Looking to buy TRD PRO 22+ factory 1/2" rear block
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Chief_CNMI, Dec 13, 2022.
  1. Dec 13, 2022 at 11:46 PM
    Chief_CNMI
    Chief_CNMI [OP] Well-Known Member
    Bryan
    Saipan, Northern Mariana Islands
    2020 4x4 V6 SR5 White
    All lighting are led, wheels, tires, 5100 lift, pro grill, bed light, seat covers, door sill protectors.
    Looking to buy OEM TRD PRO 22+ tacoma 1/2" lift block just as in the the photo. Let me know on your price. I'll pay shipping as well.
  2. Dec 14, 2022 at 7:24 AM
    Ncousins1
    Ncousins1 Well-Known Member
    Niko
    Gainesville, FL
    2023 Solar Octane TRD Pro Tacoma
    I'll have them available possibly around new years or a little after. I have the Westcott lift ordered, just not sure how quick I'll be able to get it done. Not sure the time frame you are on but I can reach out if you havent found them by the time I have the new lift on
    Chief_CNMI[OP] likes this.
  3. Dec 14, 2022 at 4:20 PM
    Chief_CNMI
    Bryan
    No rush, but the sooner the better :')
    Ncousins1[QUOTED] likes this.
  4. Dec 15, 2022 at 2:55 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I'm wondering if these 1/2” blocks require a longer center pin or if they just slip under the existing center pin.
    Aftermarket 1/2" require a new one, and I don't want to go through the pain of aligning them through the springs again.
    Off topic, but it is cool to see someone from 670.
  5. Dec 15, 2022 at 7:09 AM
    anamorphic
    anamorphic Well-Known Member
    08 TRD Sport 4x4
    Also looking for the 1/2 block- wonder if there’s a part number to purchase yet?
  6. Dec 15, 2022 at 8:37 AM
    Rainoffire
    Yes, PT82A-35220-SS
    Each side is identical so you have to buy two.
    They aren't expensive, but I haven't bought a set yet, cause I couldn't find info back then on if they needed a new centering pin or not.
  7. Dec 15, 2022 at 8:53 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    What’s the deal with OEM blocks?
    Why not make it easy and go to Supreme or another aftermarket company and just order a set from them. I mean, it’s only a block, not a OEM Fox shock or something… Just trying to know what makes this any different other than a larger price and hard to find.
    OG_Tacoma likes this.
  8. Dec 15, 2022 at 9:25 AM
    Rainoffire
    They aren't particularly expensive, actually is cheaper than most other 1/2” flat blocks. It is only $7ish for one, so around $15 for two. And are not hard to find, you can easily get them from any Toyota Online Dealer.
    OG_Tacoma and Taco1004[QUOTED] like this.
  9. Dec 15, 2022 at 10:11 AM
    quantumechanic
    quantumechanic Well-Known Member
    2009 Tacoma TRD-Off-Road AC 4x4
    I think the Trail Edition also uses a 1/2 inch rear spacer. Don't know if its the same part number as the newer TRD Pro or not.
    I did some searching and couldn't find any other source for a 1/2 inch rear block besides OEM. Smallest I could find anywhere else was 1".
    The 1/2 inch block could be popular for people wanting to DIY a Trail Edition type lift (1.1" in front, 1/2" in back).
  10. Dec 15, 2022 at 10:28 PM
    Chief_CNMI
    Bryan
    No they don't require new center pin. Thats why I'm after these specifically. and yes, buenas aha
  11. Dec 15, 2022 at 10:33 PM
    Chief_CNMI
    Bryan
    To what I could tell, they hold into place better. And there's people out there like me who probably have a AAL or Leaf pack installed but still want to gain that 0.5" of lift in the rear without adding a 1" whole block nor AAL making the ride stiffer. I got a AAL and my rear end has settled down to 1.5" of lift in the rear. So just tryna get it back up to 2"
    Taco1004[QUOTED] and Rainoffire like this.
  12. Dec 21, 2022 at 8:30 AM
    Chief_CNMI
    Bryan
    Bump (idk if this even works)
    BUMP!! STILL IN SEARCH OF 0.5" OEM BLOCKS :)
  13. Dec 21, 2022 at 11:14 AM
    Ncousins1
    Niko
    Gainesville, FL
    Still waiting for my Westcott kit to come in and I won't need my OEM blocks anymore. hoping it'll be soon!
  14. Dec 21, 2022 at 3:24 PM
    Rainoffire
    I believe those with the OEM TRD Lift Kit (PT84K-35221) also share the same 1/2" block in the rear.
    So those with the kit can be another source for the part (PT82A-35220-SS)
  15. Dec 21, 2022 at 4:53 PM
    Chief_CNMI
    Bryan
    Couldn't verify the second
    The block that comes with the kit are 1" I'm ISO of 1/2".
    The second part number you provided, i couldn't verify if that is the 1/2" block. There no pics or much info bout it.
  16. Dec 21, 2022 at 7:04 PM
    Rainoffire
    Ye, I just rechecked from other sources with the kit, you are correct that it is a 1" block.
    So only the 2022 TRD Pro are the only ones with the 1/2" blocks. Part Number PT82A-35220-SS is the one provide by TW's local dealership parts rep @Jeff Lange
  17. Dec 22, 2022 at 5:44 AM
    Chief_CNMI
    Bryan
    Ima assume that part number is for the 1/2" rear block? And yes only the trd pro comes with the 1/2" block I believe, and maybe also the trail edition.
    And is that Jeff? Like the 'ToyotaJeff reviews' on youtube?!
  18. Dec 22, 2022 at 10:48 AM
    gregnauman
    gregnauman Well-Known Member
    Greg
    2020 Tacoma TRD Pro
    None
    Headstrong Offroad makes a spacer approved for their 1.5” 3 leaf add a leaf kit to make it 2”
    https://www.headstrongoffroad.com/store/c123/AALs_Air_Bags_Blocks_and_U-bolts__-_Tacoma_2016_.html
  19. Jan 1, 2023 at 1:23 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I am not ToyotaJeff on YouTube.
    Jeff
    Rainoffire and vivid02 like this.
  20. Jan 7, 2023 at 1:02 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    This sounds like a great solution to add back just a bit more height to the rear and keep it all as oem as possible.
    I have the Pro Fox front and rear shocks already and love the way it drives daily.
    I feel as the rear seems lower than the front as soon as I add a bit of weight in the back.
