Looking to purchase a 3rd gen - what is the best year?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BackToYota, Feb 27, 2023.
  1. Feb 27, 2023 at 7:50 AM
    BackToYota
    BackToYota [OP] Member
    2020 Super White TRD Off Road DCSB
    I'm looking to purchase a 3rd gen 4x4 Tacoma (likely a 2017-2021) within the next 6-8 months. Knowing that no vehicle is perfect and will eventually need repairs, what seems to be the year/model that is the most reliable and what are the major issues I need to be on the lookout for or to prepare for?
  2. Feb 27, 2023 at 7:51 AM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    2021 will be the most reliable year of those listed.
  3. Feb 27, 2023 at 7:56 AM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    12-15 ;)
    But in seriousness, I'd try to get 18+. It's only one truck I'm basing this on, but my old man's '17 has been kind of a turd since day one (front diff failed, headlight and wiring issues, poor shifting by the trans, and the actual shifter itself has gotten stuck or hard to move several times. Also has been hard starting recently). You'll want to avoid them in white as well due to poor quality paint, there's several places with rust bleeding and chipped / flaking paint on his truck
    J Williams and D-Bag like this.
  4. Feb 27, 2023 at 7:56 AM
    soggyBottom
    soggyBottom Well-Known Member
    The newer the better (generally speaking). 2 things to consider.
    1) when a new generation comes out e.g. 2016, there will be problems that will eventually be fixed in later generations.
    2) when viewing the number of issues on consumer reports, later year vehicles may look better because they don't have enough of a history yet to show their problems.
    Malvolio likes this.
  5. Feb 27, 2023 at 8:11 AM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    Not sure reliability wise, but feature wise 2020 was the first year power drivers seat and apple carplay / android auto were standard features.
    dead cat, BigEasy, TacoManOne and 2 others like this.
  6. Feb 27, 2023 at 8:12 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    2020 and up cause Carplay.
    JDKred, WELLSPRING, ACSTaco and 2 others like this.
  7. Feb 27, 2023 at 8:57 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Some features were added over the years and some taken away. Depends on what you want. I would love Carplay, but wouldn't want to give up my bed cubbies.
  8. Feb 27, 2023 at 9:00 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    If 4 cylinder, any year.
    If V6..2019/2020
    Emmohl, JDKred, BigEasy and 2 others like this.
  9. Feb 27, 2023 at 9:15 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    They’re all reliable overall. ‘18 (safety) and ‘20 (CarPlay LED’s power seats) are step-up years for features.
    ‘16-‘17 had some well documented early build teething issues, but even a well maintained ‘17 likely had those issues corrected and will serve you well moving forward.
    Regardless of year just make sure you have outstanding service records and check underneath & everywhere in between. A lot of trucks in general will get beat to hell & traded off at the first signs of trouble. That has nothing to do with the inherent reliability so even a newer one could potentially be your next big headache.
    Good luck!
    Canadian Caber and na8rboy like this.
  10. Feb 27, 2023 at 9:18 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Most notable differences, of the years you specified:
    2017 doesn't have all the nanny stuff (TSS). 2018+ does.
    2020/2021 has the automatic transmission fix applied.
    2017 and early 2020 automatics have the external transmission cooler.
    WELLSPRING, BigEasy and shakerhood like this.
  11. Feb 27, 2023 at 9:20 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    2020+ is how I’d do it. 2020+ facelifted with excellent headlights (leds)
    19+ No 3rd brake light leak
    20+ Better auto shifting due to new software
    A few coolant leaks happened in the 16s and 17s
    BigEasy and mic_sierra like this.
  12. Feb 27, 2023 at 10:07 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Like my 4 banger 2016, not any open issues. 85k. The battery was replaced
    BigEasy and LeakyAC like this.
  13. Feb 27, 2023 at 10:21 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    2021 SR-5 has been proven to be the top of the food chain when it comes to Tacomas. Read up on it.
    t2c and Road_Warrior like this.
  14. Feb 27, 2023 at 10:30 AM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    2020 built before March....
  15. Feb 27, 2023 at 3:51 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    2017, no TSS nanny's.
    Tnc, Lt. Dangle and Bigfsur like this.
  16. Feb 27, 2023 at 3:54 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I think I'm starting to understand this CarPlay things...thx!
    atc250r likes this.
  17. Feb 27, 2023 at 4:19 PM
    InThePlains
    InThePlains Well-Known Member
    2020+ are Mexitaco? 2019 and older were made in Texas.
  18. Feb 27, 2023 at 4:28 PM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    I think it was split between Texas and Mexico until 2020, then 2021 and after they're only made in Mexico.
    LeakyAC likes this.
  19. Feb 27, 2023 at 4:41 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    My 2020 was out of TX.
    As others stated I'd look at a 2020+ for power driver seat, android auto/carplay, and LED headlight option. 2021 also got dual zone climate control standard in the TRD models.
  20. Feb 27, 2023 at 4:55 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I can add to this by saying my ‘21 SR5 has been perfect since the day I bought it. 0 issues and I drive it a lot.
    t2c and AM6217[QUOTED] like this.
