Loose Valve Cover Bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotamd, Aug 12, 2020.
  1. Aug 12, 2020 at 7:50 AM
    toyotamd
    toyotamd [OP] Well-Known Member
    Arizona
    2002 Xtra Cab V6 auto TRD
    02 V6 4WD w 190k miles.
    I have had the truck for about 10 years, do almost all maintenance work myself.
    I noticed a fair amount of oil around the engine yesterday, and decided to check the valve cover bolts. I was shocked to find them remarkably loose, like so loose that I could turn them without the wrench attached to the socket extension. 4/5 of the bolts were loose like this. The oil is completely new - I have never seen oil on it before and check it frequently.
    Any idea why these bolts would be so loose all of a sudden after 190k miles? Has anyone else seen this before?
    GQ7227 likes this.
  2. Aug 12, 2020 at 8:10 AM
    Madjik_Man
    Colorado Front Range
    I’ve had those bolts loosen up and the covers seep.
    I just chalked it up to expanding/contracting over the course of 20 years and 200,000 miles.
    cryptolime and Key-Rei like this.
  3. Aug 12, 2020 at 8:16 AM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    When I did my valve cover gaskets I don't think I needed a ratchet on any of them. The washers under them have a rubber plate on them that eventually dries up and shrinks.
  4. Aug 12, 2020 at 8:27 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Everyone has had this or will soon.
  5. Aug 12, 2020 at 8:32 AM
    toyotamd
    Arizona
    thanks for the reply. Has anyone replaced those washers with the rubber plates? Anyone know the part number?
  6. Aug 12, 2020 at 8:40 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    You can snug them a bit and buy time but if you're keeping the truck it's time to do the valve cover gaskets. Cheap and easy. Lots of info. if you'll search. There's a sticky, there's a video. There's probably a website and a support group.
    CS_AR and 0xDEADBEEF like this.
  7. Aug 12, 2020 at 10:54 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
  8. Aug 12, 2020 at 10:55 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    About to do mine. Kinda dreading it :annoyed:
  9. Aug 13, 2020 at 12:12 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Mine also need doing, but I've been putting it off. so many small jobs that need done. All I need is time and money. Time I have, money I don't.
    Kolter45 likes this.
  10. Aug 13, 2020 at 5:28 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I don't have a part number for you but you definitely want to replace them when you do the valve cover. They will break very easily, and then you have to remove everything and start over. The torque on them is very low, something like 54 in/lb.
    Nessal and 1997tacomav6 like this.
  11. Aug 13, 2020 at 6:10 AM
    1997tacomav6
    Denver
    I just did mine last month,
    If you have a 3.4 v6 timing belt and valve cover gaskets are something that have to been done
    sooner or later.
    It’s not that hard of a job, just time consuming, if you can use a dremel with a brass wire wheel
    that will cut down your time removing all the old gasket material on the covers and heads and in those
    tight places, cam seals and half moons.
    Let the gasket material setup for 24 hours before running it too,
    If you have the time painting the covers is pretty easy at this time.
  12. Aug 13, 2020 at 5:39 PM
    petecarlson
    2002 4X4 DC TRD
    Not sure how this will format
    Part Number Part Name Price Quantity Total
    11213-62020 Valve Cover Gasket $24.09 2 $48.18
    11193-70010 Spark Plug Tube Seal $2.66 6 $15.96
    17176-62040 Plenum Gasket $9.63 2 $19.26
    90210-05007 Engine Valve Cover Grommet $1.08 16 $17.28
    11188-62010 Plug $9.09 2 $18.18
    11183-62010 Engine Camshaft Plug $6.63 4 $26.52
    90480-18001 PCV Valve Grommet $4.28 1 $4.28
    00295-00103 Oil Pan Sealer $11.62 1 $11.62
    cruiserguy and 1997tacomav6 like this.
  13. Nov 27, 2020 at 9:01 AM
    Toyoter
    Toyoter New Member
    2003 Tacoma
    I have the same issue...loose valve cover bolts that caused leaking oil. I keep tightening them down to spec (53 in lb), but they keep loosening up. So I'm wondering if replacing the valve cover gasket is even going to solve the problem of continuously loosening bolts. Is it a result of oil in the threads that causes them to loosen? What part of the valve cover gasket replacement job fixes this issue, specifically? I've searched around, watched videos, but nobody talks about this exact part of it.
    With that said, I should point out that half of the valve cover bolts are out of reach (covered up by other parts on the top of the engine). So I'm only able to tighten down the outer rows of bolts on each valve cover. It's occurred to me that maybe the loose bolts which are out of reach, cause the valve cover to vibrate and shake the other (recently tightened) bolts loose. That's my best guess.
    I'm gathering the parts and tools to do the valve cover gasket replacement. So hopefully that will resolve the issue completely. But even still, I'd like to know the reasoning here, so I can be a better DIY home-mechanic. My Tacoma has ruined my mechanic skills, because I hardly ever get to practice!
    WagonHo!, CS_AR and GQ7227 like this.
  14. Nov 27, 2020 at 9:40 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    ^^^ This. It's because the gasket and rubber under the bolt washer have dried up and contracted. I just tightened my VC bolts to buy a little time on my 4.7 L.
    I know I need a gasket kit.
    Look at the bright side. You could have had a V8. I think the V6s are easier.
  15. Nov 27, 2020 at 9:52 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, it’s common.
    And it’s not hard to strip the threads if you “crank them down”.
    Lubricated threads (from the leak) and over over torque can get you in trouble quick.
    I like to use 1/4” drive ratchet on them.
    Snug them up, and do the gasket when you get a chance.
    Keep an eye on it from time time, you’ll be ok.
  16. Nov 27, 2020 at 10:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    hopefully!! this thing does not come around but maybe every 20 years or so :notsure: time-elapsed on the rubber washer things drying out... unless its mileage dependent
    it was not the 'cheapest' of fixes at all :(, a bit north of $500 with a $50 coupin
    CS_AR likes this.
  17. Nov 27, 2020 at 10:28 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    if u do the cover gasket might as well do new tube seals & plugs too
    CS_AR likes this.
  18. Dec 23, 2020 at 2:16 PM
    GsuEagle18
    GsuEagle18 Hail Southern
    Atlanta, Georgia
    2004 White TRD Prerunner
    ARB Bumper, 2016 TRD OD Rims
    THIS
    Had mine done by a shop in Chamblee and they cranked mine down because my gaskets were still leaking (because they didn't do a good job) and they actually cracked my driver side valve cover. Then got mad and defensive when I told them they did it. They did replace it (with a beautiful new one stamped MADE IN CHINA after telling me it would be an OEM one) and redo the job again (even though they are still leaking).
    Long story short, you will DEFINITELY get yourself in trouble by overtightening. I'm about to try and get my money or at least half back and redo the job again myself because I don't trust them.
    Looking at this kit. Any ideas? It's a good bit cheaper than the Toyota way of buying it all individually and it's made in Japan.
    https://www.ebay.com/itm/Stone-Valv...an/323598485954?fits=Model:Tacoma|Make:Toyota
  19. Apr 24, 2023 at 9:45 AM
    Jolly Onion
    Jolly Onion Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    Changed my valve cover gaskets last year, changed grommets in the valve covers, sealed the half moons, everything went OK. Yesterday I noticed leaks on both sides of the VC, bolts are loose. As stated above, it is a common problem. I am thinking of installing studs where the bolts are and tighten them with a nut, so I do not break the threads in the head, and have to take things apart (time consuming job). Does anyone have a part number for correct thread? I prefer allen head to tighten them , but can use 2 nuts as well. Thanks
  20. Apr 24, 2023 at 9:57 AM
    toyotamd
    Arizona
    What about using some loc tite in the threads?
    cryptolime likes this.
