Looking for the best overall manufacturer nerf bars/sliders/running boards...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gmatt21, Jun 20, 2017.
  1. Jun 20, 2017 at 9:58 PM
    gmatt21
    gmatt21 [OP] Active Member
    2017 White TRD SPORT 4x4
    Who is the go to? What is a good price?
  2. Jun 20, 2017 at 10:10 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Well I already gave you the luxury of axing 2 categories. Sliders are the way to go.
  3. Jun 20, 2017 at 10:17 PM
    gmatt21
    Main concern is armor for my side doors
  4. Jun 20, 2017 at 10:25 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Sliders. It's all opinion from there. I like my SOS concepts, other people like whatever they chose to buy. I'd look for whoever is running a sale.
    JimboAnz likes this.
  5. Jun 20, 2017 at 10:31 PM
    GuerreSOK
    GuerreSOK Well-Known Member
    2017 Blue Tacoma TRD Sport DCSB
    OP, I'd also do some research and figure out which Slider company may happen to be closest to you location wise and go with them.. unless you don't mind paying out the butt for shipping costs.
    For me on the north east / east coast.. I'm going to end up going with Mobtown Offroad when I get mine. As far as I'm aware, they're the closest to me being somewhere in Maryland.
  6. Jun 21, 2017 at 6:35 AM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I went with Mobtown also even though I'm on the west coast. The main reason was their well thought out full bolt-on setup. Everyone else's need to drill a couple of holes in the frame to be full strength (actually BAMF didn't need the holes either but they had a very long lead time).
    gmatt21[OP] likes this.
  7. Jun 21, 2017 at 6:44 AM
    fuzzynet
    fuzzynet Active Member
    James
    Tempe,AZ
    2017 Blazing Blue Tacoma TRD 4x4 Offroad
    Fuel Wheels,Nitto Tires
  8. Jun 21, 2017 at 9:05 AM
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
  9. Jun 21, 2017 at 9:22 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I was hesitant to buy from Tyger.... don't hesitate. I LOVE my steps and literally just about every day someone comments on how awesome and functional they look (esp. on my silver)! Good build quality and the semi-glossy powder coat is pretty awesome looking (with frequent coats of 303 to keep it looking good).
  10. Jun 21, 2017 at 9:25 AM
    ICU1
    ICU1 Well-Known Member
    Magnum RT steps. Purchased from Auto Everything. Very heavy duty. Easy install. Included step light kit. $371.00
    kgilly likes this.
  11. Jun 21, 2017 at 9:26 AM
    TashcomerTexas
    No offense but Nerf bar/running boards aren't "functional" in the aspect of protecting the truck. Bolted to the body and not the frame.
    For the kind of money they are I'd spend a little more on actual sliders that can protect the rocker panels, undercarriage, and fuck up some serious mall-door swingers.
  12. Jun 21, 2017 at 9:27 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    What about ground clearance?
    One thing I like about sliders, is that they are typically angled up 15-20 degrees and really hug the bottom of the truck.
  13. Jun 21, 2017 at 9:30 AM
    bshammer0
    Brandon
    Nashville, TN
    function is based on the utility you need from the truck. I needed a FUNCTIONAL step that: protected my doors from dings (check); was a wide enough step and high enough to function as a comfortable platform to stand on for loading/unloading of gear on my Prinsu; nice to have if it would provide a bit of protection from minor scrapes (which it does). I'm not rock sliding, do light offroading - generally on farms or nat'l forest fire roads. For my "function" they were perfect. They also catch a ton of things that would otherwise hit my paint on the sides which is a plus.
    But no, these do not bolt to your frame and thus are not intended to support the weight of the truck. Need sliders if that's your primary use case.
    birry likes this.
  14. Jun 21, 2017 at 9:37 AM
    bshammer0
    Brandon
    Nashville, TN
    And ground clearance isn't impacted - the lowest point on these steps is almost exactly the same as the bottom of the truck's frame.
  15. Jun 21, 2017 at 9:40 AM
    TashcomerTexas
    More power to you. My point is that for almost $300 if you spend another $100-200 you can have sliders that work both as steps and protect.
  16. Jun 21, 2017 at 10:00 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    I'm pretty sure only a few steps will be good enough for door ding protection as they try to tuck them closer to the body. Some sliders are that way too. The steps themselves will protrude. You'll still get whacked on the upper door if there's a taller truck or suv by you.
    I added door moldings to help cover that and then I had sliders made to poke out some more to cover the doors.
    I admit I'm a mall crawler at this time and some steps can be as pricey as sliders (oem predators) so that's something to consider too.
    Here's my vid that i jumped to the spot showing my moldings and how it protrudes more
    https://youtu.be/LYJciP14M2M?t=845
  17. Jun 21, 2017 at 10:08 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Another option is to find a local weld/fabrication shop and design your own slider/step/board so that it meets your needs.
  18. Jun 21, 2017 at 10:17 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    If you decide on SOS Concepts, message me for a discount code :thumbsup:
    bshammer0 likes this.
  19. Jun 21, 2017 at 11:08 AM
    SeanDub
    SeanDub Well-Known Member
    Sean
    Morgan Hill, CA
    2017 TRD Off-Road
    Icon Stage 4
    He said they compliment how functional they look, so I guess that's probably accurate.
  20. Jun 21, 2017 at 11:45 AM
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Sliders hands down! Plus you're supporting a small business and they will be made in the USA!! Most running boards are going to be made in China, even NFab stuff. I recently ordered a set of sliders from SOS Concepts. You can't beat Eddy's prices or even shipping prices for that matter.
    JimboAnz, bshammer0 and Rob Daman like this.
