Loose front turn signal
Discussion in '1st Gen. Tacomas (1995-2004)' started by SouthernYoder, Nov 13, 2016.
  1. Nov 13, 2016 at 7:56 AM
    SouthernYoder
    SouthernYoder [OP] If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    got a 2001 3.4 and just realized my driver side turn signal light is loose. The front black plastic clip is broke on the driver side and is just holding it in. Is there a way to remove the front grill or a video to show how to? Thanks in advance.
  2. Nov 13, 2016 at 8:02 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    They all do this, Clips on the grill are easy but a bit of a pain. Its not going anywhere tho. Mines been loose for 5 years lol
  3. Nov 13, 2016 at 8:23 AM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Yes it won't go anywhere. You can take out the grill to get to light fixture and maybe epoxy it or replace.
  4. Nov 13, 2016 at 9:32 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Both turn signal assemblies on my 1998 Tacoma have been loose for the last 16 years and have not come off, even over hundreds of miles of washboard and rough terrain found in southeastern Utah and central Nevada.
  5. Nov 13, 2016 at 3:44 PM
    bradkaren
    bradkaren coffee lover
    Pacific Wonderland
    2001 Silver Tacoma SR5 4WD V6 AT
    Here's a video to show how to remove the grill, headlamps, and sidelamps.
    https://youtu.be/WwSyjKVwl-k
    More than likely the tabs broke while replacing the headlamp(s) - mine did.
  6. Nov 13, 2016 at 4:00 PM
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    Only about $15 to replace if you dont want it shaking but everyone on here says it wont fall out.
  7. Nov 13, 2016 at 6:12 PM
    SouthernYoder
    Knoxvegas, TN
    Thanks for all the help guys. I should have it from here.
  8. Nov 14, 2016 at 1:22 AM
    KiteGuam
    KiteGuam The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
    They rarely fall out! mine's been broken since I bought the truck but since I did the corner light mod. it's got two sets of wires to keep it from going anywhere
  9. Nov 14, 2016 at 8:28 AM
    skeezix
    Colorado
    1998 Limited
    Oops, bad info.
    The lights I refer to in the above post are the two running lights that are in the bumper, and NOT the turn lights. Sorry...
  10. Nov 14, 2016 at 8:59 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Both of mine are loose. No issues.
  11. Nov 14, 2016 at 6:57 PM
    liftedsr5
    liftedsr5 Active Member
    sr5
    3in lift, front fox coilovers.
    my passenger side became loose and popped out multiple times whenever I hit a bump. I just used a zip tie and bailing wire to rig it.
    Hamer95USA likes this.
