Looking to change out for a crate motor
Discussion in '4 Cylinder' started by toxictacoma, Sep 23, 2013.
  1. Sep 23, 2013 at 10:00 AM
    toxictacoma
    toxictacoma [OP] Member
    Logan
    Louisville
    '98 2.4L RWD Tacoma
    My '98 Tacoma is a small 2.4L 4-cyl with problem after problem. It has over 200k on it, so i was thinking of changing out for a new crate motor, but i was wanting the bigger 4-cyl that Toyota offers for my truck. Does anyone know if its compatible with the current transmission, or would i have to replace the transmission as well as the front & rear suspension?
  2. Sep 23, 2013 at 10:40 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    Hi and welcome to the forum.
    That's weird. That combination seems to be one of the more bulletproof here. Some member have reported they're at 600k miles and still driving to work. Have you considered a complete rebuild?
    Unfortunately I can't help much with your question though other than look into a 2RZ-FE to 3RZ-FE swap.
  3. Sep 24, 2013 at 4:52 AM
    toxictacoma
    Logan
    Louisville
    '98 2.4L RWD Tacoma
    Hello & thanks :)
    I mean, I can still drive it to work no problem, but it's getting to the point where everything is breaking down. The exhaust has fallen apart, starter, alternator, battery cables...
    I was thinking of rebuilding, but I don't want to re-hone or resurface.
  4. Sep 24, 2013 at 6:36 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    But what about the condition of the motor itself?
    Its going to be a lot more work to swap an engine than to replace the things you listed...
  5. Sep 24, 2013 at 9:34 AM
    toxictacoma
    Logan
    Louisville
    '98 2.4L RWD Tacoma
    I havent gotten down & dirty with the engine yet. No major problems like a rod knockinv or anything, i just want a little more power out of my truck.
  6. Sep 25, 2013 at 11:22 PM
    2007 tacoma
    2007 Access Cab
    TRD made a supercharger for your engine. I don't know if they still do. Paradise Racing also make a bunch of performance parts for the 2RZ-FE. You could also ask in the 1st gen section to see what others have done.
  7. Sep 25, 2013 at 11:48 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    A crate motor isn't going to replace anything but the motor.
  8. Sep 26, 2013 at 4:16 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "The exhaust has fallen apart, starter, alternator, battery cables..." That's just normal maintenance at your truck age and mileage.. You don't need a motor you just want more power. Wouldn't it be easier and cheaper to just sell it and get a 6 cyl Tacoma ?
