Looking to purchase New Rims
Discussion in 'Wheels & Tires' started by SilverTaco2013, Oct 8, 2015.
  1. Oct 8, 2015 at 12:44 PM
    SilverTaco2013
    SilverTaco2013 [OP] Member
    Andrew
    Evans, Georgia
    13 DCSB 4X4 Sport
    None under warranty
    Good day all!,
    I have a 2013 Toyota Tacoma TRD sport 4x4 and was looking at getting new rims and tires. My questions is does this TRD rim PTR20-35110-BK. Fit my vehicles bolt pattern and size. I plan on getting the stock size BFGoodrich All terrain T/AO tires. Any help is appreciated
  2. Oct 8, 2015 at 12:47 PM
    la0d0g
    running for the hills
    For crawling not hauling
    SEMA wheel. Yep it'll fit.
  3. Oct 8, 2015 at 12:51 PM
    SilverTaco2013
    Andrew
    Evans, Georgia
    13 DCSB 4X4 Sport
    None under warranty
    Awesome Thank you!
  4. Oct 8, 2015 at 1:06 PM
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    Welcome to TW. Post a pic when you get the new rims.
  5. Oct 8, 2015 at 1:53 PM
    StupidPanda
    StupidPanda Member
    Leif
    '15 TRD Sport DCLB Super White
    TBD
    Welcome! I recently installed these wheels on my '15 DCLB TRD Sport. Your stock lugs will work as well (but I had to have black). I paired them with 265/70/17 Hankook Dynapro ATM RF10s. I chose this setup for the looks and a little more ground clearance. It didn't hurt that the tires are priced very affordably and have mostly very positive reviews and are light weight for their size. Tire (P rating) was only slightly heavier than stock and the wheels are a bit lighter, so it evens out if not a little lighter than the stock setup (should be 1 lb. lighter according to claimed weights--I didn't weigh anything). I didn't want to add a bunch of rotational weight to my truck that would kill its initial power/torque and decrease mpgs.
    This tire size (265/70/17) should work with minimal to no rub with our stock wheels, however with no lift/leveling kit, this wheel/tire size combo rubs a lot (front mud flaps right at the bottom of the fender). I think they rub because the wheel has a bit wider stance than stock, so instead of stuffing in the wells they have more potential to contact the fender flares/flaps. They will also spray your cab with road debris a little more than stock because of this spacing. They barely look like they stick out, but they do just enough to cause them to rub. Not sure what I'll do, but I'm worried about damage and getting tired of the noise every time I turn into a driveway or while going through potholes. Anyway, it's more info than you were probably looking for, but I just wanted to warn you in case you think you may ever want to go up a tire size without lifting. Maybe with stock tire size they wouldn't rub at all.
    And one last note, I've read of people complaining that the red TRD logos will decide to peel off soon after purchase. I wasn't really concerned about this until I saw a Tundra in town with only the red 'R' remaining. I found a part number for replacement hub caps but many have recommended a matte clear coat over the caps before installing the wheels. Cheers.
  6. Feb 24, 2016 at 12:10 PM
    SilverTaco2013
    Andrew
    Evans, Georgia
    13 DCSB 4X4 Sport
    None under warranty
    I said I would post pics once I got them on and here they are with BF Goodrich All Terrain KO2's
  7. Feb 26, 2016 at 1:08 PM
    BuffaloScout
    BuffaloScout Well-Known Member
    Minnesota
    10 4x4 TRD
    Weathertech, Wet Oaks, Baby Car Seat, Flashlight Mod
    Just purchased new wheels for my 2010 Tacoma off of Ebay...$599
    Can't wait to put these bitches on ASAP!
