Losing brake fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jul 31, 2024.
  1. Jul 31, 2024 at 2:58 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Discovered yesterday that my brake fluid resivor was dry. I haven’t found where the leak is coming from yet but I’m suspecting it’s coming from inside the passenger side drum. Lines look good, no obvious puddles or seepage. I’m about to go outside and take it apart and see how it looks. If it is coming from there is there anything I should be looking for specifically that’s causing the leak?
    wilcam47 likes this.
  2. Jul 31, 2024 at 3:04 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Brake cylinder rubber boot ends. It will be apparent if thats where its leaking from.
    Logans2001[OP] likes this.
  3. Jul 31, 2024 at 3:04 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    The drum cylinders, almost certainly what is leaking.
  4. Jul 31, 2024 at 3:06 PM
    MadNachos
    Wait...are you losing fluid after you add it or is the fluid level just low? If it's low it's because your pads and shoes are shot. If you add fluid and lose it, that's different.
    mjp2 and time623 like this.
  5. Jul 31, 2024 at 3:19 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    E-brake light was on for a few days. I thought maybe it’s just a sensor for the e brake. Yesterday I learned that it can also signal low fluid. Checked it, it was completely empty. Girlfriend went on a rescue mission to oriellys for fluid. Brought it to me. Topped it off. Drove home behind her a few miles. Checked it again and the level definitely dropped a little.
  6. Jul 31, 2024 at 3:38 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Welp..
    Black97v6MT and mjp2 like this.
  7. Jul 31, 2024 at 3:43 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Wasn’t expecting that. Thick black grease everywhere. Inside of the drum, brake assembly. So that would be an axel seal?
  8. Jul 31, 2024 at 3:56 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Does it smell like diff fluid? Pretty distinct smell. Could be brake fluid and brake dust together
    Jakerou likes this.
  9. Jul 31, 2024 at 3:59 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I think so. It’s pretty pungent. But it’s a lot thicker than diff fluid. This is thick grease.
  10. Jul 31, 2024 at 4:02 PM
    MadNachos
    That just looks like good moly.
  11. Jul 31, 2024 at 4:04 PM
    MadNachos
    You may have run it dry and may need to bleed the system. Brake fluid flows and you should see it on the inside of the wheels if it's leaking at the cylinders in the rear. Bleed it, check it after a few miles.
  12. Jul 31, 2024 at 4:06 PM
    MadNachos
    That's certainly not correct, I suppose that could be a mix of brake dust and leaking diff fluid. Doesn't really look like it from the pic though.
  13. Jul 31, 2024 at 4:16 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You'd see brake fluid running outta the drum if the wheel cylinder failed. You're looking at a blown axle seal.
    If you're low on brake fluid and you can't find the puddle, it'll be in the brake booster.
    mjp2, JJ04TACO and Logans2001[OP] like this.
  14. Jul 31, 2024 at 4:32 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Brake booster was my next suspect.
    JJ04TACO likes this.
  15. Jul 31, 2024 at 8:13 PM
    MadNachos
    You may be correct but blown axle seals don't cause brake fluid loss. Not sure he is actually losing fluid though.
  16. Jul 31, 2024 at 8:29 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Ok so I had the mysterious evaporating brake fluid issue for a long while. I replaced the rear cylinders and, because why not, the brake calipers. They were ok just blown piston seals, no leaks but uneven pad wear so a sticky piston was the likely cause.
    Anywho... so it turns out that the leak was from the back of the master cylinder, and the fluid was going into the booster. Pedal went completely cock stiff one day causing me to do more troubleshooting. Booster had quite a bit of fluid in it. Soooo your master cylinder may have poor seals and voila. Same issue as me. You can pull the bung where the vacuum line connects to the booster and take a string or something and drop in in and see if it comes out wet. It should not be wet :D
    Edit: Also check your proportioning valve on the rear axle if you have one. That is a potential leak point that is tied into your brake system.
    Edit Edit: I just saw Andy's post (#13). Yup but here's my story as well. :D
    mjp2 and MadNachos like this.
  17. Jul 31, 2024 at 8:33 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    If brake fluid drops, and there is no leak, trust me it's going somewhere. :)
  18. Jul 31, 2024 at 8:46 PM
    MadNachos
    So when pads wear the fluid level stays the same? Nah.
    time623 likes this.
  19. Jul 31, 2024 at 9:53 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Oh it’s going somewhere alright. Not sure what the booster/master cylinder lifespan is suppose to be on these things but the truck is at 315,000 miles with most likely the original booster/MC
    Black97v6MT likes this.
  20. Jul 31, 2024 at 10:40 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Keep watching the fluid see if it keeps dropping.
    I think you were just low from pads wearing. I’d make sure you’re consistently losing fluid before jumping to the more complicated and expensive causes.
    MadNachos likes this.
