Hobo test also works.
  20. Mar 2, 2017 at 9:03 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Are you over heating at all?
