Loose Rear View Mirror
Discussion in '1st Gen. Tacomas (1995-2004)' started by mikesdoublecab, Jan 31, 2022.
  1. Jan 31, 2022 at 7:20 PM
    mikesdoublecab
    mikesdoublecab [OP] LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Any pointers on how to tighten the mirror? I popped the cover to access the base, but the adjustment bolt is not exposed. The arm for the mirror looks like one solid plastic covered piece.20220131_144051.jpg
  2. Feb 1, 2022 at 5:03 AM
    Norcal89
    Norcal89 Active Member
    San Francisco
    Black 2003 2.7L Regular Cab 4x4 5 Speed
    Subbed
  3. Feb 1, 2022 at 5:10 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Bivouac likes this.
  4. Feb 1, 2022 at 6:58 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    The ball end behind the mirror on mine is what's loose. The mirror stays in place, but just barely. Is replacing the mirror the only fix?
  5. Feb 1, 2022 at 8:39 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    I saw that vid after i posted. If those two clips are all that binds it together with no real explanation on increasing the tension, I am not sure now if it's worth all that time to take it apart. Hoping someone has gone through the process
    six5crèéd[QUOTED] likes this.
  6. Feb 1, 2022 at 8:41 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i hope not. the ball end on mine is still good, but the whole arm is what wiggles. i am guessing from all the years of offroading it just gave out. it's not a deal breaker but on uneven roads, it jiggles enough to look Blair Witch
