Loping grind in front end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by J_Hacker, Jan 2, 2020.
  1. Jan 2, 2020 at 8:09 AM
    J_Hacker
    J_Hacker [OP] Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    So over the past couple days I have noticed a loping grind in my front end. Feels like it is coming from my driver side front. It can be felt in the steering wheel and floor board. It is almost like my tires is rubbing the fender well. But my tires are no where near rubbing so rules that out. The lope goes away around 45-50 mph. Slower I go the more noticeable it is. Braking and acceleration does not change the noise. I did put it in 4wd and the noise went away. Took it out of 4wd and it went away. Drove to work this morning and it came back. I did drive through some puddles (small puddles at trash site) the other day possible some grit or grime in something and grinding. My suspicion is needle bearing. I was not able to find where anyone had the same loping with their grind. Truck is lifted 3 inches on 285’s for information sake. Thought, opinions, insight, all are greatly appreciated.
  2. Jan 2, 2020 at 8:11 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    All symptoms point to ds front diff needle bearing
  3. Jan 2, 2020 at 8:12 AM
    J_Hacker
    My thoughts as well. I did one on my 2nd gen too so luckily all I need is the bushing.
    SR-71A likes this.
  4. Jan 2, 2020 at 8:21 AM
    J_Hacker
    Agreed-o
    Superdave1.0 and Natetroknot like this.
  5. Jan 2, 2020 at 8:32 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Looks like you have a lift over 2” which would be a culprit. It’s a relatively easy fix, especially if you’ve done it before.
    J_Hacker[OP] likes this.
  6. Jan 2, 2020 at 12:56 PM
    J_Hacker
    Bushing has been ordered. Hopefully that is it. Thanks for the assitance.
  7. Nov 24, 2020 at 8:10 AM
    bfaris1
    bfaris1 Well-Known Member
    Brian
    2018 White TRD OR
    6112 #700/5160 w/ Wheeler’s AAL RCI Skids Front to back RCI sliders SSO Slimline (Hi-clearance soon) Sungtop Various other crap
    Sorry to revive your thread but did your problem go away with this? I did my bushing swap and the grinding has since come back
