Loose spark plug wires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Quackerjack, Dec 28, 2021.
  1. Dec 28, 2021 at 12:08 PM
    Quackerjack
    Quackerjack [OP] Teku
    Vincent
    Washington
    1999 Toyota Tacoma prerunner TRD SR5 extended Cab v6
    King shocks Upgraded suspension Leer shell Custom exhaust Deck Plate mod Upgraded Sound system Hella 500 lights 2 1/2 inch lift Fuel pump + injectors Pro comp series 69 wheels (nice)
    So my spark plug wires were hard to remove when I took them out to replace pugs and injectors, they are now loose and are easy to pull out and spin. I've been having problems and nothing seems to fix it, the next step is to take it to a new mechanic since my last one couldn't find a problem. Could the plug wires be bad and causing me so much pain?
  2. Dec 28, 2021 at 12:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Your truck is a '99, could be long overdo.
    Why not just replace the wires when you did your plugs?
    Takes like half an hour to an hour total to do and it's crazy easy.
    Bivouac likes this.
  3. Dec 28, 2021 at 12:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Forgot to mention; use dual electrode plugs otherwise you'll be going through your single electrode much sooner.
  4. Dec 28, 2021 at 12:23 PM
    Quackerjack
    Vincent
    Washington
    Ok that helps alot
    Kwikvette[QUOTED] likes this.
  5. Dec 28, 2021 at 12:43 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I'd also recommend OEM wires. I recently helped a friend out who was experiencing a misfire. They had replaced their wires with parts store wires, and one of them ended up being bad after only a year or so. We swapped my old OEM wires on to confirm, and then they replaced theirs shortly thereafter.
  6. Dec 28, 2021 at 1:43 PM
    Glamisman
    Glamisman Well-Known Member
    maybe… please dont take offense to any of this because I am not there to point out the obvious. Some spark plugs have an adapter that screws onto the tip that the plug wire goes on. some spark plugs have a non removable adaptor, here is a good video explaining what I am talking about https://www.youtube.com/watch?v=zCIE4_DubXo
    it could be that you have a mismatched setup… I hope that it is that simple.
    Mavigogun likes this.
  7. Dec 28, 2021 at 7:07 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  8. Dec 28, 2021 at 8:47 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Another vote for NGK
    In this case, the cost of OEM plug wires is 100% completely unnecessary.
    Kwikvette likes this.
